Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
I just replaced the print cartidge on the MFC240C, and then all four of the Function lights went on, and the LCD Screen has blacked out.
Unable to print 46
To reset purge counter
1) Enter machine maintenance mode (on MFC240C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Sep 29, 2014 | Brother MultiFunction Center MFC-440CN...
My brother printer has an error unable to clean 50
XXXXX XXXXX look on the printer, do you have these keys:
Menu/Set, Black Start, or Function?
Brother Printer Support
Sep 28, 2012 | Brother LC51BK Print cartridge, Inkjet...
Just opened my new mfc240c printer and it wont print black ink why? only prints in color no matter how many times i clean the heads
Try powerful cleaning:
Press menu, then start black copy, then four times arrow-up quickly after another.Machine will be in maintenance mode
(all lights will flash).
Press 7-6-4 and OK (or start-black-copy).
When finished press 7-6-3 then start black copy,
printer will do a power purge.
Leave maintenance mode by pressing 9-9.
If this not help better think about new printer, because cost of repairing this one is profitable.
Nov 26, 2009 | Brother Multi-Function Center MFC-240C...
My printer wont print documents with black ink, its a brand new ink cartidge..any ideas on what to do?
I had this same problem after replacing the black ink cart. I pulled all the inks out and used a Q-tip to swap the area where the ink goes in. I also used a sewing needle to poke around a bit and clear out any clogs. I then went throuh 5 cleaning cycles. It works now.
Sep 19, 2009 | Brother MFC 490cw Color Inkjet...
Mfc-240c reading offline and empty black
Regarding your problem: If one of the color ink cartidges is out of ink, the MFC 240C printer will not operate when you only install a black ink cartidge. It requires that all four catridges have ink available in them for it to function. When you examine a cartridge it may appear that it has a little ink in it when you get message that the cartridges needs to be replaced because a little ink remains to prevent the print head from drying out. JLHinton1@bellsouth.net
Sep 24, 2008 | Brother Multi-Function Center MFC-240C...
Black screen
Hey... friend,
It's seems your backlight inverter is burnt out...need to replaced a new inverter. Visit this site @ www.3rd-rocks.com There's a replacement parts for your FP988D LCD. Have a nice day!
Aug 05, 2008 | Fuji FP-988D 19" Flat Panel LCD Monitor
Printer not printing!
You need to reset the Purge Counter.
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine’s log
Jul 16, 2008 | Brother MFC 420CN All-In-One InkJet...
Inkjet alignment and cleaning
press ink and the arrow-up button to choose alignment print, test print and cleaning color or black or both.
Oct 29, 2007 | Brother Multi-Function Center MFC-240C...
C4180 Professional Photo Pack
Yes, plastic cartidge holder is provided to you to store HP 337 (black inkjet print cartridge) as you remove it to install a new HP 338 ( Photo Cartidge).
Remember, below combination of Cartidges for used for specific purposes:
Black and color cartidge  for general Printing of Documents.
Black, Color, Photo Cartidge to Print Photos.
Color cartidge , photo Cartidge and gray cartidge is specially used when you to print copies of photos  with great quality.
I hope that this should resolve the issue for you.
You can mail me at thumuvikram@rediffmail.com for further assistance, I'll be glad to help you.
Bye
Oct 16, 2007 | HP PhotoSmart C4180 All-in-One Color...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
70 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
