Question about Epic Exercise & Fitness
I have a epic t 60 treadmill the display will light up but the motor will not start. Is there a fuse that that might need to be replaced.
  • 40 Answers
Probably a bad motor control board, possibly bad connection, less likely but still possible is bad console. Another possibility is that it's in demo mode and you forgot to attache the safety key, but anyone who has had this treadmill a while would notice that.
Posted on Sep 29, 2009
Why doesn't it start?
epic view 550 treadmill video 2 - YouTube
? 2:08
https://www.youtube.com/watch?v=fSIuoh_bZN4
Mar 9, 2010 - Uploaded by Epictreadmillowner
epic view 550 treadmill video 2 ... ICON Canada doesn't really support this and the independant technicians ...Epictreadmillowner 1,181 views.
Epic View 550 Treadmill Review - YouTube
? 3:02
https://www.youtube.com/watch?v=kNiFOcrV9r4
Nov 29, 2012 - Uploaded by Treadmill Review Guru
... .com/epic-treadmill-reviews/epic-view-550-treadmill-reviews-ratings/ ... Nordic track has the track and google maps by i-fit you can download and run anywhere ... The review says it doesn'thave the track/lap but it does.
Epic View 550 Treadmill video 3 - YouTube
? 1:59
https://www.youtube.com/watch?v=YjqgZS-1qlw
Mar 11, 2010 - Uploaded by Epictreadmillowner
Epic View 550 Treadmill video 3. Epictreadmillowner ... I have had 3 different console units, and now the tv doesn't work either!
Epic View 550 Reviews - MyTreadmillReview.com
mytreadmillreview.com/epic-view-550-reviews-2
Jan 27, 2016 | Epic View 550 Treadmill
EPIC 400 tread mill starts but slows down &blows breaker moter run fine with no load belt backed off re set speed sensor changed power cord pluged .in to circit board ran fine for 2 hrs then stoped
motor brushes are bad. when they wear out, the motor loses torque and draws more amps. they can be replaced fairly easily once you get the motors out.
Oct 03, 2015 | Epic 400 Mx Treadmill
EPIC VIEW 550 MOTOR WONT START
Please post the specific model # found on the model/serial# decal on the frame of the machine (EPTL....)
Who replaced the drive motor on the machine, and for what reason? Did the new motor ever function when installed?
Nov 24, 2013 | Epic View 550 Treadmill
Treadmill KETTLER PACER have error E7 when starting run. How to eliminate it?
see the following indications and fix it. God bless you
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Nov 28, 2012 | Kettler treadmill Pacer
My Epic 425 Mx motor won't run even though power is on and display works
try to RUN the software calibration for diagnose, troubleshooting, fix it.
2) LUBE THE deck belt , this happen because the lack of maintenance schedule, maybe the deck is worn and need replace it. see the video and picture
3) lube the rollers bearing too very well.
4) test the input voltage motor, if there are the motor NEED repair,tight any wires connector for loose
5)measure the output voltage board, for input voltage motor, if there are NOT the board is faulty. use the DVOM OR VOM in both cases.
see the block d, tight any wires connector or wires looses
God bless you
Jul 29, 2012 | Epic 425 Mx Treadmill EPTL88105 !
EPIC TL 2200 wont start
1) Test the fuse or c. breaker see the diagram attached.
2) Test the c. breaker from your hourse, or blown fuse
3) Test the main switch of the treadmill see how to do it
4) Test the voltage input motor, if there are voltage the motor need repair.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Jun 08, 2012 | Epic Exercise & Fitness
It won't start
Make sure there is power at the outlet.
Check that the breaker is set (on/off switch beside the power cord.)
Attach the magnetic safety key, the console should power up.
If not, unplug the machine from power, remove the motor cover, check that the wires are all secure. Check on the electronic motor controller fuse. If it is bad, you can replace it and try again. If it blows the fuse or breaker again, you may need a new motor controller PCB.
Dec 18, 2010 | Shopzeus.com EPIC T40 Treadmill with 68"...
Epic is sending me a replacement motor for my 425MX. Is it easy to change out the old one? Any secrets I need to know before starting?
You will need to loosen the rear roller off 8-10 turns on both sides to reinstall the motor drive belt...
Dec 14, 2010 | Epic 425 Mx Treadmill EPTL88105 !
Exercise & Fitness Logo
281 people viewed this question
Top Epic Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
