Question about Kicker CVR12 Car Subwoofer
How to unseize a speaker - Kicker CVR12 Car Subwoofer
  • 344 Answers
Does it smell really bad, if so you probibly over powered the voicecoil wire and the insulation melted off and shorted. You should check the resistance first to see if it's fryed, if your sub is 4 ohm that's what you should read with a multi-meter, if it's close to 0 or 1 than you won't be able to fix it
Posted on Sep 29, 2009
Unseize motor
You have a broken rod or etc. Don't be starting it till find the problem. May damage it more.
Jun 09, 2013 | Garden
Unseize engine
Chances are you will have to disassemble the engine to fix it.
May 01, 2013 | Cars & Trucks
Unseize an engine
If the problem is a piston or bearing, you may have to disassemble the engine to fix it.
Apr 30, 2013 | Cars & Trucks
Unsieze a weedeater motor after using regular gas
Even if you are able to "unseize" it, it may not run afterwards. The reason you NEED to add oil to the gasoline is because that is the only lubrication the engine gets! You can try to unseize it by removing all of the remaining gasoline from it and putting in ONLY some 2 cycle engine oil. Then you will need to attempt to turn the engine shaft back and forth using the weedeater feed spool as a lever handle. IF, and I say if it breaks loose you may not have sustained alot of damage. If it doesn't...
Jan 10, 2013 | Garden
How do you unseized clutch plates gl1000 75 sat 10yrs creepy in gear
HiClutch not disengaging
Make sure cable has only a couple of mm play. If unable to adjust at handlebars then adjust at clutch endA quick & dramatic way to unseize clutches is to put front wheel up against a wall or similar, bike at 90 degrees to it, front brake on, with full riders weight on seat, in neutral hold clutch in & handlebars straight, rev her up to 3 - 4000rpm, brace your arms & dump her into 1st gearThe shock will generally free-up even a completely seized clutchThe other option is to strip & clean the clutch plates
Ride Safe
Bike-Doc
Jan 08, 2012 | Honda GL 1000 (K1 Motorcycles
Can a seized emergency brake be unseized or do you
You do not need to remove it. Trace the cable back to the rear rotor(s). Grab a pair of pliers and some WD-40. Spray the E-brake cable with WD-40 and have a helper pull the E-brake lever inside the cab. Take your pliers, grab the cable and begin pulling the cable back and forth near the E-brake until it releases. You may have to ask your helper to release the cab lever a few times as you continue to rack the cable back and forth. Fairly easy, however, if the cable is rusty, it may take up to 30 minutes to release.
Mar 20, 2010 | 1997 Ford Explorer AWD
Only the drivers door and drivers side passengers door open. The door handles wont operate inside or out /
chances are the other two other door latches are corroded and seizing remove and unseize is the answer
Nov 10, 2009 | 2003 Ford Focus
Works for a while after spraying mechanism with WD40, but inevitably seizes again. Anyone know what cuses thiis?
Try spraying with white lithium grease or similar after it's unseized. WD-40 is not a lubricant, only loosens rusted parts.
Apr 19, 2009 | Nissan Pathfinder Cars & Trucks
Kicker CVR12 Car Subwoofer Logo
301 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
