Question about Vizio GV42L 42 in. LCD Television
Screen goes black, static, then pops back (within 1-2 seconds). If I rewind the DVR, it doesn't show the blip, so I'm assuming it's a TV problem, and not a Verizon FIOS problem.
  • Vizio Master
  • 8,457 Answers
The backlight video inverter board is dead.Need a new board.
Posted on Sep 29, 2009
LG 60PA5500 component 1 screen pops up
Try doing an "AC reboot" by unplugging the TV, waiting 30 seconds, then plugging it back in. Sometimes the microprocessor get s glitched from blips in the power. If that does not cure it, there are issues on the mother board that need repair.
Dec 03, 2013 | LG 60PA5500
Dish HD-DVR connected to a Denon 3808ci via an HDMI cable. Problem is periodically, the screen goes black for a split second and then comes back. Rewind and play again the blackout doesn't repeat. When...
Your'e losing digital data from Dish or the DVR. Since even live TV is through the DVR it is always a potential problem when anything glitches. That it doesn't repeat on immediate rewind/playback says the data made it to the hard drive ok.
The Denon is only defaulting back to an analog audio feed upon loss of the digital (preferred) one.
If it affects the video AND audio simultaneously the cause is something common to them.
I'd look at HDMI cabling into the Denon from the DVR.
Don't blame the Denon just yet.
My $.02:
I'd skip the video right past the Denon to the TV/Monitor even if it means using component cables instead of HDMI, but keep digital audio coming in from the DVR. Added cabling and connections never improve anything. Plus, HDMI cables are expensive.
It would be interesting to see if the problem comes back and affects only the audio or the video.
If you use optical cable make sure it has smooth flowing curves and no small-radius bends that would lose light power.
http://www.retrevo.com/support/Denon-AVR-3808CI-Receivers-manual/id/3124dj391/t/2/
Feb 06, 2011 | Denon AVR 3808Ci Receiver
I have 3 att uverse cable boxes...1 being the dvr unit. The room with the dvr unit only shows a black screen with live tv? When I go to watch a recorded show it works in the other rooms but is a black...
Is the cabling from the satellite receiver to the DVR hooked up right. It sounds like it's in single mode, but with the coax cable put on the wrong way.
Nov 23, 2009 | Computers & Internet
Dvr doesent work
Hi djn Collinswhen your DVR is not allowing you to pause or rewind live TV you will need tounplug the receiver for 10 seconds and allow the receiver to power back up and acquirethe signal. Then you will want to try the functions again and make sure theyare working fully.
Jun 25, 2009 | DISH Network DVR-625 DTV Receiver /...
Picture goes bad when playing Verizon Fios DVR or On Demand
I had issues when I set an SD override for the box, it would sometimes display as bad input when switching to HD content(as well as display all menus in SD even with HD mode in settings.) Turning that off in settings (also turned off "modes" which has no description) stopped it and gave me guide/menus in HD.
Apr 04, 2009 | Sharp Televison & Video
My TV is going into standby mode whenever it is turned on
My screen turns black and the TV goes into standby mode (I get an Amber Light) within 3 seconds after turning the TV on.
Dec 16, 2008 | Televison & Video
Screen going black on LG60PG60 TV
It does seem to be a tv problem, check the input connector to the tv next time when it happen, this tv seems to have problems with connectors or could be the video processor good luck
Nov 22, 2008 | LG MU-60PZ11 60 in. Plasma Television
DVR won't play
I hae a Motorola 6412 that had this problem. I turned it off, then unplugged it for 30 seconds. After turning it on I had to wait 1-2 minutes before I could acces the DVR, but it work now.
Jun 11, 2008 | Arris DCT6200 DTV Receiver
Picture "blip" every 1-2 seconds
Try unplugging the Dish box for a minute, then plug back in, is the program guide blippy?
Jul 14, 2007 | JVC HD-52G886 52" Rear Projection HDTV
RCA 27" TV F25432
You apparently have a high voltage arc. Possibly the anode lead to your picture tube. Also the flyback transformer could be arcing. If you're not experience with tv repair, you need to have a tech check it for you. The circuits operate at very high voltage and if you get into it you can get a possibly fatal electrical shock. Be careful !!! Stargazer
Jan 11, 2007 | RCA F27645 27" TV
Vizio GV42L 42 in. LCD Television Logo
165 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
