I got a gigabyte motherboard, when i hook it up the only thing that comes on is the fan itself, the hard drive dont light up and neither does the dvd rom....now i bought two brand new processors for it, i tried them both and it does the same thing, so please someone help me figure out what the problem is...
    President:
  • 1,901 Answers
Sounds like the first thing you need to check is if you are getting all the voltages out of your power supply.
Here is a link to the pinouts of the connectors. if you have a faulty PS replacing the CPU or motherboard will not help.
http://www.helpwithpcs.com/courses/power-supply-basics-inc-pinouts.htm
Is there a green LED on your motherboard at all?
You said the fan comes on. Which fan? You should have a CPU fan, a case fan, and a power supply fan.
Posted on Sep 29, 2009
I get nothing except the fans running for about one second. No lights, no beeps, no noise. No nothing. If I push the button again I don't even get the fans to run. If I wait I get the fans again f
Chances are that your power supply is toast.
Although you could try removing either one of your rams (if you have 2), and unplugging any optional device plugged onto the motherboard (Hard drive, dvd player)
In the worse case, your motherboard could be broken and need to be replaced.
Did anything particular happen before it stopped powering up?
Jul 05, 2012 | Computers & Internet
Just installed a new Gigabyte 880GM-D2H motherboard, 4 GB RAM (Corsair DDR3 1333), AMD Phenom II multi-core processor (X6 1055T), 750 W power supply, Maxtor 500 GB hard drive and a Blu Ray DVD Drive. ...
motherboard to hard drive leads
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
one bad lead will end with a computer error a computer needs its connections continue its cycle and have an end to function properly
even something as small as an electrical extension or a faulty fan lead can cause this problem computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
hope this helps
Jul 25, 2011 | Gigabyte (GA-880GM-D2H) Motherboard
Fan does not come on
Try plugging in the fan into a different fan header to test to see if it functions. Also it may not turn on right away.
Mar 16, 2011 | Gigabyte GA-EP45-UD3R Motherboard
Gigabyte motherboard problem
I suggest you replace the motherboard.
If you know a service center near you that can fix motherboard then bring it to them to have it check.
May 20, 2010 | Gigabyte MB GIGABYTE GA-MA74GM-S2H AMD740G...
Just in the process of bulding my firs pc. using an intel cpu and a gigabyte motherboard. having problems getting it to boot. the cpu fan starts to spin and the board light,s up for a second then stop's....
try to go to its set up and in try to change the boot settings in drive C: if it fails try to reformat your hard drive and if still not work maybe your motherboard and processor is not compatible
Mar 28, 2010 | Gigabyte Computers & Internet
Main bios checksum error
You have to change the CMOS battery located on the motherboard...
Mar 28, 2009 | Computers & Internet
Components aren't powering up
Sounds like the board is not receiving power. Check that the power connectors from the psu to the motherboard are securely in place, or else try another psu
Mar 22, 2009 | Gigabyte Computers & Internet
Problems with Gigabyte GA-8I845GVM-RZ Motherboard
nothing but the fans run.the hard drive will run if i unplug the ribon.I changed the power supply and still not working
Mar 08, 2009 | Gigabyte GA-8I845GVM-RZ Motherboard
Computer randomly fails to boot
how many video cards do you have installed?
Nov 14, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
