My Heater kicks on but doesn't light. The AC Works fine, and the heater seems to work fine but won't light. It doesn't seem to be getting any Gas. I've checked the gas and it is turned on, I leave it running for a few minutes but no gas comes out.
  • c12rober Oct 12, 2009
    I had the Electronic ignitor replaced, and while that wasn't the problem it was in bad shape and needed replacing. The problem ended up being the heat sensing switch and the top of the unit. Apparently it got very hot in the unit and tripped this switch causing it not to light.
    President:
  • 1,187 Answers
One of three things, in this order:
Open the front access door and turn ON the heater.
Does the electronic ignitor turn a bright orange?
If not, then it is the ignitor.
If it does turn bright orange, check the thermocouple.
The thermocouple looks like a bare copper wire that is supposed to almost touch the ignitor.
It senses if the ignitor gets hot enough to ignite the gas.
If the thermocouple is loose or not mounted close to the ignitor, then re-position the thermocouple (it is not electrified; however, unplug power cord before doing this). It is also ok to bend the thermocouple if you are unable to loosen its mountiing bracket.
Plug power back on and turn on heater again.
If it fails to flame, you must call for service. The automatic gas valve is stuck. The valve cannot be safely "fixed", it must be replaced.
I hope its the thermocouple out of place.
Posted on Sep 29, 2009
2000 grand prix, temperature won go from ac to heat, stuck on ac.
Pontiac Grand Prix Climate Control/AC - Car Forums at Edmunds.com
forums.edmunds.com > Pontiac > Pontiac Grand Prix
Dec 29, 2007 - 30 posts - ‎20 authors Hi Joe, I had the same problem with no heat on my 2000 grand prix. .... motor and the exterior temperature sensor have both been replaced ... Pontiac Grand Prix Electrical/Lighting
Aug 3, 2009
Pontiac Grand Prix Heater blower relay switch
May 13, 2009
Pontiac Grand Prix Starting / Stalling Issues
Feb 9, 2008
More results from forums.edmunds.com
Fixing AC Temperature Control on my 2002 Pontiac Grand ...
? 9:58
www.youtube.com/watch?v=2BOdhWMdxXc
Jul 13, 2014 - Uploaded by Turbo231
Fixing AC Temperature Control on my 2002 Pontiac Grand Prix... How To Install Replace AC Heater ...
Oct 15, 2015 | 2000 Pontiac Grand Prix SE
Jandy lt250 heater has air flow message
make sure 24 volts ac on both sides of pressure switch if not replace pressure switch or copper tube is plugged if only 10 or so volts will not keep gas valve open
Nov 21, 2012 | Jandy Laars Lt 400,000 Btu Heater
My Norcold N611 frig code flashes 3 time every few second and doesn't go into A/C mode and will only go into gas mode when the switch is in auto mode and the interior light stays on even when the
The N611 will flash 3 times as an AC heater fault. If your AC heaters are ohming out properly (48 ohms of resistance), then you have a bad power board. If the AC heaters are not showing around 48 ohms of resistance, replace the AC heater. It's going to be one of the two. Here is an article on it:
Norcold Fault Codes AC HE or On light flashing 3 times What to do
Aug 16, 2012 | Refrigerators
I have a richmond 40 gallon powervent water heater. It seems to light, but shuts itself off after about 5 seconds. I am leaning toward the vapor sensor. I know there are reset codes, but have not been...
1) Could be the vapor sensor. That's a suspect.
2) General troubleshoot: clean burner and combustion parts, clean air intake, bleed air from gas line, check gas pressure. Color of gas flame should be clear blue, and flame should be strong, and no combustion by-product dripping back into combustion chamber. No chemicals of any kind stored in air supply. Plenty of fresh air. Water heater in hot attic needs more air. If water heater has igniter, then igniter has to be checked. Flame sensor must be positioned correctly and operational at time of combustion, or sensor will signal gas control to turn off gas. Gas control valve can be bad.
Open following link for possible illustrations and reading.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
3) Specific troubleshoot begins with identifying gas control valve and reading the service manual.
I think the Rheem/Richmond power vent has intellivent gas control
Open following link to identify gas valve and download possible service manual:
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#intelli
4) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 04, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
04 Hond Accord AC blower out
It sounds like your blower motor went out on you,A/C+heater.
Jun 22, 2009 | 2004 Honda Accord
Heating & Cooling Logo
76 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
