Question about InFocus ScreenPlay 4805 Multimedia Projector
We have a brown line that is appearing on the right side of our screen. does this mean our bulb is going bad??
  • 74 Answers
It sounds like you light pipe has collapsed.
Posted on Sep 29, 2009
I have sanyo projector model PDG-DSU20E. Few white spots appeared on the right side of the screen. Gradually the spots has filled the right side about 1 feet is width till bottom of the screen. Now few...
1,white spots appeared on screen,means the DMD is broken,you need a new DMD.
2,the projector running off after only a few minutes,means the Inductor (Sensing element),near the Color Wheel. Use a cotton swab moistened with alcohol to wipe the Inductor.
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD,
motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Sep 11, 2013 | Optoma PRO250X Projector
Tip
Fuel line routing for ryobi,poulan and sears trimmers
hello sir, fuel line routing for ryobi,poulan trimmers, looking at machine from left side,front green line from tank to bottom of port on primmer bulb. rear line from tank which has filter inserted through tank with small white ring pushed up against tank & filter fittings, goes to port at bottom of carburetor.top line from primmer bulb goes to top port of carburetor. that is the way they go on.it is important to make sure you have the same fuel line I.D. and O.D. are very important! also if old line dissolved it will get in carburetor and clog ports & small screen inside.clean inside of carburetor with carburetor cleaner & air pressure. to get your parts and numbers ,go to mtd parts.arinet.com, parts,791-683398,fuel line assembly.hope this helps
.hello sir,routing fuel line for craftsman,homelite, trimmers,fuel tank over engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carburetor fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carburetor fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carburetor fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carburetor when replacing fuel line it is very important to use the same ID and OD line,when the lines dissolve small pieces will get in the carburetor clogging small passages and screen,it is advisable that you clean out carburetor and use a new filter.hope this helps, DON'T FORGET THE 4 THUMBS UP,,,,any comments welcome,thank you.
on Feb 27, 2010 | Garden
2003 Jeep liberty right front turn signal
why skip RR lamp? what does IT DO? be like 1st 1st look.
dim, out, fast?
the rapid is talking to you
it means current is wrong,
shorted, or open lines. to the right.
its the wiring
if the bulbs are like 1157 brass base bulbs
why not replace them first , they can short inside,
asking online for guessing is silly, why listen to 10 examples for this.
but is cut wires.
shorted wires.
keep i mind the blinker asks funny for both opens and shorts
its a feature, that.
low current or too much.
the acid test is connect 2 TEST bulbs in parallel to the multi-function switch output right side,
blinks ok now, bingo bad lamps or bad wiring, from there to the right side.
if the hazard fails you never said????
if rigth front is dim or dead the bulb is blown or shorted
if new bulb there , then the wires are shorted.
to it.
the only help on line worth squat is how to test and use your meter.
you can, check for voltage
you can check continuity on that line (its just 1 wire)
and check for shorts on that wire to ground (lamps pulled right side to do that, lamps read 0 ohms cold)
look for collision damage RF? behind lamp sockets?
be first.
in my book.
looking is always first. sure.
I have your SM book open now, chapter 8w-50
the haz/blink module has just 2 pins, left and right out.
pin 3 on the module runs front and rear blinks, (a fact to know)
RF is BR/RD, brown -red stripe?
all comments USA on USA forum. USA car.
ok?
the right side lamp (sidemaker) only blinks turns if parks ARE oFF
Id try 2 new blinker lamps front and 1 rear.
that be first. or test the lamp on a battery , and no not get burned fingers hot wring a shorted lamp.
wish i knew
what rear did
and what both did on HAZ
out, dim or to fast.
Mar 23, 2017 | 2003 Jeep Liberty
My nokia 6500 slide, has some problem with its screen. first it was a light brown symbol on the screen and later, two lines appeared to the left side of the symbol horizontally. and now, one more line...
Hi, You will need to unscrew the phone and see if the phone screen is not broken, if the screen is not broken, that means the fllex of the phone is damaged and will need to be replaced.
The flex controls the displaying of the screen.
Oct 08, 2010 | Nokia 6500 Slide Cellular Phone
Colors on the screen are scatttered, mean I can see the red, yellow and blue lines.
Go to menu then setup and see if you have convergence if not you have Blown Fuse FL231 it is located on right side of FBT flyback Transfomer there is 3 in a roll small brown looking caps But they are Fuses.06 it will be the one in the middle
Go to Partstore.com for part
Jun 01, 2010 | RCA D52W23 52" HDTV CRT TV
Model is Satellite P105 S6024, serial # 86019106W About one inch from right-hand side of screen, a 'white line' (in appearance) has appeared. It is about one inch in width, and goes from top to bottom of...
When you get vertical lines from the top of the screen to the bottom of the screen, it means you have bad LCD panel, you need the new one. It will get worst with more lines as time goes by.
Mar 04, 2010 | Toshiba Satellite P105-S6024 Notebook
The out door fan motor is bad. it has three wires the new one has four, a black one a white one and two brown how do i wire up the cap.
the two brown wires go to a capacitor which you should buy new when you buy the motor. they usually cost less than $5.00 and since your motor wires are not the same the capacitor in your a/c may not be the right one for the new motor and it also may be bad.
for the white and black wires they go to the load side of your contactor. it's important that you check the voltage rating on your motor and the a/c to make sure it's the right voltage for your a/c.
usually there's a wiring diagram on your a/c showing the line or power wires coming in to the a/c, they usually go to the contactors line side the opposite side is the load side to wire the motor to.
Mar 16, 2009 | Carrier 36KCARMS Air Conditioner
Blue line down right hand side of screen
If you are confident enough to open screen bezel and take out screen , then the second strap from right of your screen has a bad connection. theses cannot be repaired but as a tempory measure some duct tape across the connections will cure it, else replace the screen.
Mar 16, 2009 | Acer Aspire 9500 Notebook
PT-47WX, Blue streaks across the screen?
It is not a bulb. It is a picture tube. If there are thin blue lines across the entire screen, not just the edges, and the picture itself looks too blue, it means that the blue picture tube is being driven too hard. This could be because the blue screen voltage is too high, the boost voltage on the blue picture tube is too low, or the video output is leaky or shorted. If the picture has what looks like blue arcs and double images on one or more sides of the picture, it means that one of your convergence IC's has burned out and needs to be replaced. These are things that should be tested and serviced by a qualified tech, so allow an experienced tech to handle it for you.
Sep 07, 2007 | Panasonic PT-47WX49 47" Rear Projection...
InFocus ScreenPlay 4805 Multimedia Projector Logo
185 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
