Question about GE Profile Advantium SCB2001KSS Stainless Steel Electric Single Oven
Advantium SCB2001KSS clicking or ticking noise
I had a power failure the other night. The Advantium had no display. I turned off the breaker for a minute, turned it back on and the oven started working.
It still works fine, but when cooking is finished there is a clicking noise. It's not that loud, and only clicks 3-4 times and stops. The noise seems to be coming from the right side of the unit, but I can't be sure. It sounds like some sort of thermostat relay clicking, thats the only thing I can compare it to.
Thanks.
eagle338
  • 4889 Answers
SOURCE: F3 Error
This is due to a Defective control board..You have to get it replaced..
Posted on Oct 22, 2007
SOURCE: The GE Profile Advantium SCB2001KSS
Well right now I'm looking for how to just turn off the beeping. Our GE Profile isn't the same model, but it does the same thing. Found a fix that works, but we have to use it every few months when the keypad locks again. Here's the solution to getting it running again:
unscrew and take off the faceplate exposing the motherboard and chips/wires. unplug/unsnap the wide, flat power cord attached to the digital face. Take a pencil eraser and use it to clean the metal contact points where the power cord meets the display (the ones that are visible once u unplug the cord). Put it back together and tadaa... it works again.
My guess is that it gets some sort of buildup over time that u just have to clean off. Anyway, good luck. Hope this helps
Posted on Jan 13, 2008
MicrowaveSvc
  • 9125 Answers
SOURCE: GE Advantium stopped working completely...indicates no power but it is on.
It may be that your high voltage diode or capacitor has shorted.
The fuse is usually located behind the grille, on the floor of the oven behind the control panel, between the door switches, or on the filter board near where the cord comes into the unit.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even though it is bad!)
http://www.gallawa.com/microtech/xformer.html
To check the high voltage parts, you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Posted on Dec 18, 2008
Just had this same problem w/ my ZSC2001FSS. F3 code indicates that the keypad is faulty. Luckily, mine was still under warranty, so the GE repairman just ordered a new front control panel. Judging from the number of complaints, this is a common problem with this model. Repairman did suggest I spring for the extended service contract on the oven, because any little problem could be expensive down the road. If it helps, the parts for my repair are listed below.
Parts ordered:
WB07X10680 - Control Assy
WB27X10395 - PCB LED Assy
WB27X10396 - Selector PCB
WB27X10397 - PCB Control Assy
Posted on Sep 22, 2009
  • 478 Answers
SOURCE: my scb2001kss ge advantium no longer heats. it
check breakers for oven one side could of tripped if everything else works but the heat this is a normal problem the only other thing could be is that the controles are not working
Posted on Jan 26, 2010
Bread will not brown on bottom
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 19, 2011 | GE Profile Advantium SCB2001KSS Stainless...
My scb2001kss ge advantium no longer heats. it turns on and everything else works, but heat
Jan 26, 2010 | GE Profile Advantium SCB2001KSS Stainless...
Have -F3- on the screen and nothing works
**FIRST; shut off the breaker or unplug the unit before going any further please**
"F3" on most GE ovens describes a fault with the oven sensor or sensor circuit. Ohm out the sensor. It should read approx.1100ohms. @ room temperature.
The other possible faults are a bad solder on the control, a pinched or severed wire from control to sensor.
Having said all that, 99% of the time, its' a sensor. most common GE sensor is part # wb21x5301.
hope that helps
good luck
Oct 01, 2009 | GE Profile Advantium SCB2001KSS Stainless...
GE Profile Advantium oven (stainless steel)
spray a little oven cleaner on a wet rag and wipe. Rinse really well afterwards. Do not spray directly in oven. It could get in the holes.
Jun 10, 2008 | GE Profile Advantium SCB2001KSS Stainless...
The GE Profile Advantium SCB2001KSS started beeping and displaying error code F3. I was able to set the time after holding one of the controls in for 3 seconds, but it reverted to the beeping and F3 error...
I know what you mean. I was cooking with this appliance tonight and suddenly it displayed an f-3 code. My advantium oven is less than 8 months old. Not sure how this happened or how to fix the problem. In order to sleep tonight (the constant beeping) I had to shut power off at the breaker pannel. Is this representative of the the type of quality that GE stands for???? I am sooo frustrated. I cook with my advantium oven all the time and love the dual abilities of this appliance. Like I said this is brand new and to have the f-3 code which apparently (from what I read) is a failed key pad. I am very dissapointed and am begining to think about pulling my stock from this company!
Oct 19, 2007 | GE Profile Advantium SCB2001KSS Stainless...
F3 Error
Oct 15, 2007 | GE Profile Advantium SCB2001KSS Stainless...
Can't make my oven work after a power loss - GE Profile Advantium
check voltage to oven. if thats ok your control board may be shot.
Feb 01, 2007 | GE Profile Advantium SCB2001KSS Stainless...
GE Profile Advantium SCB2001KSS Stainless Steel Electric Single Oven Logo
97 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Steve Allison
Steve Allison
Are you a GE Oven Expert? Answer questions, earn points and help others
