Question about Gateway MT3705 Notebook
No lights, no signs of power, no warning
I have the same issue with my "new" laptop. It was my dad's and he bought it new. I was using it and it died. No lights, no fan, no signs of power or life. Took it to the tech dept at work and we confirmed the power cord has power, the jack in the computer is taking power.
Not sure what specs you need:
Gateway
Model No: MA7
Modem Model Motorola ML3080
White Sticker says:
MODEL:MT6705
(upc lines)
PIN 1MA7A000054
(upc lines)
GWTF1008QQ
Windows Vista Home edition. I had it running for about an hour or so? No hiccups at all. Just finished installing the latest Microsoft updates successfully. Just cleaned up the programs and files that were on there. The computer use was not heavy throughout it's life - my dad is an average to below average usage user, yet technically inclined. I'm very confident no virus or malicious software installs.
I took the battery out, had it plugged in and attempted to do the power flush start...no luck. I can't seem to find the reset - if there is one (Gateway support has a picture but it doesn't match this computer, or well I couldn't find it.)
I have limited hardware repair experience (a beginner elective class back in college years ago) although I am a developer and very comfortable cracking it open.
I am almost positive it's the power IN the computer, after the DC input. I am not familar with the correct terminology of the parts, so please be descriptive.
Thank you so much in advance for any advice direction to take this.
  • mgotelaere Sep 29, 2009
    Tried that, nothing happened. I am hesitant to conclude it's a motherboard issue. Is there any steps I can take to determine if the motherboard is bad?
Replace theac/dc power jack itsa common problem
Posted on Feb 23, 2010
    Scholar:
  • 78 Answers
Well, if you kept the AC power adapter connected when you tried to do the "power flush" then you did it wrong. :) No offense, but you can't have power connected when you're trying to flush the power from the capacitors.
Disconnect AC power and battery. Then press the power button down for about 3 seconds, 10 or 12 times. Then reconnect AC power and try powering up.
Ultimately, it appears to be a motherboard issue. This is not unusual for a laptop that is several years old, no matter how well you maintained it. There also might be a short that has developed somewhere internally, sometimes the protective shielding between the layers of electronics moves. I have a x31 Thinkpad that I had to completely disassemble and reassemble to solve this same problem. Thankfully, it wasn't a mobo problem, just a shield that needed to be moved back into place.
Posted on Sep 29, 2009
I bought a brand new Asus F551M laptop and after a day of using it the laptop just turned off without warning and won't turn back on
Did you charge it properly? Was the battery sign overlooked? If no such case is there, call authorized service center.
Apr 23, 2014 | Computers & Internet
I have had a Cobre 29 LTD Classic, a 29 NW LTD Classic and now a 29 LTD Chrome.It seems that the first two died because of possible bad antenna connections. I was able to calibrate the radios and adjust...
I see two possible problems. First, with a magnetic antenna it is difficult to get the proper ground for the antenna. Make sure the magnetic base is clean as well as where you place it. Second, try running your power lead DIRECTLY to the battery and not using the cigarette lighter. Hope it helps.
Tom
Feb 27, 2013 | Cobra 29 LTD CB Radio
HELLO STAN FIRST HAS THE RADIO BEEN PEAKED AND TUNED? SECOND IS THE INTERIOR LIGHT IN YOUR PICK UP RIGHT BELOW YOUR ANTENNA,IF SO YOU HAVE A PROBLEM BUT EASY FIX THE WIRING GOING TO THE LIGHT ACTS LIKE AN EXTRA ANTENNA CAUSING YOUR ANTENNA TO RESONATE TO YOUR RADIO CAUSING THE A W I LIGHT TO COME ON MOVE YOU ANTENNA BACK A LITTLE FUTHER AND SHOULD BE GOODif you want to get a bettter antenna get a willson 500 mag mount far better
Power adapter issues...
If you can jiggle the the power cord right at where it plugs into the computer and sometimes the green light comes on, that means your DC Power Jack is bad. There was probably nothing wrong with your other power cord. When the DC Power Jack is bad the laptop will not power on if the battery is drained of all of it's power because the Power Cord can't charge the battery.
Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Jun 02, 2012 | Dell Inspiron 1525 Notebook
My dell inspiron 6400 no power at all
If your battery is charging, then i guess it is suffering from Dells Graphics card known issue. Basically the graphics card stops working which also wont let your laptop boot up. A tell tale sign of this being the problem is when you press the power button on your laptop, the power light will flash on for a second then die.... hope this helps...
Apr 06, 2010 | Gateway 7405GX Notebook
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
A105-S4254 is dead!
According of your description, If you already changed the power suply, and the battery, and still no signs to power on, your laptop has some issue at power connector in the motherboard and need to be serviced.
Jan 23, 2009 | Toshiba Satellite A105-S4254 Notebook
Flashing icon at the top right of my Dell Inspiron 6400
seems your battery cell is the one having that issue. try replacing the battery or plug the laptop and let it recharge the battery to full.,
Oct 28, 2007 | Dell Inspiron 6400 Notebook
Gateway MT3705 Notebook Logo
505 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
