Question about Compaq tc1100 Tablet PC
Chequered screen For some time now, the screen has gone chequered. Everything works just fine but you hardly see anything. The screen is coarsly pixelized and fuzzy. Smells like a hardware problem. It happened a couple of times some year ago. Since then I havn't used it, until recently. Now it is only chequered. I tried to carefully adjust the flat panel cable and its connectors inside but that didn't change anything. Useful maintanence guide at "http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00681631/c00681631.pdf?jumpid=reg_R1002_USEN" 1) what else can i try 2) does the small internal batterypack called "bridge battery" have anything to do with this? 3) has anyone experienced this before? Thanks for great site, /Anders F
  • 4 more comments
  • joemc Feb 01, 2008
    Having a problem with several tc1000 tablets - video is very fuzzy - one is this way regardless whether it is docked or undocked, one works ok on dock in most instances, but in undocked mode, you can barely see anything on the screen. When you first boot the tablet on, all kinds of characters pop up on screen, then everything is totally fuzzy. Any easy fix or solution, these are no longer under warranty.
  • Anonymous Feb 12, 2008
    same problem as described above, cannot find any solution.
  • frisman Mar 02, 2008
    Similar screen problem..
    I have a TC1100 that had a bad screen (display SUPER dim, HP logo barely visible on boot) so I just purchased and installed a new screen (which comes with the whole bezel, inverter, display, everything on the top half of unit) Same thing happens, barely visible screen and no backlight. I have played with every cable and nothing. Anyone else had this problem or know how to fix it, I would really appreciate any help. Also, the external video port to another monitor does work which tells me that the video adapter is functioning.
    Thanks.
  • neilcosta99 Jul 01, 2008
    My screen started having this chequered screen about two months ago. It has also started just crashing and giving me blue screen of death randomly as well. I am not sure which solution to chase down - replacing wires, video card, etc? Any help would be great. In Boston area and want to have repaired.
  • clanwarrior Jan 08, 2009
    Help me also, I have the same problem
  • paolo-bf May 11, 2010
    hi tabletmaven,
    i found your post quite useful, you said that to hold the
    battery and screen in a certain way at startup may be quite helpful,
    could you possibly tell me in which way you should try to hold battery and screen,
I have a tc1100 with the exact same issue. The problem I noticed, also, that when attached to the keyboard and in the upright position I could get clean boot (sometimes) by flexing the tablet a bit.
I discovered when I disassembled the unit the bracket assembly that connects and releases the keyboard from the slate was the culprit.
When I removed that and lifted the motherboard a bit it booted fine ... when I replaced the assembly, the checkered screen appeared again. I again removed the bracket and got it to boot fine. Apparently, it was pressing the motherboard against the frame and shorting out the video card.
Posted on Dec 09, 2008
I have this checkerboard problem, and I was able to temporarily solve it by putting the TC1100 in the fridge for 20 minutes before bootup. It must be that hairline fracture in the motherboard, and warping from the heat. My device will not start up normally unless I do this. I would like a real fix though.
Posted on Jun 27, 2008
I fixed mine finally!!! I ordered a cable kit and replaced the cable from the display to the motherboard (I actualy replaced them all but that one was the culprit.) Also, I learned that if you put the cable in backwards :) into the motherboard, it will appear very dim as it did with the bad cable. I believe that this is because the backlight inverter is not active, which in other posts here, may mean that the inverter is bad. Just a thought...
Posted on Mar 12, 2008
    Problem Solver:
  • 10 Answers
I work with these computers on a daily basis. For checkered screens it is a bad connection with the keyboard/system board usually caused by a loose keyboard bracket or hinge. This has been known in some cases to cause a hairline crack in the system board near the graphics controller which gives a checkered/low resolution screen. The problem is not fixable; you will have to buy a new system board and sometimes a new keyboard.
Posted on Apr 05, 2008
Ok. reading other solutions. \ helped me figure Out the problem. There is a hairline crack, that that's what i did not notice. i only heard the large sparking the motherboard would give. in Suggesting if anyone with good Soldering skills could fix their motherboard. (that is if You can open your tablet) in going ahead with this and tell You what happens later,
Posted on Jul 04, 2009
Can anyone tell me where I can get a replacement system board for the tc1100 and if they are even available now?
Posted on Sep 20, 2008
  • 24 Answers
Pixelated and fuzzy screen Issue note.
The tc1100 and tc1000 borrow ram from the onboard ram installed at the factory (or upgraded) and if this RAM is bad or failing in the area that feeds to the Nvidea integrated card, well, you can get this effect. I dont remember if the card uses the first or last part right now.
It can also be caused by a bad video card, and no, you cannot replace it as it is fixed to the Mother board (mainboard) unless you are a very very qualified board tech. The RAM you need to check is attached to the mainboard under the rear cover which will have to be removed. Download the manual at HPs site. For the tc1000 this RAM is on the bottom of the board, so you have to remove the mainboard completely.
You will need patience and known good RAM!
  • 3 Answers
I have a TC1100 that started doing this right after I used the keyboard controller update, which BTW I don't think is necessary and I only did it out of a nerd compulsion to make sure everything was up to date.
