Question about Samsung RS2534 Side by Side Refrigerator
RF266ABPN French Door Firdge/freezer Ice maker sensor
There is what appears to be a sensor that comes from the right front side of the ice maker. It was hanging down unsupported. There are several built in "hooks" on the underside of the ice tray. I wound this sensor through these hooks in what I "think" is a logical installation but I really don't know. Since then it has not made ice correctly. Now it seems it is over filling the tray. The manual does not cover this part or have any valuable information regarding the ice maker. I can find no information about the ice maker online. (The sensor is white and connected via two wires to the ice maker.)
I found David's solution very helpful and I'll just add to it. Take out the top freezer door-- it just slides out and up. I had a bunch of stuff on the little shelf on the actual door and I had to take some of it off first. The big bottom drawer stays on. The little foam piece was on the floor of the freezer so I picked that up and can see how the little sensor part fits into it. Next, I put a chair next to the open bottom drawer, sat on it and leaned back onto and into the big drawer. I had to torque my head to actually get right under the ice maker. I am 5'5" so I don't know the heck David did it! Anyway, there is a little "slot" next to the last ice cube mold closest to the door. This is where the foam piece goes in. The slot where this piece goes has some raised lines sticking out on each side-- I wouldn't call them brackets and the foam thing doesn't stay in well by itself. However, on the right side of the ice maker, near that last cube, is a little hook. So I slid foam piece up with the sensor tucked in, facing the ice cube mold. I wrapped the tail/wire around the bottom of the foam piece and also the hook, so that it kind of holds the foam piece up in there, kind of cradling it. That was my solution, we'll see if it works!
Posted on Jul 28, 2013
5 Suggested Answers
davtom81
SOURCE: I believe, the ice sensor
Haven't been able to find a reasonable diagram anywhere. Hope you still aren't having this problem but here's what I learned when repairing mine.
There are 2 pieces that reattach the sensor. There is a foam-rubber piece that the sensor seats into. There is a channel in it for the wire. This assembly is held into place by a plastic bracket. Before getting in there, make sure you put the three together to see how the fit.
Pull out the top drawer of the freezer. Place the sensor back into the foam-rubber piece. Wiggle your head in to the freezer looking up at the bottom of the ice maker (I'm 6'4" 220, wasn't easy). The foam-rubber piece will slide up behind and underneath the last cube, closest to the door, such that the sensor is making direct contact with the cube. You can then slide the plastic bracket into place. There is a small pin like protrusion on the bracket that will hold the whole thing up. You may alternately try putting the whole assembly in together, but I had worse luck trying this.
When you've got it, its still going to be kind of loose, explaining why it fell out to begin with. Really poor design here. Anyway, should be able to give it a tug and it won't come out. Make sure the wire for the sensor isn't protruding anywhere that it will snag. From now on, I'll be real careful that ice doesn't build up and rip this off again.
Posted on Nov 06, 2011
SOURCE: My samsung rf265abwp ice maker is over filling the ice tray, the wiring harness is hanging down, I don't know where it attatches and I suspect this is what is causing the ice maker to malfunction caus
I have the same problem, has anyone figured out how to fix it?
Posted on Jan 06, 2013
SOURCE: My Samsung French Door RF266ABPN has a warm
I have read that if you unplug the unit and plug it back in again, it will "reset" it. I would wait 15 or so minutes before replugging just to be sure. Of course, this solution doesn't preclude the problem from happening again - sounds like a manufacturing defect to me.
Posted on May 21, 2009
SOURCE: I Have a rf266abpn and the icemaker front plate f...
I know this is a little old, but I had the same problem. It turns out that under the Ice tray, there are some plastic clamps that you can set the hanging hose onto, along with a hook that the thermostat (harder thing) hangs on.
Posted on Jul 12, 2010
How to remove DA97-12317A ice maker from samsung RF263BEAESR? I've unplugged the harness, and depressed the clip but it won't pull forwards. Do you have to pull hard?
The instructions above are wrong. The ice maker will not come out as instructed. There is a tube coming out of the back of the refregerator that passes in and around the bottom of the ice maker that won't let it slide out. If you could take the bottom panel off the ice maker, you will see the tube. To replace the ice maker, the entire enclosure may have to be removed.
May 03, 2014 | Samsung RF265AA Bottom Freezer French Door...
Ice maker leaking into ice storage tray
start with hose replcement buy parts at sears water hose to main ice maker might have crack in it or the stopper is bad get in ther look close with brite light
Oct 14, 2008 | Refrigerators
The ice maker is not making ice. The water filter has been replaced and there are no trouble indicators from the lights on the front of the unit. The house has a water softener for whole house service.
Hello
Where the water comes into the ice maker.Be sure it is not frozen up.If it is, remove ice with a hair dryer.
Also,reset ice maker by lifting full ice tray arm and putting it back down.
Jun 05, 2011 | Maytag MFI2266AE Side by Side Bottom...
Our jenn-air side by side refrigerator with ice-maker has a problem. Quite often it makes a buzzing sound which seems to be more frequent than is normal. There is water inside the freezer which solidifies...
Good day,
You'll need to isolate the problem. Shut the water off to the machine to eliminate the ice maker as an issue. Clean up any mess left over and restart the machine with the ice maker set to the off position.
Run for a few days to test the quality of the cooling capacity of the machine. If it tests O.K. then the ice maker situation can be addressed.
May 10, 2010 | Refrigerators
Ice build up in freezer and temp in fridge section not very cold
just needs to be defrosted ice is blocking the vent for the bottom defrost it and should be good
Aug 28, 2009 | Samsung RF265AA Bottom Freezer French Door...
Amana French Door Bottom Freezer
see if there is any ice caught within the ice maker itself preventing proper cycling of the ice maker. if not pop off the white cover to the ice maker(theres small **** in the cover on bottom right corner of white cover to insert a ***** driver and twist the cover will pop off. look into the center of the main plastic gear, there should be 2 "tabs" holding that gear in place . as if you were to push gear on and the tabs would keep it in place.( reason i mention that it is/was a problem with the ice makers hat the gear would break and it was very noticeable looking into the center gear).if not, theres a detailed trouble shooter for the ice maker behind the kickplate(maybe taped up under front corner under cabinet) it will tell you points to check for power and jump out if necessary
Mar 12, 2008 | Amana AFD2535DES French Door Refrigerator
Optical sensor or valve problem
Your ice maker has an automatic shutoff. The ice maker sensor passes a beam from one freezer wall to the other, automatically stopping ice production when the storage bin is full. When you open the freezer door, you should see a red light on the top right freezer wall.When the freezer door is open or the ice storage bin is removed, the sensor cover or "flipper door" on the left wall of the freezer stops the ice maker from producing ice by blocking this sensor, When the beam is blocked, the red light on the right will blink twice. This is normal operation. as for the blink twice and pause I'm still checking on that. Make sure the water flow is coming from the solenoid valve located on back and bottom of refrigerator to the ice maker. Check the solenoid to see if the magnetic field is pulling the internal plunger open when ice maker ask for water. That can be checked with a multi meter at the wireing going to the solenoid and if the ice optics are telling the tray to fill voltage should be present. Insure that water supply is not restricted before it comes to the solenoid , like a bent line or clogged piercing valve.  Check that an ice cube is not jammed in the ejector arm of the ice maker. Remove jammed ice from the ejector arm using only a plastic utensil so the ice maker is not damaged. Call toll free in USA and a trained consultant will be happy to assist you. 1-866-698-2538
Oct 22, 2007 | Whirlpool GC5SHEXN Side by Side...
Samsung RS2534 Side by Side Refrigerator Logo
368 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
