I have an HP laptop and the charger for the laptop wont charge it anymore. What could be the problem?
    Sergeant:
  • 168 Answers
The charger could be broken or the connector in the laptop could be the cause. Most chargers have a light that tells you if it is working or not. If you have access to a volt meter, look on the power supply for the output.
Posted on Sep 29, 2009
  • 106 Answers
If u touch the charger while charging it must be hot after 5 minutes if it starts charging; if this happens there is no problem with your charger ; if it is over heated at the instant it is plugged there's fault in charger replace it
Laptop runs on battery and charges ok,but wont run just on the charger-hp f700
Charger go true a lot of power voltage regulators and in the end is not powerful inought to power loptop without battery, same capasity neaded to help maintain stable curent.
Feb 17, 2014 | HP Compaq Presario F500 F700 and G6000...
HP 584037 battery not charging anymore, the yellow light turns white or switch off after just 20s - and the PC does not work either just with the charger. Still , the charger delivers normal tension -...
sometimes you can take the battery out and put it back in (Re-seat Battery) or the cord on chrger could be broken inside near the plug some computers wont recognize and deactivate charging if there is a short in the charger could just be the battery is bad if it has been progressively getting worse
Jan 01, 2014 | Computers & Internet
Its plug in but battery wont charge
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Nov 28, 2012 | HP Compaq nc2400 Notebook
Battery wont charge
Please check the battery charger. Otherwise, I had one of this HP Mini 1000 replaced by HP with the same problem, the Mini gone complete dead, no charging or turn on.
Apr 07, 2012 | HP Mini 1000 Netbook
Targus charger wont charge laptop when laptop on?
The laptop does not recognize the charger due to a different wattage/ amperage or is not powerful enough to charge the laptop while the machine is powered. I have seen many problems with hps/compaqs and the Targus Universal Charger and recommend the HP universal charger for those models instead.
May 23, 2011 | HP Compaq nw9440 Notebook
My laptop wont charge so i brought a new charger but it still wont work.
It could be the battery... they tend to wear out over time. If you run the laptop with the charger plugged in, it works fine, right? It just won't hold the charge?
Aug 31, 2010 | HP Compaq Presario CQ61420us Notebook
Philips X50 charging problems
1st remove Battery after few min insert battery and connect charger Then power on laptop.If not on check Power Mosfet or Power ic.
Jun 27, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Wont charge anymore? hp dv 4000
Does the computer acknowledge when you plug it in? Are there any status lights indicating AC power? If not then the electrical contacts in the laptop power plug may have broken. If you are not under warranty, you could take a peak inside the case where the connector is and possibly fix it with a soldering iron. In the meantime I'd backup any important data.
Jan 24, 2009 | HP Pavilion dv4000 Notebook
Computers & Internet Logo
138 people viewed this question
David Payne
David Payne
