When I connect my laptop directly to my HP w2338h monitor the resolution adjust itself to the monitor resolution of 1920 x 1080, but when I connect to my iogear kvm switch the resolution adjust 1024 x 768.
  • apostolos_bu Sep 29, 2009
    Well I have my other laptop connected to the other KVM swtich cable and it properly displays the correct resolution 1920 x 1080. So there has to be another reason why.
    When I connect my laptop directly to my HP w2338h monitor the resolution adjust itself to the monitor resolution of 1920 x 1080, but when I connect to my iogear kvm switch (Model#:GCS632U) the resolution only adjusts to 1024 x 768. I checked the specifications for my KVM switch and it shows that it can support video resolution up to 2048 x 1536. Also, if this helps I know that this should work since I do have another laptop connected to the other cable of the KVM Switch and it is working properly (monitor displays resolution 1920 X 1080). Any help would be greatly appreciated!
  • 13,433 Answers
Are you able to adjust the resolution to the correct one from the laptops settings?
Posted on Sep 29, 2009
  • 1 more comment
  • Ekse Sep 29, 2009
    Hi
    Probably all you need to do is to adjust the resolution of the external monitor from the laptops settings.
    On your laptop desktop, right click on your background and select Properties. In properties select the last tab "settings" click on the Monitor #2 (it will only show numbers alone like 1 or 2 CLICK ON 2) Now adjust the resolution from the lever below. set it to the optimal 1920x1080 then click Apply and OK
    If you have vista its little different, right click on desktop, select customise? and screen resolution. do the same things as above.
    if you don't have 2 monitor screens in the settings, then press the FN button together with one of the F1 - f12 keys, one of them will switch between different screen settings --- Only laptop screen, Only external, both. it needs to be set on both, after swapping the settings go back into the screen resolutions and try adjusting them again.
    you should be able to get the 1920x1080 out from the laptop into the external display, its just a settings problem.
  • Ekse Oct 03, 2009
    123test
  • Ekse May 15, 2010
    hello, please click on the accept button.
  • 448 Answers
This only happens if the KVM switch doesn't support transmitting 1080p or 1080i signal.
The resolution 1024 x 768 indicates that the KVM switch supports transmitting only 720p signal.
How do i mute the hp w2338h
Open Control Panel and from there, click "sound". Under playback, you can see the audio devices connected and you can right click on them and select enable/disable.
Apr 10, 2014 | HP W2338H Monitor
Computer not recognizing HDMI, but recognizes VGA
i would try go to - graphic properties(options) and try to browse for display options, if nothing's there than browse for update for your graphic card drivers on laptop producer website or hdmi drivers
Feb 11, 2014 | HP Computers & Internet
Hp w2338h too dark
THAT IS THE GAME ITSELF ALSO YOUR GRAPHIC CARD MAYBE NEED A CONFIGURATION FRO GAMES
Apr 11, 2012 | HP W2338H Monitor
Can't get full screen
If you're wanting to resize your desktop resolution then see my tip here: http://www.fixya.com/support/r6774994-resize_desktop_background
Apr 18, 2011 | HP W2338H Monitor
My monitor hpw1858 recommends settings 1366x768-60Hz, I can't find it in the PC settings . In options Screen resolution dosen't exist this setting. Therefore, please advise me on what to select, because I...
  1. This document describes using and adjusting flat panel monitor model w2338h.
Installing drivers Install the software from the CD, or download them from the Internet as follows: Installing drivers from the CD To install the monitor driver from the CD:
  1. Insert the CD in the computer CD drive. The CD menu appears.
  2. Select the language.
  3. Click Install Monitor Driver Software .
  4. Follow the onscreen instructions.
  5. Restart the computer.
  6. Check that the proper resolutions and refresh rates appear in the Display Properties window in the Control Panel.
Installing drivers from the Web To download the latest version of drivers and software files from the HP Support Web site:
  1. Go to the HP Support Web site
  2. Select the country/region.
  3. Select Download Drivers and Software .
  4. Enter the model number of the monitor, for example w2338h . The software download pages for the monitor display.
  5. Make sure the system meets the requirements given.
  6. Download and install the driver and software files by following the steps on the screen.
  7. Techbelkin please rate me
Nov 03, 2010 | Computers & Internet
I HAVE COLORED LINES ON THE RIGHTSIDE OF MY MONITOR THAT WON'T GO AWAY AND ARE BECOMING WIDER AND MORE OF THEM, ITS ONLY A YEAR OLD. IT'S A HP w2338h MONITOR.
mcdevito75 here, Double check all connections at your monitor and computer. On the monitor press the AUTO button, this will re-set the factory settings. If this fails, I would bring the monitor to a Staples, Radio shack, Best Buy for testing, Monitor could be going bad even at a year old, also check any warrantees on the monitor.
Jul 22, 2010 | HP W2338H Monitor
I have a HP w2338h monitor that goes blank
It is most likely a bad power supply... I have had aboit 4 diff monitors do this to me... most common is under rated capacitors in the internal power supply... some times there could be a black light going out witch causes higher current draw on the power supply ( witch can take out the caps, fusses, transformers ( caps and transformers when they get week and bad can cause the buzzing sound ( on some times with a radio near buy then the monitor is acting up with blanking out and buzzine the radio will pop and buzz as well witch is a sign that there is arching going on IE. caps and transformer are most common for that )))
hope this info helps
kc7wzl
Jun 23, 2010 | HP W2338H Monitor
I have the HP w2338h monitor. when i listen to
Hi there , Go to your PC settings , and Try turn Screen saver off , aswell as Sleep off... it is in your PC settings.
Good luck
May 22, 2010 | HP W2338H Monitor
Only get very faint sound out of my speakers, even though the sound bar in the lower right hand corner is at max
And what about volume adjustment in the monitor itself? Is it also adjusted to a higher level?
Dec 23, 2009 | HP W2338H Monitor
Recommended resolution
Most likely your video card will not support that kind of resolution through that monitor. I did not see where you mentioned the card or not, but it takes a good graphics card to push that kind of resolution.
Oct 28, 2009 | HP W2338H Monitor
Computers & Internet Logo
558 people viewed this question
David Payne
David Payne
