Question about GE WSXH208A Front Load Washer
What would cause the concrete weight on the tub to disintegrate (washer is 3 years old)?
  • GE Master
  • 2,605 Answers
well it sounds like this washer has suffered from extreme vibration. that can be caused by several things. 1) non "HE" detergent being used. 2) shipping bolts not removed soon enough after unit was used. 3) continual and consistent overloading. 4) a very unstable floor, inefficient pedestal. 5) shock absorbers broke and gone unattended too long after separating from tube and or base/chassis.
bottom line is there are many possible causes of the counterweight breaking apart, (even loose counterweight hold down fasteners) these are just a few.
now the good news...
as long as no further damage has occurred, these units are a dime a dozen at used appliance depots and you should be able to locate a relatively inexpensive replacement part.
hope that helps, I know it sucks...no matter if it's 3yrs. or 13yrs old !
good luck
Posted on Sep 29, 2009
On the final cycle where it says its wringing the cloths and draining the water the washer is making a very loud fast clicking sound as it runs. what could be causing this?
A hose might have become un-clamped at the rear of the washer or something might be loose on the tub(such as one or more of the concrete stabilizers). I have seen these formed pieces of concrete shatter due to vibration/age. Remove the top cover and carefully inspect the forms(at the top rear and front top/bottom of the tub) for cracks and missing pieces and looseness. Run the washer with the top removed to confirm or better diagnose.
Aug 24, 2015 | Frigidaire ATF6000ES Front Load Washer
I moved my Kenmore 400 series washer into our new house and now it makes a loud banging noise, and vibrates real bad on the spin cycle. It shakes the dryer beside it it's so bad. If I sit on the washer it...
THERE S A THIN NOT REAL LARGE CONCRETE BLOCK INSTALLED AT THE FACTORY UNDER THE MACHINE. A STRAP MAY HAVE LOOSENED OR BROKE, AND THE BLOCK MAY BE MISSING. ANY SMALL YET HEAVY WEIGHT WILL WORK.
IT APPEARS YOUR BOOTY MAY BE ACTING AS THE COUNTER WEIGHT!...IF NOT,,CHECK THE CONDITION OF THE TRANSMISSION COUNTER WEIGHT (AT BASE OF TUB UNDERNEATH)
Nov 04, 2013 | Washing Machines
When washing towels the load starts banging...not overloaded and repair service can't find the issue.
sounds like a broken shock,or balance spring!! possibly loose concrete weight on tub
Mar 15, 2013 | GE WSXH208A Front Load Washer
Whirlpool cabrio loud noise
Check your bearings. This post will show you most of what you need to know about your bearings:
http://www.squidoo.com/how-to-replace-bearings-in-a-whirlpool-cabrio-maytag-bravo-or-kenmore-oasis
Nov 06, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
How do you replace the springs on the front load washer? The tub is so heavy.
I suspect the weight is due to the lump(s) of concrete on the top of the drum frame (?). You could try removing it/them first.
Good luck! John C
Oct 08, 2011 | GE Washing Machines
While washing heavy load (towels) spin cycle became very loud and sounded out of balance. After cycle finished, noticed several small pieces of white material. Washed a light-weight load next; same loud...
I had exactly the same problem, sound and everything. I just pulled the front off the washer and discovered that I half mooned shaped, big hunk of concrete was broken in half and hanging down rubbing who knows what. I'm sure it's just a weight to help make it stable while spinning. I don't know if the broken concrete is a result of another problem or not. I'm going to try to find a replacement and install it myself and see if it's fixed. I can just hope.
Nov 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
After the clothes have spun dry, a small amount of water accumlates in the tub; generally 1/4 inch or so. Why BTW, I'm not sure that I've selected the correct model. Our washer is about 3 years old.
If draining into laundry tub, chances are water is siphoned back into washer due to laundry tub slow drain.
Very long drain hoses( such as 10+ feet) will also cause this.
Nov 05, 2009 | Fisher and Paykel IWL12 Top Load Washer
REALLY NOISY
posted by mikey b from st Helen's. after experiencing a similar fault on my wt741.i set about determined to find the cause of the noise.On spin,particularly fast spin the washing machine was making a horrendous vibrating banging noise.i eventually traced the fault to the lower concrete weight which simply needed tightening. which is held on with 4 10mm bolts.the weight can be easily accessed by turning the washer on its side.support the outer drum with a small block of wood against casing before lying on its side. you will need a 10mm spanner to get on bolts.hope this was helpful !
Jan 15, 2009 | Siemens WFXD8400UC Front Load Washer
Banging while spinning and disintegrating gasket
Most likely not the drum bearing on this one.
I believe that your inner basket support has failed. It's a common problem on 4+ year old duet washers. This is by far the most labor intensive repair that can be done on the duet washer. You will need to tear down the machine for this repair. Expect it to be a four to eight hour job depending on your level of skill.
The basket is under lifetime warranty. The new basket will come w/the basket support already attached to it. Stupid as it sounds, You can't buy the bolt-on basket support alone, You need the entire basket! wtf?
The front section of the outer tub is supposed to have a 10yr warranty. Being that the tub was damaged by the basket, They may or may not warranty the parts.
Do a search on fixya. There is a guy from MA that has a complete set of pictures and info on the rotted/broken basket support.
Jan 02, 2009 | Whirlpool GHW9100L Front Load Washer
GE WSXH208A Front Load Washer Logo
230 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
