Question about Manitowoc Refrigerators
Manitowoc qd0282a only dumps ice every 35 minutes salesman says it is suppose to dump every 15 what can be the problem supose to make 190 plus pounds a day only making about 75 pounds
catriver
  • 878 Answers
SOURCE: Whirlpool refrigerator ED22TEXHW01 ice maker
Tammi, you first want to check to make sure the water inlet tube to the icemaker is not frozen shut. Next, get yourself a jumper wire about 4 inches long with the ends stripped exposing the wire on each end. Pull off the ice maker cover, it will pull right off. Now you are looking at the module. On the module, left side, you will see two test points marked V and L. Insert one end of the jumper wire into V and the other marked L. You are now sending 120 volts to the water valve and water should fill the ice maker providing the inlet tube is not frozen over. If it doesn't fill, you either have a bad water valve or module itself. Also check to see if the clips that hold the center gear on the module are not broken. Catriver..post back.
Posted on Mar 22, 2007
SOURCE: Ice maker not dumping ice
My lady friend has the same problem with her ice maker. The problem is, the ice tray is broken on the end. I took her ice maker out and found out it was broken. Its going to be hard finding a replacement since they don't make parts anymore.
Good Luck !!!
Posted on Dec 02, 2008
SOURCE: ice maker won't dump cubes
the problem is that the tray doesn't eject the cubes, they get stuck and it just breaks them and only parts come out instead of the whole cube/crescent, then the proper amount of water comes in as refill, the tray gets too full and your problem begins. Take the unit out, then take the tray out, its's easy, and give it a light coat of Pam, olive oil or corn oil, the cubes will eject properly. It took me 3 years to figure this out, it willl amaze you.
for everyone with the fan screech noise, replace the fan motor, don't buy the blade, look around the websites, I found it, my second replacement, for 28 but as high as 65.
yeah I hate this fridge too
Posted on Feb 21, 2009
  • 59 Answers
SOURCE: 532 ice maker works, but dumps water into ice container with ice.
Do you still have a manual or can tell me the watts power consumption of the 532?
I'll look into your question. Sounds like a sticking icemaker water valve, but I'll have a look.
Posted on Mar 06, 2009
SOURCE: icemaker will not dump the ice into tray
Make sure that an ice cude is not stuck somewhere in the maker. I had a simular problem and that was it.
Posted on May 01, 2009
My manitowoc model qy0275w is constantly draining. why?
Check the dump valve. Pull the wiring harness off of it to see if water stops dumping, if it dose not stop dumping then replace the valve. If if stops dumping water then you need to see what is causing power to be sent to dump valve this valve should not open until it gets a call from the control board when it goes into a harvest.
Jun 18, 2014 | Kitchen Appliances - Others
Manitowok ID0452A-161 water not draining one water tray is filled causing water to over flow into ice bin melting ice. Need to know where the float switch is and dump valve solenoid. FOR TROUBLESHOOTING
Remove side panel on left. Dump valve and drain hose usually blocked with silt, but may be dump valve coil open circuit. No float switch, water level sensor above tray.
Mar 04, 2014 | Manitowoc ID0452A-161 Dice Cube Air Cooled...
Starts into ice making then dumps ice slurry in tray
Adjust the ice thickness sensor out 1/4 turn at a time until 3mm ice bridge forms between cubes. Clean condenser thoroughly, descale ansd sanitise waterways inside.
Jan 30, 2014 | Manitowoc QY-0214A Self Contained Ice...
Manitowoc sd0602a keeps dumping the water 3-4 minutes after the pump starts, won't terminate freeze cycle or recalibrate. Have changed water level probe, ice thickness sensor and board. I suspect so
Make sure the water fill valve is shuting off for a while after start up . try turning off the water after it fills for one cycle and see if it makes a batch of ice
Nov 09, 2013 | U-Line Icemaker
Manitowoc ice maker
sounds like your dump valve is stuck
Nov 09, 2013 | Kitchen Appliances - Others
If my ice cubes are incomplete from my manitowoc ice machine and I sometimes here them falling early and hitting the bin before it dumps. Is the ice thickness set too thin or too thick? Thanks for your...
The ice thickness is too thin...
turn the screw on the ice sensor IN or clockwise about 1/8 turn at a time till you get the right thickness...give it a couple of dumps before making another adjustment after doing the first one...be careful as the sensor is very sensitive and can be knocked out of wack very easily...
heatman101
Sep 28, 2010 | Refrigerators
Ice machine wont dump ice on sears kenmore side by
Ice forms are 32 degrees but ice maker don't dump till 25 degrees. Get that guy back out there. Obviously you have a bad defrost heater.
Jul 17, 2009 | Refrigerators
Intermittent rattling noise in refrigerator
Do you have an ice maker? That noise could be the ice maker trying unsuccessfully to dump ice, usually caused by a defective heater to loosen the ice cubes prior to dumping them into the container.
Possibly even if your ice maker appears to be functioning normally, it may be attempting to dump ice several times before the ice is actually ejected and if you don't use a lot of ice, you'd never notice it.
Hope this helps.
Jun 27, 2009 | GE Monogram Refrigerator Built-In...
Ice maker not dumping as frequently and cubes freezing one large chunk
The first thing I would check is the cleanliness of the condenser coil under the fridge. Make sure the fan under there is running, and that the coil is clear of dust. The ice maker requires 15 degrees for a period of time before it will make ice and dump. If the temp in the freezer is colder than this, then it is likely the ice maker needs replaced. They can be replaced fairly easily with just a couple tools. (1/4" nut driver and a flat screw driver). There is a plug where it plugs into the freezer side wall, and a bent tube that supplies water to the tray. If not sure what to do, have a service tech look at it.
May 27, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
190 people viewed this question
Top Manitowoc Refrigerators Experts
Tim Whalen
billconfused
Are you a Manitowoc Refrigerator Expert? Answer questions, earn points and help others
