Question about Gardner Bender #GSW-SK Door Switch
Can you describe how to wire this switch between an electrical outlet and an overhead fluorescent light? I have recessed the electrical switch box in the door jamb. There are two black wires on the rear of the Gardner Bender GSW-SK switch. One is labeled 'comm' which I've connected to the two white electrical wires i.e. one from the electrical outlet and the other that goes to the overhead flourescent light. The other black wire I assumed would connect to the two black wires. When I flip on the circuit breaker the light in the closet is on, even thought the pantry door is closed???? Please help. Thanks in advance. Mark
  • 69 Answers
The 'comm' on that switch is very misleading. Generally that would refer to the white (or neutral wires), however in this case it doesn't. All a switch does is interrupt power. One black wire is power into the switch, and the other black wire is power out of the switch. So, all you have to do is leave the whites connected to each other, and connect one black wire to one black lead on the switch, and connect the other black wire to the other lead on the switch. Everything should work perfectly after this.
Posted on Sep 29, 2009
  • 8,404 Answers
I dont understand your question. However, I can tell you how to put a switch in this circuit.
You are taking power from an outlet. Run the black, white and green to the switch box. if the box is metal, you myst make a ground connection and you must ground the switch frame. The white runs straight through the switch box to the flourescent, as will the green after you make the connection to the box and the switch frame. The hot black goes to a brass screw. continue with the black from the other brass screw on the switch to the black (red) in the flourescent. Green is ground; white goes to the white wire and black to the black.
Does this help you? If not ... please reask
a
Living room wiring. All the outlets and the bright overhead light fixture are all wired to a wall switch, so you can't have any side lamps on without the overhead light. How do I understand this so I can...
The most common way the houses are wired is through the ceiling. The power comes into the box that the light is on. The power is wired to the light on one wire and the other goes down to the switch. The return comes back from the switch and connects to the light. What the did was connect the wire that feeds the outlets to the switch.
Aug 16, 2014 | Electrical Supplies
Replacing a switch outlet combination with a switch GFCI outlet combination and there is only one cable in the box (14/3)
If it worked before, it should be a wire to wire replacement. You are replacing a regular switch/outlet with another switch/outlet which just happens to be a GFI outlet.
Wire the old switch wires to the new switch and the old outlet wires to the new outlet.
Cut the breaker/s off first !!
Sep 25, 2017 | Cooper Industries Electrical Supplies
How to connect three gang switch to control three lights, using two 1mm double core
What is 1mm double core?
Following image shows example 120Volt 4 gang switches with outlet.
http://waterheatertimer.org/images/Single-pole-switches-in-4-g.jpg
Each 120Volt electrical box has one Hot wire. This is true for ceiling and wall boxes.
Normally in a gang box, the Hot wire jumpers across all devices in the box.
Some switch boxes do not have Neutral wire. Neutral wires are usually white, and are twisted together and covered with wire nut and shoved to back of box.
Open following links for typical 120V and 240V circuits in US.
http://waterheatertimer.org/B220C.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Feel free to add a comment and describe wiring, and voltage.
For example if hot wire arrives from one of the lights.
Describe the wires that you have, and what each wire goes to for best possible answer.
Aug 16, 2011 | Cooper Industries Cooper Wiring 2158V 3...
I have a standard light switch that controls one overhead light - fine. Now I want to replace it with a Leviton T5225 which I think is the right weapon for the job -- one unit that has a light switch and...
It sounds like you have power in your light, power is fed down on the white wire and the black wire is switched and connects back up to the light. You do not have a "neutral" in the box, so you cannot run an outlet with the wire that is currently available.
Feb 27, 2011 | Leviton 8299 Combination Switch / Smart...
I bought a leviton combination two switches. I would like one to go to a recepticle, that i can switch on & off. The other switch i would like to go to an overhead light. Any information will be...
The wiring for the overhead light is the same as for the outlet. I don't know what wires you have in the box where you will be putting this switch, but I will assume the simplest case. The box should have 3 sets of wires. Each set has a white, a black and a ground. One set is hot, coming from the main panel. One set goes to the light. The third set goes to the outlet. Connect all three ground wires together and to the ground lug on the switch. Connect all three white wires together, but not to the switch. Your switch will have 4 terminal screws. On one side of the switch, two of the screws should be connected together with a little metal bar. Connect the hot black wire from the panel to one of the two screws that are connected together. (the other screw is not used). Connect your black wire for the light to one of the screws on the other side of the switch. Connect your black wire for the outlet to the last remaining screw. Be safe. good luck. Let me know if you found this helpful. Al K
Jan 19, 2011 | Leviton Electrical Supplies
First, I have power running thru a switch box. All white commons are tied together. Then I tap power to S1 switch leg with light working normal using a standard S1 switch. Then using a Lutron DV-600P the...
Let's start at the beginning please. You have a source cable fed into an overhead outlet box or to a switch outlet box on the wall? This is critical because it tells me what kind of arrangement you actually have.
If the source is in the ceiling, then you are using switch loops and the wiring gets tricky because you have to "re-task" the Neutral (White) wire (Assuming you are here in the U.S.A.) that goes to the switch because it will become the feed to the wall switch.
However, is the feed is at the switch, then it is much simpler. Please let me know what you have in the form of wiring.
Also as an FYI, if you are using special switches, you may have to have equipment grounding conductor present at the switch. The electrical code no longer allows the use of a Neutral (White) conductor as a grounding conductor.
Nov 08, 2017 | Lutron Electrical Supplies
I want to install a GFI outlet in a bathroom that only has a outlet in the light fixture? How do I run a wire from the switch which has 2 switches, one for the fan and one for the light above the med...
Make sure you turn off the power at the power panel.
If you are lucky you will find the following in the electrical box behind the light:
  1. A black wire that brings power from the fuse/breaker panel--connected directly to one or two other (black) wires (not to the light).
  2. A white wire from the panel--connected to one or more white wires including one to the light.
  3. A black or white (maybe taped black) wire that comes from the switch and is connected to the light.
  4. A green or bare wire connected to the box and maybe also to the light.
If this is the case then you can run a new cable to a new electrical box in the wall for the GFI. Connect the new black wire to the Line In terminal/black wire of the GFI outlet and to the group of black wires in (1) above. Connect the new white wire to the Neutral terminal/white wire of the GFI outlet and to the group of white wires in (2) above. Connect the new green/bare wire to the Ground terminal/green wire of the GFI outlet and to the original box or ground wire. If there is a Load/Feed through wire on the GFI outlet, tape the end of it and do not use.
If the black and white wires described in (1) and (2) above do not appear in the electrical box at the light then they are probably in the switch box and there will be only one black wire and one white wire that connect to the light on the wall. In that case you will need to run a new cable from the switch box to the new outlet. You will not be able to wire the new outlet from the existing electrical box at the light unless you do it through the switch and it will not be on unless the switch is on.
Aug 28, 2009 | 3M GFI Software GFI MailEssentials For...
Gardner Bender #GSW-SK Door Switch Logo
346 people viewed this question
Top Gardner Bender Electrical Supplies Experts
epangan29
Gene Haynes
Are you a Gardner Bender Electrical Supply Expert? Answer questions, earn points and help others
