Question about Konica Minolta PagePro 1350W Laser Printer
Error light I have a konica minolta pagepro 1350w and the error light is on but I don't know what the problem is, nor how to find out what the problem is. isn't there a way to get the printer or computer to display the problem
  • 7 more comments
  • Anonymous Jan 06, 2008
    Cleared paper jam
    deleted print job out of que
    turned printer off, turned back on
    rebooted printer and computer
    uninstalled and reinstalled printer cartirdge
    still gets error message
  • Anonymous Jan 11, 2008
    error light flashing.
  • Anonymous Jan 28, 2008
    the roller that feeds the paper will not pick up paper after I cleared the paper jam.
  • reign211 Feb 04, 2008
    I am having a problem which points to the paper tray. i load paper and it doesnt feed. the manual states that the slow blinking error light = load paper and i am still not getting anything. is there a downloadable service manual
  • poppadoc Apr 04, 2008
    Error light with "Non Moniko Toner" alert. Konico PagePRo 1350W
    While evaluating I noted that there are two "spring" contacts on the right side of the drum/toner compartment. The left of the two springs was dislodged from its tract. I was able to gently tease the contact wire "hook" back into the tract and my problem has resolved.
  • dmdiehl Apr 07, 2008
    My error light is on....usually I just turn off the printer and shut down computer and start again and it is fixed..this is time is is not wokring.
  • Anonymous Jun 11, 2008
    The error light started falshing and won't go off. There is no way to determine what the error is. We have two of these; I changed out toner (which broke and went everywhere!), even when I switched printers, same problem! What's up with that? Not a happy customer.
  • willy McCoy3 Jun 12, 2008
    The paper will not feed, and the light is a solid green. It just stopped working a few days ago.
    thanks
  • Anonymous Aug 20, 2008
    our printer's green light was on and the orange error light light was flashing rapidly which indicated a "non-minolta" ink cartridge- even though it was. Reviewing all of the posts, we looked at the wires suggested here (on the right side inside the printer) and they appeared fine. We noticed that the 3 copper contacts that rub across the chip on the toner cartridge were bent and we gently straightened out the wires. Reinstalled the cartridge and it works perfectly and the error light is gone. thanks for this posting to tell us to look at the wires!!
Xxxxxx
Posted on Aug 20, 2008
You have installed a refilled cartridge without changing the chip on the bottom of the cartridge. Your error light will flash and also upon starting your computer, you will probably get an error screen saying the bi-directional connection is disabled. The printer should still work, but will be slow because it recycles between each page. My error light has been flashing for some time, but when I send a document to the printer, the error light stops flashing and the printer prints. After the print job is done, the error light resumes flashing. The only real solution is to replace the chip on the toner cartridge with a new one.
Posted on Jan 12, 2008
3 Suggested Answers
SOURCE: KONICA MINOLTA PagePro 1350W
You have to connect it to exactly the same USB port. For every time you connected to a different port compared with the last one, a new copy will be installed.
Chip reset device for Konica Minolta Bizhub and CF imaging units
http://www.chipreset.eu
Posted on Aug 23, 2009
SOURCE: Konica Minolta PagePro 1350W Laser Printer won't print anymore
Konica Minolta PagePro 1350W laser printer. can mode five in to wi fi or wire leas
Posted on Jul 20, 2013
Konica minolta pagepro 1350w not feeding full page but get stuck at half page.
check the size of the document make sure the print drivers and the printer are correct and matching you might also need to replace the fuser unit or the transfer roller and or image unit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 16, 2014 | Konica Minolta PagePro 1350W Laser Printer
Where can I download Konica Minolta Pagepro 1350W driver for Windows 7 64 bit?
Go to this website
http://download.cnet.com/KONICA-MINOLTA-PagePro-1350W/3000-2116_4-155429.html
Oct 04, 2010 | Konica Minolta PagePro 1350W Laser Printer
Konica minolta page pro with windows 7
I looked at the manufacturer's web-site:
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productname=1350W
and you are correct -- there are drivers for 2000/XP, and for 95/98, but nothing for Vista nor Windows 7.
Find an old computer running Windows 2000 or XP, and connect the printer to it, and "share" the printer across your home-network.
Apr 07, 2010 | Konica Minolta PagePro 1350W Laser Printer
Can i get drivers for konica minolta pp 1350w
download.cnet.com/KONICA-MINOLTA-PagePro-1350W/3000-2116_4-155429.html -
Nov 17, 2009 | Konica Minolta PagePro 1350W Laser Printer
Pagepro 1350W will not print. Ready light on. error light blinking
You have to see how the led is blinking and to compare with the table that explains every blink what means. If you don't have this table, contact me and I'll send it to you.
Aug 09, 2009 | Konica Minolta PagePro 1350W Laser Printer
Konica Minolta Pagepro 1350W error light flashes and will not pri
Jul 06, 2009 | Konica Minolta PagePro 1350W Laser Printer
Need drivers for vista on pagepro 1350w
I clicked on the 'Konica Minolta PagePro...' link next to this and Vista drivers were offered...
Jun 14, 2009 | Konica Minolta PagePro 1350W Laser Printer
Konica minolta pagepro 1350w error light won't stop flashing
pleas install status monitor, it will tell you what is wrong
Jun 20, 2008 | Konica Minolta PagePro 1350W Laser Printer
Konica Minolta PagePro 1350W Laser Printer Logo
1,605 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
