Question about GE WSXH208A Front Load Washer
How to balance a front load GE washer. I bought this from a friend. It does fine when it has nothing in it, but when I put a load in, it nearly jumps off the ground. I know now that there are some type of balancing things that go int the back (found those after the fact) but the bottom is balanced and all level..Please help if anyone can. I have been googling trying to solve my problem.. Thank you for any help :o)
  • GE Master
  • 2,605 Answers
I'm not aware of any "balance things that go in the back" as you put it. if by chance you are refering to the transportation/shipping bolts, they need to be removed when the unit is in use and only neccessary for moving the washer.
Try this first **UNPLUG the unit from the wall** before calling a tech.
# 1...make sure you use "HE" detergent in any front load washer, including this one.
You can pull off the bottom service panel (2 screws) on the front of the washer and look to see the shock absorber's or the concrete counter weights aren't broken. while you're at it, pull off the top and inspect the suspension springs are intact to the cabinet/chassis.
start there
good luck
Posted on Sep 29, 2009
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
The washer is very off balance from moving
This washer right here has a tub which is suspended on four rods. The lateral movement is kept in check by 4 bungy cords. These stretch over time. One of the support rods could have easily jumped out of place. This video from my friend Shawn Ryan shows how it breaks down:
Apr 16, 2011 | GE WBSR3140DW Top Load Washer
My front load GE washer would not drain . balance looks fine. pulling the power source and replugging did not help WCVH6800J1WW Serial IS205695T -
if this washer has a control board on top of motor try opening the lid six times within 6 seconds... then start washer .... if it does have board ontop of motor look at board is green indicator lit up if not replace fuse link white wire with red line threw it from motor has a one time fuse link in wire replace fuse link or jump across to test
Jan 24, 2011 | GE WJSR2070B Top Load Washer
How do I balance a load. My front load GE washer seems to jump around a whole bunch.
In theory the front load washing machine is self balanced. The problem you are experiancing is most likely due to the machine being impropperly leveled on the floor. It is not only important to have the top of the machine level front to back, and side to side. It is also essential to have good pressure on all of the leveling feet of the machine.
Any side to side motion of the machine will be magnified if the feet don't share the load. (The weight of the machine and its contents.)
The easyest way to accomplish leveling the machine propperly is to put a level on the top of the machine on a flat surface from side to side, and turn each foot down untill it is leveled propperly by the back feet. be careful that you don't mess up the exhaust hose, gas line, ect while doing this.
Then put the level from front to back, and make slight adjustments to the front feet until it is level in both directions, and has equal pressure on both front feet. You can usually tell by the resistance the foot has to turning.
Then just run a load of laundry as usual. It should run great for a very long time, but need adjustments againeventually.
Presto.
Oct 28, 2010 | GE WSXH208A Front Load Washer
My GE washer got off balance and now i hear water slushing beneath the barrel. and the barrel is lopsided. how do i get front off
Your machine probably jumped the shipping bracket.To remove the front cover use a putty knife between the top cover and the front panel. There is 2 clips that hold the front cover. Push in on the clips 1 side at a time and pull the front forward.
Mar 01, 2010 | GE WBSR3140DW Top Load Washer
GE Front Load washer shakes whenever any type of load is put in. GE service has been out at least 4 times and say that its fine..perfectly level, etc
All front loaders shake to some extent. It depends on the balance of the load. It is especially evident in the spin cycle due to the high speeds. Also these machines are best placed on a solid cement floor. They can shake an entire house if on the first or second floor and the floors are not well reinforced.
Feb 25, 2010 | GE WSXH208A Front Load Washer
GE TOP LOAD WASHER DOES NOT AGITATE OR SPIN
ck lid switch can be acessed by pressing clips at front edge of front anel and pulling panel off
Nov 20, 2008 | GE WWSE5200B Top Load Washer
Timing is off
timing is not the probelm off balance load or washer not solid on floor is...front load washer try to balance load as much as possible before full speed spin the 10 min is only and est ..additional time will will be taken trying to balance load and no ge won't do anything about the walking best try getting machine as solid as possible if on pedistal good luck..lower bottom as close to floor as possible both rear legs all the way up adj front legs for solid setting try rocking washer and adj legs till solid..also weak floor?
Jul 08, 2008 | GE WSXH208A Front Load Washer
Front Load Washer
have you took the transporting bolt out the back of it yet
Feb 18, 2008 | Whirlpool GHW9100L Front Load Washer
Walking during the spin cycle
Try placing it on a rubber mat or carpet that has a rubber backing. The floor may be too smooth and allows it to walk.
Oct 12, 2007 | GE WSXH208A Front Load Washer
GE WSXH208A Front Load Washer Logo
449 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
