Motor not shutting off in Fellowes Powerhouse C-14 shredder
When shredder is in automatic mode and something is shredded, it does not shut automatically.
  • 1 more comment
  • joebry Jan 12, 2008
    I have the P-57C and it did automatically shut off but it does not automatically stop now when finished.
  • wm126883 Jul 04, 2008
    My Fellows powershred PS60 sometimes will not shut off. If I leave It in the automatic position it will sometimes start and continue to run until someone notices it. Tonight when I returned to my office it was running, very hot, smelled like burning electrical ozone, and the plastic case was melting. It is sitting at the curb now.
  • Anonymous Mar 18, 2014
    After shredding the paper it used to shut off. Now I have to manually shut it off.
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 64 Answers
The sensor arm located in the middle of feeder is jammed down.
To clear this you can try to shred strip of very thick paper or thin cardboard. Run it through the middle of the feed opening. If that does not work clear the paper jamming the sensor arm it a pair of tweezers Otherwise you could soak the blockage between rollers with liquid soap as a lubricant. After soaking, and once the paper has softened loosen and then remove it with your tweezers.
Your unit should operate fine now!!
Posted on Jun 16, 2015
    Scholar:
  • 102 Answers
This is an issue with your paperfeed sensor. You need to call Fellowes at 1-800-945-4545.
Posted on Feb 23, 2008
Shredder will not work in automatic mode
There might be a tiny scrap of paper blocking the sensor, which will keep the motor running.
Dec 06, 2016 | Shredder Office Equipment & Supplies
My Executive Machines EPS 1200X shredder works in reverse, but does not shred.
there should be a forward/ reverse switch that is used to unjam paper being shredded. check that
if it is automatic then check for paper stuck in the shredder causing the reverse action.
May 12, 2015 | Shredder Office Equipment & Supplies
Won t shut off
Blow out the sensors with some compressed air, Using a can of compressed air, look for the sensors that detect the paper and give them a blast or two, then try it, it may take a couple of tries.
This may also be a good time to lubricate the cutting heads, if it is a good machine with metal heads a light oil applied to paper then run through the shredder will pass the oil onto the heads.
A shredder oil or light oil like 3 in 1, these usually have a narrow nozzle to limit the oil flow, draw lines, do a picture or spell your name on the paper with oil and shred it. You have just serviced your shredder.
If it is a less expensive shredder with plastic heads, shredding a couple if sheets of waxed paper will pass the wax onto the cutting heads reducing friction.
Hope this helps.
Ed
Oct 01, 2013 | Office Equipment & Supplies
The shredder doesn't automatically shred anymore. How do I set it so the "eye" works and it shreds automatically without me holding down the button?
Check the Power Ensure that the shredder top is firmly placed in the shredder basket if the unit will not operate. If the top is not in place the feeder will not work and accept any paper. Make sure it is firmly plugged into the wall outlet and that the outlet is active. Rest the Shredder Let the shredder cool down if the shredder has been running continuously for a long time. It may have overheated and needs to be left in the off position for at least 30 minutes to reset. Verify the basket is empty or not too full as that will cause the shredder to deactivate. Clear Paper Jam Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Auto Mode Not Working Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
Sep 04, 2013 | Quartet gbc 5550X Shredder
My royal 112mx shredder doesn't shut off automatically after shredding a sheet
Unplug the shredder. Either blow with canned air or take a small paintbrush and clean the sensors where you put the paper in. There is one above and one below in the center of the slot.
Feb 28, 2011 | Royal 112MX Shredder
Shedder OM99732 in automatic mode will start and shred when paper put in, but will not shut off. It also appears there is some type of plastic covering the screws so I am unable to remove the cover. It...
It sounds like a piece of paper is blocking one of the two photo cells that detected when a piece of paper (or a CD / DVD) has been inserted for shredding. The (six) screws that secure the top are accessible from the bottom of the shredder unit after it is removed from the paper bin. Be careful: There are three different sets of wires connecting the top control plate to the bottom motor and cutter assemblies. It is not too difficult to get inside the shredder "head" if neccessary.
Aug 23, 2010 | OfficeMax Office Equipment & Supplies
Paper shredder does not turn off. I have to open
I'm assuming that it automatically detects the presence of paper... .
By opening the drawer you're disabling it from the safety switch. (they dont want you to shred your fingers from the bottom) There is probably a small piece of paper holding the feed sensor down.
If you're confidant, unplug the unit and take apart the plastic cover. Do not remove anything inside. Look for the small switch between the blades which 'feels' the presence of paper. There is probably a small piece of paper wedged between the housing and the switch which would fool the unit into thinking it has paper that still needs to be shredded.
Carefully put your unit back together and happy shredding.
This may happen often, remember what you did!!!
Jul 30, 2009 | World Office Products Papermate PM-1550CD...
Shredder won't stop after shredding
Blow out the electric eye in the feed slot with compressed air.
Jun 28, 2009 | Office Equipment & Supplies
Automatic Shredding
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pc1.gif board, contact manufacturer for more info.
Dec 10, 2007 | Quartet gbc Shredmaster 2240S (Strip-Cut)...
785 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
