Question about Coleman Powermate Premium Plus 6250W Portable Generator
Looking for shop manual for kohler 9.5kw model 11Rmy home nat gas generator
    Prodigy:
    An expert who has answered 500 questions.
  • Coleman Expert
  • 573 Answers
Email advanced-power-technologies.com they can help you with a manual
Posted on Nov 23, 2013
2 Suggested Answers
FRANKSFIXIT
  • 72 Answers
SOURCE: Coleman Powermate 6250 generator
My answer:
You will need to contact Powermate directly (see below), and give themthe CORRECT model # info that you have there on that Genset.
Unfortunately what you posted above doesn't help out at all as there isNO model # for reference. Certain models are no longer available asthey have been discontinued and only by contacting Powermate directlywill you get the proper Operators Manual.
There should be no charge for this and most likely it will be a PDF download sent by their service dept.
The model # should be found either on the engine decal plate or else on the generator head assy or it's power panel.
Please post me a reply as to finding this solution being the bestresolve to your missing Operators Manual problem by following thecompany references & links below. Also please rate mytroubleshooting fix as well.
Keep me posted and I'll follow up as well.
Best regards,
Frank
Customer Service: US: 1-800-445-1805 Mexico: 011-52-5553-660800 Canada: 1-877-501-0090 Technical Service: 1-800-445-1805 or Email: At productservice@powermate.com and a service representative will personally respond to your inquiry Service Centers: Click here to find your nearest service center in the US or Canada FAQs: Click here to find answers to our Frequently Asked Questions Product Manuals and Parts Diagrams: Click here to find your product manual or parts diagram Register your product: Click here to register your product.
Posted on Sep 05, 2008
My 20kW Kohler home generator (nat gas) cranks but won't start. Definitely getting fuel. Everything checked in October with new spark plug. Maybe a setting?
Did you check the oil level? Some generators have a oil sensor that will now allow it to start if the oil level is too low.
Mar 14, 2017 | Kohler Electrical Supplies
Where is the speed sensor located on a 20resa kohler genset
Kohler Generator issue 20 RES - YouTube
? 0:24
www.youtube.com/watch?v=CT9u64dZna0
Apr 28, 2012 - Uploaded by Jeremy vanEyk
Brand new Kohler Generator Test cycle issue. ... Oh, and Mike, good call on the carb--that happens on some 20RES models. ...Indicates Locked Rotor (Lr). ... I'm on my second 20 RES-L,home depot swapped out the 1st one. ... Kohler 20KW RESA Whole House Standby Electrical Generator - Duration: ...
May 19, 2015 | Kohler 20resa 20kw Home Emergency Backup...
WHAT WOULD CAUSE A AUX FAULT ON A KOHLER GENERATOR MODEL 80ROZJ
Aux fault can be many things, if it failed to start you may get it. Try reseting and manually starting. See if it re-occurs while it is running or does it ever start and give error. I have seen this generator by a coolant level sending it is an auxillary fault
May 09, 2014 | Kohler Generator 30 Kw Nat Gas Or Propane...
WHAT IS THE MOST LIKELY CAUSE OF AN AUXILIARY FAULT ON A KOHLER GENERATOR MODEL 80ROZJ
Check radiator coolant fill right to the top, if it has a low level switch or faulty switch I have seen this
Kohler Generator won't start
If you have a drip leg near generator open that up for a sec and then try it again.
Nov 16, 2012 | Kohler Electrical Supplies
Kohler 11rmy-q53 generator. Generator starts and runs a vew minutes and shutdowns. When dry weather it is ok. When it rains it doesn't run long before shutting down.
The first thing I would do is to clean and dry air filter. If it is a foam material you can use a warm water and a few drops of dish soap.Rinse thoroughly and let dry. I also would try a small amount of octane booster in my gas. Hope this helps you.
Nov 29, 2010 | Kohler Electrical Supplies
What is he avrage price of this system
depending on what accessories you get and the fuel type like gas diesel nat gas propane it can run a couple thousand dollars plus the install as well if city permits required it is hard to say hope this helps shop around and have it installed by someone you trust or certified bonded and insured so there is no risk of a home fire good luck.
Aug 28, 2010 | Kohler 17 kW Emergency Power System -...
My Kohler 11RMY (40 amp) standby generator will not start
You should have two wire remote Start/Stop. It may need to be shortened in order to start.
Jun 06, 2010 | Kohler 12 kW Emergency Power System -...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
176 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
