Question about Canon PowerShot SD300 / IXUS 40 Digital Camera
Canon IXUS40, rubber(?) seal between lens rings & body keeps popping out
I have a Canon IXUS40. The rubber(?) seal between lens rings & the body keeps popping out. Is this something I can replace myself? It started to happen when I was travelling somewhere extremely hot. I suspect the heat expanded or softened the ring so it became over-sized for the original diameter, or the adhesive keeping it in place melted. Thanks.
  • sandy2007 Jun 07, 2008
    Thank you! I suspected it was mainly a barrier to dirt. Thanks for tips on how to replace it.
  • Canon Master
  • 4,738 Answers
It can be replaced, but requires removing the front face of the camera. Here's an example disassembly. Proceed no further than removing the front face to install the seal:
Not sure where you could find a replacement other than from another (broken) camera. The seal is mainly intended to minimize sand and grit from entering the camera, but is not necessary for operation of the camera.
Posted on Jun 03, 2008
I have a thermos 1 liter flask. I was washing it the other day. The glass part was our of the flask and a rubber seal came off but I didn't see where the seal came from. Please can you tell me where do I...
There is a rubber ring on the bottom of the glass and it holds the glass flask in place in the metal body.I wonder if this is what you describe as a seal.When you put the glass back in its body it should push up to a ring seal at the top.If that is there then I am sure it's the shock ring at the bottom.
Jul 07, 2014 | Washing Machines
FEE keeps popping up on my camera what does it mean
You're using a lens with an aperture ring. Turn it to its smallest setting (largest f/number). You can control the aperture from the camera body, the same way you do with a lens without an aperture ring.
Apr 20, 2012 | Nikon Photography
My lens locked suddenly Canon EF-S 17-85mm f/4-5.6 IS USM Lens on a 20D body
Possible power problem make sure the camera has sufficient battery power and is functioning as it should (less the lens) if this is okay then the problem is between the lens and body gold contacts. It's a quick and easy repair you can do yourself. Shut the camera off remove the lens and put the body cap on the camera if you don't have a body cap place the camera on a clean lint free surface like a glass table or counter top. Use a new clean red pencil eraser to gently rub the gold contacts on the lens. Hold the lens as vertical as possible when you are doing this to minimize the rubber dust getting into the rear lens element. Clean the area of rubber dust with a puffer blower or lens cloth not a tissue. Set the lens down on the clean lint free surface and gently clean the gold contacts in the camera body keeping the camera lens mount down to minimize any rubber dust from getting into the sensor area. Clean the contacts with a lens cloth only do not use a blower/puffer, re-install the lens and it should come on. When installing the lens make sure it makes a solid click and locks securely in place.
Jan 06, 2011 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
I have a canon eos Rebel DXS - I dropped it and now it won't focus.
Normally I'd say your camera is due for a trip to the service department but, depending on the surface the camera was dropped on and did it hit lens first or body. So without knowing let me ask you to do this. Remove the lens and quickly install the body cap on the camera. Hold the lens firmly in a hand and shake it vertically gently but with a little vigor listen for a rattle, stop, do it again horizontally listen for a rattle. If it rattles the lens has internal damage if not and the camera appears to be functioning then I'm going to instruct you on how to clean the gold contacts on the lens and body.
Using a new pencil with a red rubber eraser gently rub/clean the gold contacts while holding the lens almost vertical with the contacts facing down, use a puffer/blower to clear away the rubber dust. On the camera body, remove the body cap and hold the camera with the lens mount facing down as best possible and clean the tinny gold contacts with the red rubber eraser. DO NOT use a puffer/blower or blow on this part to remove eraser dust. Keep the camera lens mount facing down as much as possible and use a lens tissue to clean away any rubber dust. When you have completed this install the lens on the camera and make sure it clicks and locks solidly. Try your camera again, if it works great if not it means there is an electrical break within the camera or lens and it needs to got to a service depot. Hope everything work for you
Jan 02, 2011 | Canon EOS Rebel XSi Digital Camera
Can sigma lense fit to canon av-1 camera body
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Greetings!