I find that if I boot with the keyboard detached it will usually boot ok. The moment I get it booting clear I reattach the keyboard.
Because this started after I updated the controller BIOS and I have 4 identical machines BTW, I believe this is also related to a poor BIOS fix.
Obviously these symptoms can be created by numerous factors so this may not apply to everyone.
Posted on Mar 15, 2008
The problem is actually due to the connection between the keyboard and the systemboard. This is why if you pull your screen towards you when you turn on the computer it will often work but not another time. Usually the fix is to replace the system board but when that is not an option you could always try reinforcing the solder on the systemboard port that connects it to the keyboard.
Posted on Mar 11, 2008
Not sure of a fix but it appears that the heat generated by all the components under the screen may be warping certain components. I have found that if on startup, i hold the battery and screen in certain way I have successful starts. This is not idea, but to have it checked out and repaired (out of warrantee) could be very expensive. I noticed that the tc4400 now has the components (battery, harddrive...etc) and the screen seperated. I think they figured it out and did not put out a notice to the early adopters.
Posted on Feb 03, 2008
I've got one and the same happens. However, there are instances when it works fine. Quite random.
Unfortunately, I've no idea what you can try but I have read that it's a faulty video memory chip problem.
I'd like to know what that specific chip is and maybe try to replace it.
And I've not heard about the bridge battery before.
Any joy with anything of late?
Steven
Posted on Jan 02, 2008
Non of the apps on my acer tablet are working , I have gone through all of the updates and restarted the tablet multiple times
Might want to contact them -https://www.acer.com/ac/en/US/content/support
If you don't mind losing all you have saved on it you can try a factory restore- It will delete everything!
Factory / Hard reset / Password Removal
  1. Power off the tablet. Press and hold the Volume Up and the Power button. After 3 seconds release the Power On button but continue holding the Volume Up button. In the Select Boot Mode use the Volume Up/Down keys to navigate and the Power button to select the desired option.
  2. [SD Image Update Mode]
  3. wipe data/factory reset.
  4. Yes - delete all user data.
  5. Reboot system now.
  6. Your tablet will reboot and go to the Welcome screen.
Jul 12, 2018 | Acer Tablets & eReaders
My Ipad is locking on me and I dont understand why nor do I know how to fix it.
The Line on the screen indicates a damaged screen or faulty screen connection to the main circuit board.
Is the battery status low or decreasing very rapidly (activate percentage display for the battery) then it could be your battery is worn out. It can cause the iPad to shut off or reboot when the battery can't deliver the required power anymore. Like when you run a power intensive task the power drain is too much for the battery and it can't keep the required voltage.
Jul 31, 2017 | Apple iPad Tablets & eReaders
Have 2 tablets only 2 months old 1 won't charge; 1 has plain white screen can't do anything
For the one that is not charging. Is it where it cannot hold a charge or won't make a connection all? Could be a bad battery, or could be the charge port is bent or disconnected. The white screen sounds like it has crashed and won't boot up with its "Operating System" You could try doing a hard reset on the white screen, if that does not fix it then I say it is gone for good and you would need a new one.
Mar 02, 2015 | Tablets & eReaders
The reset button is gone so how can I reset it to get past my screen lock
Enter your tablets make and model followed by "hard reset" into your search bar, example "Apple Ipad hard reset". Choose one link and follow their instructions. Problem is that everything in your tablet will be erased.
Nov 07, 2014 | Tablets & eReaders
Wont let me go anywere from the titel screen
Hold down the power key for a while and wait for it to either switch off or restart. if you do see some problems go for a reset
Mar 01, 2014 | Iview Cyberpad 756TPC Tablet
Disgo is frozen on home screen and home icon keep flashing i cant do anything
Search google to do a hard reset, I had the problem and after doing a hard reset it helped me and my tablet is working fine now. I don't really remember which keys it was but there are three keys to keep pressed and after that it will reset your tablet and if everything is ok it should work perfectly after that.
It would be nice if the manufacturer would also put that in the manual, because when I received my tablet I had to calibrate the screen and that didn't really help me. Also the tablet was working really slow and took a lot of time for everything, plus the fact that the keyboard kept pressing all sorts of other keys then that I wanted to press.
I hope this will help you and that your tablet will work fine for you.
Let me know if you had any success.
Sep 08, 2012 | Disgo Tablets & eReaders
Hard drive shuts down and freezes computer instantly. The drive indicator light turns off, and I can still move my mouse around, but if I click on anything, it doesn't respond. It works fine in safe mode,...
time to save everything to another save source and replace that hard drive
use a solid state hard drive as a replacement as there are no moving parts to wear out
Jan 31, 2018 | Gateway C-141x Tablet PC
Hardrive won't run, screen is black
Most possible one of your Toshiba Tecra m4 driver is not working properly, but don't worry give me a call at +1 (833) 493-0111 so that i can suggest you the right way to fix it!
Apr 13, 2017 | Toshiba Tecra M4-S435 Tablet PC
Compaq tc1100 Tablet PC Logo
1,475 people viewed this question
Top Compaq Tablets & eReaders Experts
Vernon Taylor
tosin_christ
alibaba69
Are you a Compaq Tablet and eReader Expert? Answer questions, earn points and help others
