Question about Canon PIXMA iP1600 Printer
Took printer apart to clean out the dust , now have a white piece
With a clear pice attached to it in my hand. I don't know where it goes. could u please help?
2 Suggested Answers
SOURCE: Paper feeding
Thank you, thank you, thank you!!!!!!!!
Posted on Oct 27, 2007
I took a plate off the bottom of my HP 6210 to clean up as much ink that had spilled as possible. I now have a 3 pieces to put back. The gray plate, a black "L" shaped piece and a retangular white sponge...
The white rectangle goes under the cleaning station, which is the black plastic box on the right as you look from the front of the printer. It also helps for ink overflow.
Nov 05, 2009 | HP OfficeJet 6210 All-In-One InkJet...
My images are blurry
check that you have not left it on close up settings ! micro
Jul 14, 2009 | Casio EXILIM Digital Camera
I accidently pulled out a piece of white strip with tow blue ends. Now my printer wont turn on....I took it apart but don't know where this white strip goes...
Sounds like the encoder strip. There's a hook on one side, itgoes through a slot in the printhead, near the top in the back, and a spring to hook it on the other side. Hard to put back without taking the covers off.
Jul 03, 2009 | HP Officejet 5510xi Printer
Hoover Steamvac hose won't spray water
SOLUTION#1 If the attachment wont spray water, the white plastic nozzle tip may be clogged. Take the brush attachment off, remove the two screws from the gray retaining cover (BE CAREFUL THE WHITE TIP UNDER THE BLACK PLASTIC TRIGGER MECHANISM IS SPRING LOADED and WILL GO FLYING). The trigger mechanism can be taken apart by lifting the black part off (may have to slide it back slightly), remove the spring from the white plastic valve insert, then take a flat screw driver and carefully pry the two white pieces apart and blow out both ends. You may have to find a hair size piece of wire to push threw it to clear it. The whole process is really simple once you take it apart and see how it works. Putting it together is in reverse order. The white piece will only go in to the black part one way and with the spring on you need to push it through the hole and the trigger part hooks on, slide it back on to the hose, then while holding it all, and put the gray retaining cover back on. Sounds more difficult than it really is. If your not mechanically inclined take some pictures as your taking it apart to refer to.
Solution#2 If the nozzle and trigger are clear, with the trigger assembly off the hose, plug the hose into the shampooer and turn it on (if the hose inside the suction hose is clear you should start seeing water flowing out the hose. If not run a piece of wire through that hose to unclog it. If its still not flowing then the Pump on the unit needs to be replaced.
Solution #3Cost Around $20 with shipping online. Google your make and model, and upholstery attachemnt pump. Mine was called AP4561692 (43582018) PUMP ASSM, from http://www.appliancepartspros.com/. (there real good about the live chat and helping you find the part).There are Youtube videos on taking apart the shampooer, which is pretty easy. The one place that might give you problems after you get down to taking the pump off, there is only one screw holding but there is on the bottom side of the pump a black bump that clips in to the base of the shampooer and you need to stick a screw driver from the bottom up and pry the base one way and pull the pump the other to unhook it.
Jun 16, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Message says that the ink overflow is full. How do I replace or correct the problem on my Cannon iP 1500?
1) Underneath the print head are 2 foam pads. Turn your printer on with the cover open and then unplug it with the print head away from the pads.
2) The 2 pads have 2 silicone tubes attached to them that run to the rear right side of the printer.
Taking the sides off you can unsnap plastic clips to remove the top half of the printer cover.
3) Follow the silicone tubes. They run into a white plastic pump that sucks the ink that falls onto the pickup screens and dumps it onto numerous felt absorber strips under the pump mechanism.
4) To clean or change the absorber felts you must first remove the Pump mechanism which is held on by 2 screws so that you have access to the felt absorber pieces
5) Run clean water over each piece of felt until the water runs clear and then place them on an absorbant surface (paper towels maybe) to dry.
6) Put it all back together the same way you took it apart.
This can be extremely messy, be careful not to get the ink on anything that matters.
Jun 03, 2009 | Office Equipment & Supplies
White stripes on pages copied from ARM 205
If you changed your developer? Or did you change the Toner Cartridge?
White stripe? Check the charge on the drum, it might have a piece of dust on it.
take the charge out, (dont take it apart) hold it up to some light, you might see some dust particles hanging in the grid. If so, rub very lightly with finger, do not use a cloth to clean. Blow it with a can of air.
Clean the transfer charge as well
Usually replace those as it is such a pain to clean on the smaller machines.
if you need any further help let me know
Thanks
Nov 05, 2008 | Sharp AR-M205 Copier
Paper jammed alarm won't clear. No paper or obstructions seen in feed or internal sections. Tried shutting off and back on, no help. Double checked for scraps or pieces of paper at both ends, none seen....
I found that if you tell it to do a roller cleaning then without using to much pressure put your hand down the paper feeder and push it through.I found with mine where the paper goes through there was dust and dry ink and it stopped the paper going through
Jul 10, 2008 | Office Equipment & Supplies
Gateway 450sx no power
Needs physical repair. No help without some new parts. The "little piece" latch is necessary. The bay thinks there is a device there and there isn't. The POST (Power On Self Test) program won't allow it to startup if a device is missing.
Jun 18, 2008 | Gateway MT3705 Notebook
The yellow light is blinking at all times
check 2 be sure you removed tape from bottos of new cartridges.
Oct 25, 2007 | HP DeskJet 1220c InkJet Printer
Canon PIXMA iP1600 Printer Logo
16 people viewed this question
old marine
old marine
