Question about Philips AJ3950 Clock Radio
A burnt transformer in my AJ3950/17 clock radio and cd player
To day I tried to buy a new trans former but in the electronic store they can do nothing with the code on the philips transformer so could you help me with the information of the part in general like letting me know
the voltage and the amperage that the radio as mentioned above needs to work properly.
thanks William Coster
Bluehound
  • 25 Answers
SOURCE: Philips DVDR3450H
Put the DVD back into the drive...Then open the DVD menu by selecting the first tittle on the disc....Hold down the up arrow on the remote to make the "Editing menu" appear....Then select "Finalize Disc".
These instructions can be found on page 54 of the instruction book.
Posted on Dec 31, 2007
  • 1779 Answers
SOURCE: Philips LX3600D Home theatre always returns to standby mode
There is a 1ohm resistor on the 4x4 pcb as soon as you take off the cover. ( I forget the ID # ) It supplys the -15volts to the control bd. The resistor will not looked burned. It was under rated. An ohm meter will find it ( open ). Rreplace it with a 1/3 watt. I believe the orig. was a 1/4 watt.
Posted on Apr 11, 2008
SOURCE: need code for philips dvdr3505
I need it too and I cant find it anywhere! I live in southamerica and all my stupid dvds are region 4! Thanx.. my email is inesgallagher@hotmail.com
Posted on May 26, 2008
sorose4u
  • 217 Answers
SOURCE: Need user information booklet for Hilips Big LCD
download it here:
http://safemanuals.com/user-guide-instructions-owner-manual/PHILIPS/AJ3540-37-_E
Posted on Mar 08, 2009
SOURCE: Philips Portable DVD Player PET 730/98 Unlock Code Needed!
Philips PET730/05
Using remote control
Setup
Down arrow
Down arrow
Right arrow
212225 (you won't see anything!)
Left arrow
Down arrow
should now show region code box
Enter 0
Setup to save
Posted on Apr 09, 2009
My Bose radio/cd player (02273c03437299a) seems dead! It's plugged in... No clock, no radio, etc..... What now? A 9 volt battery does nothing.
Various problems may cause no power condition: Dead AC transformer; defective power regulation circuitry; dead microprocessor or display electronics; liquid damage; cracked circuit board; open current limiting resistors .. and more. If needing professional service, Ship radio and contact info to:
CET Services
117 Windsor Ave
Hurley, WI 54534
Their Certified Tech Repairs These Units, average
cost between $100 to 145 plus return shipping to repair all problems,
replace all defect parts, clean inside and out, and adjustments.
Jan 12, 2016 | Bose Audio Players & Recorders
My radio clock stoped working in my 2007 saturn ion. Checked the fuses all are good.
Save yourself a lot of headache, Just replace the stereo. I've have chased problems like this in the past. Just to find a burnt spot in the computer. / that was in a pt cruiser though./ You can get a better than stock stereo for less than $100:00 these days that can also run your I-pod too !!!! .
Apr 21, 2015 | Saturn Cars & Trucks
Is it possible to buy a 220-240V transformer for a Wave awrcc1 to swap out the 110V one?
The simplest thing here is to buy a plug adaptor. Sold at many electronic stores.
Radio shack, The source, ....
Nov 24, 2011 | Bose Wave Radio
WAVE radio transformer bad ???
If you can check ohms,you can also read volts. Open the radio again and look for DC volts on the rectifiers capacitors.They look like :cans", normally the color is blue. Check for positive dc v. against chassis ground. If no + tension,your rectifier or your secondary are open.
Aug 24, 2009 | Bose Wave Radio
Transformer secondary out ???
please my name is dele i have this BOSE radio/cd system model number is AWRC2G which transformer burnt out rightly, that the input is 240volts which output is the problem and in nigria. please i just want to know the output on each coloured wire of the secondary that has 8 wires output from the secondary (2 purple - brn = volt, 2 blue = volts, and 2 black - gray = volts. so that similar that i can use to work it.
thank you
Model #AJ6111-37. Serial #lm100728050845. I have
Is the unit under warranty? If not problably a fuse. take unit a part. main power pcb located on left side towars rear. remove scews holding it and have a look there. these are typically pico fuses labeled f1...f2 etc. Check for continuity with a meter if blown it will say OL if ok should read 0. Fuses and are available at your local electronic store.
Hope this is helpful.
Jun 24, 2009 | Philips Under-Cabinet Alarm Clock Radio...
Magnavox CD Player Clock Radio not working
This Clock/Radio/CD player has had component failure problems. The unit is probably not worth repairing. The reason is the parts and repair information is probably very limited. The cost of the repair with parts and labor will be expensive. This repair would probably cost you more than just buying a new Clock/Radio/CD player. I hope this information helps you with your problem. Thank you for using FixYa and have a nice day!
Nov 15, 2007 | Emerson Smartset Clock Radio
Need help
their is nothing you can do yourself to repair this as it needs a new laser unit but the only thing you can do is take it to tv repair shop and they will fit a new one and get it recalibrated for sorry i couldnt offer you any more help................................
Oct 30, 2007 | Lenoxx Electronics CDR-190 Clock Radio
Transformer in Samson servo 500
check (radio shack)near to you for transformer with same rating.or any electronic store.
Oct 04, 2007 | Audio Players & Recorders
Philips AJ3950 Clock Radio Logo
70 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
