Question about Rinnai Webstone The isolator EXP tankless water heater Service Valves WRIK
Rinnai Tankless won't stay on
Rinnai R94LSi that goes out when tap is opened more that a little or more that one is opened. Error code 12 shows up. Has 1" pipe to within 3 ft and full 3/4" flex to unit??? Vent is less than 3 ft long and only rises less than 1 ft.\r\nJerry
  • 117 Answers
How far is the tankless from the gas meter? error code 12 means it doesn't have enough gas running to it. is the 3/4 flex true 3/4 or is it 1/2 with 3/4 threads. have you checked your BTU load on your house to make sure your 1'' pipe can handle everything else you have on the house? sounds like to me you dont have the right amount of gas to the unit.
Posted on Oct 03, 2009
Rinnai tankless hot water heater
Try replacement valve or solinoid for it on Ebay, or MFG website, or their customer service web site. They may not help due to critical safety issues with DIY fixes.
Apr 14, 2015 | Rinnai R94lsi Tankless Water Heater-...
Rinnai Trouble Shooting
Clean water filter.
Delime heat exchanger.
http://waterheatertimer.org/How-to-delime-tankless-water-heater.html
Add tempering tank to preheat cold incoming water.
http://waterheatertimer.org/Tempering-tank.html
Check for bad single-handled faucet cartridges.
http://waterheatertimer.org/Crossover.html
Don't install multi-sensor computer-chip water heater to water lines and gas line and vent pipe since tankless will develop unsolvable problems.
Contact Rinnai and hear them tell you to call service technician, only to discover there are no qualified service technicians in your area who might be able to solve problem. 1-800-621-9419
Ask why the Rainnai site has much promotional information and no service manuals. Nor does Rinnai offer forum where tankless owners can freely exchange their endless unsolvable problems for all to see.
May 16, 2013 | Rinnai Tankless Water Heater R94lsi W/...
Rheem RTG-66DVN shuts off 1-2 times a day
You received recommended answer posted ago.
Probably same answer today:
Don't install tankless, especially in location where there is no service technician available unless you expect to heat water by setting tankless out in sun.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Repair any brand tankless, any error code or problem, same day, yourself for $385:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Add comment and give link to service manual that you located.
Apr 05, 2013 | Rheem RTG-66DVN Natural Gas Tankless Water...
RINNAI R94LS CONVERT TO NATURAL FROM PROPANE
The electric water heaters have replaced the traditional of water heating. The advanced features and the latest technologies of water heater have made it so easy for everyone. Find the best electric water heater on the market today. Read electric water heater reviews and comments from experts. Almost each product is manually reviewed and tested.
Electric Water Heater List Reviews waterheaterlist com
Jan 28, 2013 | Rinnai R94LSi Tankless Water Heater...
I have a Rinnai tankless gas water heater and this things beeping and flashing 12 everytime we turn on the hot water the water will get hot but you have to wait for it to stop beeping
Error 12 is failed ignition - this can be caused by many things, but normally a low gas pressure, or no gas pressure upon ignition.
Try turning the hot tap on very slowly till till the control shows burner is lit. Then turn it on faster. If it stays going with no error, you might have a faulty regulator, not opening fast enough to meet demand. Especially common with lpg models,a lot rarer on natural gas.
Oct 27, 2009 | Rinnai Water Heaters
This things beeping and flashing 12 everytime we
check the error codes on it by pressing the on off button for 2 seconds then while holding the on/off button press the up button this should display the last 9 error codes let me know what they are
Jul 28, 2009 | Rinnai Water Heaters
Rinnai r94lsi comes on 5 sec. then off
if it's a gas unit you mite have to bleed the gas line in and out.
Jan 04, 2009 | Rinnai Webstone The isolator EXP tankless...
Rinnai tankless water heater code 12
12 - Flame Failure or Poor Ground
1. Immediate code 12 is usually a defective gas valve, power supply problem, or defective fan motor wiring harness.
2. If code 12 occurs after a few seconds it indicates that proper operation was established, but then stopped unexpectedly.
3. Verify that fuel is being supplied to the unit.
4. Check for proper electrical ground. Unit must use a grounded power supply.
5. Check for flue blockage on inlet or exhaust.
http://www.foreverhotwater.com/service-codes.php
Dec 31, 2008 | Rinnai Webstone The isolator EXP tankless...
Rinnai Webstone The isolator EXP  tankless water heater Service Valves WRIK Logo
868 people viewed this question
Top Rinnai Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
jdthefixer
Are you a Rinnai Water Heater Expert? Answer questions, earn points and help others
