Question about Gateway MT6840 Notebook
Power button on laptop is completely pushed in/caved in
  • nik_nik27 Sep 29, 2009
    This is a continuing problem. Should I use a safety pin each and every time?
  • 106 Answers
Insert safety pin to the side of button and slowly try to pull it out
Posted on Sep 29, 2009
Who sings the song called "The Witness"
The Witness Song - Nick Cave
www.nickcave.com/lyrics/nick-cave-bad-seeds/good-son/witness-song/
(Please let us know if this answer is helpful by clicking the button below, thanks!)
The Witness Song Nick Cave
Apr 13, 2017 | The Audio Players & Recorders
Acer AM1100-E1304a do not start.
Try removing the battery. It may be the battery is eating all the power that the supply can produce, leaving nothing to run the computer. That could happen with a shorted cell or a completely dead battery. IF the power supply you are using is the correct one for your laptop.
Oct 27, 2014 | Computers & Internet
Acer extensa 4420 shuts down right after you push power button
sounds like it doesn't have enough power, is it completely charged? you may want to make sure you're getting power from the charger itself.
Jul 02, 2012 | Acer Computers & Internet
Start butom is not reacting on MSI notebook
Remove the bezel above the F keys and try manually pushing the power button with a penhead. If still no power up then either your charger is bad and the battery is completely drained or the board may be fried.
Aug 10, 2011 | MSI A6200-059US Laptop
I am trying to reset my toshibe m45 s165 to its factory settings, but when i try the whole press "0" and power at the same time, the laptop keeps turning off since im holding the power button,...
Do not hold the power button down while pressing the "0" key - it'll shut the computer off again. You just need to push it once to turn the power on and then hold the "0" key immediately after you push the power button on - just like turning on the laptop, but this time you're holding the "0" key down.
Feb 05, 2011 | Toshiba Satellite M45-S165 Notebook
No power. All power cords checked and tight. With
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Jan 06, 2010 | Gateway MP6954 Notebook
T30 Intermittent Booting Problems - Depending on screen angle
It is issue with the screen cable connection. Replace it. or it is getting chaffed and causing issue in proper signal and power to the screen. It is hardware issue.
Apr 24, 2009 | IBM ThinkPad T30 2366 Notebook
Dell laptop
Remove the CD Drive from the computer , disconnect the charger from the computer , flip the laptop and remove the battey, with the battery disconnected , push the power button for 10 secs to release the flea power , open the memory slot , remove both the memory sticks and then put back only one of the memory stick and then try restarting your computer. If it gives out the msg amount of memory changed , then Strike F1 to continue...
Apr 21, 2008 | Dell Latitude D600 Notebook
Hp 4600 laptop
hmmm...try it with the battery removed only on AC power..
Feb 28, 2008 | HP Pavilion dv6000z Notebook
Gateway MT6840 Notebook Logo
113 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
