Question about Meade LXD55 AR5EC Achromatic 5 in f9 Refracting Telescope 05095503
LXD75 AR6-AT I have a problem with the doublet lens. I seem to be able to collimate it, but there is still light that spreads out from stars and planets that are brite. Also when I'm handling the scope to place it on the mount I hear a clunking sound from the objective lens. I think the secondary part of the doublet is loose. I see the concentric rings when I attempt to collimate the scope but the blob of light that forms when you defocus the scope, forms beside the star and not on top (as I would expect). If the corrector lens is loose an slumping down from it's correct tightened spot would this cause the image to spray light from where it's meant to? Can I repair this or should I return the scope to Meade?
    New Friend:
I have the identical issue --- AND It did not have it when it was new. I was returning from a road trip, and heard the rattling cell get louder and louder in the back seat. When I got home, the retaining ring that keeps the doublet in the cell had almost fallen out. I GENTLY checked for lens damage and noticed that one of the three tiny foil spacers between the lenses had fallen out and was missing. I tried to fabricate one out of aluminum foil, but upon reassembly, I have symptoms identical to the ones you describe. No matter what I've tried, I still have the same symptoms. I'm getting close to giving up and sending the cell to Meade to service. I suspect the issue is that the dimension of the tiny spacers and when one falls out or is replaced with the wrong size, we get the symptoms.
Posted on Apr 30, 2013
  • 3,186 Answers
This is an old problem but I will answer it--
The rattling sound is a KNOWN ISSUE with these scopes. It actually does not affect anything. The scope is what is called an acromatic refractor. ALL ACROMATIC REFRACTORS show color fringing around bright objects. You would need to buy an APOCROMATIC refractor with 3 lenses to get true color correction. These scopes are very expensive to buy.
You can also use a "minus violet" filter to eliminate most of the color fringing in that scope. If the scope cannot be collimated it should be returned to Meade.
www.telescopeman.org
www.telescopeman.info
www.telescopeman.us
Posted on Aug 02, 2011
  • jbondojbondo Jul 29, 2014
    It's absolutely true, rattle is normal and fine up to a point. My unit's retainer ring became so loose, the outer element was flopping around with a big 'clack' (like 1 entire inch flapping back and forth.) Anyhow. Finally found the solution to the blue tinge issue. I bought some lab-grade 99.99 pure alcohol and recleaned the elements, and presto, the blue tinge problem was gone.
How to align bonoculars
Cheaper binoculars may have no adjustment means for this at all (it is called "collimation"). Properly it should be done by adjusting the front lens in its seat, and quality binoculars have an eccentric ring around the lens under the clamp ring so that can be done.
Your Tasco probably does not have that, so look under the covering material on the barrels (it may be stuck down) for 2 small screws over the prism eg
http://www.oberwerk.com/support/images/coll1.jpg
http://www.cloudynights.com/ubbthreads/attachments/1037129-colscrews.jpg
Gross collimation can be done in daylight, but fine adjustment is best done with a point source like a star.
http://www.youtube.com/watch?v=4cqJwV2moto
http://www.oberwerk.com/support/collimate.htm
http://www.cloudynights.com/item.php?item_id=416
http://barska.com/collimation_bc201.pdf
Apr 12, 2014 | Tasco Optics
Is there an adapter so I can fit my 2"Collimation Tool into my .965" eyepiece holder on my telescope
There are adapters, but normally a 2" collimation tool is way way too heavy for a .965 eyepiece holder. Most of the eyepiece holders are made from plastic, and they break fairly easily, so you take a big chance of your 2" collimation tool dropping to the floor or concrete. Even if the plastic did not break, the weight of the collimation tool would bend the eyepiece holder out of position. It only takes the slightest amount to make your test worthless - after all, you're after precision. Bending or distorting anything destroys the precision. They do make 1.5" collimation tools, and there are adapters to get from the tool to your eyepiece holder. They also make things called "cheshire eyepieces" and regular collimating tools which will work with your 4" reflector.
Nov 05, 2017 | Celestron Cameras
Aberrations are seen when I view the stars...kind of look like this: -----<o>----
Those are called defrraction spikes --- and really do not affect the view. Stars are always just points of light.
Make sure the scope is collimated- watch this video:
http://www.andysshotglass.com/Collimating.html
www.telescopeman.us
Aug 10, 2011 | Orion SpaceProbe 130ST EQ Telescope
Collimation of my lxd 55 8" tellescope i had to take off the secondry mirror and primery mirrror .due to kids play with them.i can seem to collimat the tellescope can you please tell my how to line...
The corrector lens must be perfectly centered and should have been replaced in the exact position as when you removed it. You are now left with trial and error-- turn the lens 10 degrees- check collimation-- turn the lens 10 more degrees check collimation etc etc -- until you are able to collimate the scope.
www.telescopeman.us
Jul 01, 2011 | Meade LXD55 Telescope
I used the collimation eyepiece to collimate my telescope.But I dont know if it's properly aligned. The knobs on the bottom of the tube are turned fully clockwise, and the black dot in the eyepiece is...
Before you do anything else, take the scope outside on a good night, find a semi- bright star (Polaris will do). Let the scope cool down! (about 45 minutes) use your highest power eyepiece and put the star in focus.
Now take the star out of focus (inner focus or outer focus) you should see a dark circle in the center with symmetrical rings around it (airy rings). If the dark circle is in the center and the airy rings are symmetrical, your telescope is collimated
Check both inner and outer focus, they should be close to the same. If not you should re-collimate.
Best done with fainter stars but for now stick to the brighter ones.
Because I own 3 scopes, I use a Hotech laser collimator. its quick and easy. Worth it if you travel with your scopes to dark sites
A good guide on how to collimate
http://www.skyandtelescope.com/howto/diy/3306876.html
Oct 16, 2010 | Celestron NexStar 130SLT (31145) (306 x...
When I look at a single object like a star, I see four stars in a perfect line.
Your scope may need collimation-- see these web sites:
http://astrosurf.com/legault/collim.html
http://sctscopes.net/SCT_Tips/Maintenance/Collimation/collimation.html
Aug 14, 2010 | Meade LX200GPS Telescope
The images of deep sky objects (such as M31 M8 ...) I get with my LXD75 (SN 8") are faint. The images of the solar system (Moon, Jupiter...) are decent. Should I proceed to a collimation ?
NO- the objects are much dimmer than the planets and your camera must take a LONGER exposure to get an image.
Collimation makes stars and planets "sharper" but NOT BRIGHTER.
Many deep sky objects require 10-15 minute exposures!
Aug 08, 2010 | Meade LXD75 8.0"/203mm f/4.0 Telescope OTA...
Objective doublet assembly
This should help you reassemble correctly--
http://www.cloudynights.com/documents/cleaning2.pdf
May 21, 2009 | AMT Optics
Olympus film camera 300mm 4.5 lens remove to clean rear element
Yes, it's fairly straightforward, but the fungus will have permanently damaged the lens element and is likely to spread.
Afterwards you may need to get the element adjusted (collimated) by a lens repairer.
Feb 21, 2009 | Olympus Zuiko 300mm f/2.8 Lens
Requesting answer
Negative miniscus doublet lens,Objective (disk read) lens,negative cylindrical lens,Negative elliptical lens.
yes
Apr 21, 2008 | Microsoft Windows Vista Ultimate Edition
Meade LXD55 AR5EC Achromatic 5 in f9 Refracting Telescope 05095503 Logo
123 people viewed this question
Top Meade Optics Experts
Experi
Level 1 Expert
Joe Wright
Level 1 Expert
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Meade Optic Expert? Answer questions, earn points and help others