Answer to your question is, ‘Yes’ we can. Use Sigma FD lenses.
As we know Canon AV-1 has electronically controlled AE (Automatic Exposure) & has a Canon Breech-lock lens mount.
Original generation of FD lenses featured a silver locking ring at the base. Only that locking ring turns to lock the lens to the camera body; the lens body remains still.
In the newer lens system which was introduced with this camera, the user has to line up the red dot on the lens, with the red dot on the camera and simply turned the whole lens clockwise until it clicked into place.
Note: FD-mount cameras could use FL lenses in stop-down metering mode.
Thank you & have a nice day.
Warm regards,
Feb 20, 2009 | Canon AV1 35mm SLR CAMERA SPARES OR REPAIR...
Chevrolet Equinox how to change the head light
IF it's the headlight's light bulb you want to access to pull out old bulb and install new bulb, here it is:
You know where the 3 bolts that secure the headlight body on the frame, also pull out the 4 black plastic clips that holds the grille-it's located on the top grille brackets (it's close to the top radiator area)
When you pull out the clips, gently pull the grille away from the top frame, then pull the headlight body away carefully to allow your hand to gain access behind the grille/headlamp body, find the wire that connects to the headlight bulb, use your fingers to feel the plastic 'collar ring' around the socket and twist it counterclockwise (just like unscrewing a lid off the jar) and pull the socket out with the bulb.
This space is tight for your fingers so it takes patient to get the job done.
IF it's the ENTIRE headlight body you want to remove it off the equinox (since you mentioned you've removed the 3 screws) there's one more that still holds it down is the black plastic tab that's only accessible inside the fender! So to gain access under the fender, remove the plastic wheelwell liner part located underneath the front-left fender (driver's side) there's a small screw and few plastic clips you'll need to remove it to move the wheelliner liner aside to locate that headlight body's plastic tab on the fender frame, use a plier to 'unlock' the tab out of the hole.
Feb 06, 2009 | 2005 Chevrolet Equinox
E18 error on Canon ixus40 - lens stuck
The E18 error is an error message on Canon digital cameras. The E18 error occurs when anything prevents the zoom lens from properly extending or retracting.[1] The error has become notorious in the Canon user community as it can completely disable the camera, requiring expensive repairs.
A quick internet search for "E18" + "canon" quickly reveals hundreds of similar complaints. reports that the "lens has a feature called bellows claw, which is a gear that physically extends and retracts the lens. A piece that holds the lens, the barrier plate, is not large enough and can sometimes cause the bellows claw to malfunction, resulting in a stuck lens". The result is a black screen that only contains the error message, E18. Another problem mentioned on the site blames a sticky iris in the lens, caused by grease entering inside from the microphones built into the lens. The buildup freezes up the ability of the lens to open.
Nov 13, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Zoom ring is loose and drops/slides on its own
Yes, this happens even when the lens is brand new. Some other lenses have a Zoom lock to prevent it. What I did was to slip a flat rubber band around the black area just behind the zoom ring, the area where there is s white mark or line, with the band ring just touching the zoom ring. The rubber band should be fairly tight, but not too tight. When the zoom ring revolves, the rubber band touching it gives it just enough friction to prevent it from turning. You can adjust it to give as much friction as you want. Hope this helps. Jay
Oct 02, 2008 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Lens is jamed
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
May 11, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Problem during assembly in reverse order on Canon SD300 (Ixus40)
Not quite sure where you are having the problem with your camera, but there are several places on the internet that can help fix your camera and/or lens.
Here is one listing I found on eBay for you -
You can email him your model number and he should be able to help you.
Best of luck!
Dec 20, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon PowerShot SD300 / IXUS 40 Digital Camera Logo
49 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
