Question about GE Dryers
My GE select dryer all of a sudden doesn't dry a load of clothes in the same amount of time. It takes almost twice as long.. why?
  • 304 Answers
This is likely the result of an air flow problem if you are sure the heater is working properly. Ensure you are not running the dryer in a closed room which would starve the dryer of air dramatically reducing the air over the clothes even if the full length of your vent is brand new. Next, remove the vent hose from the rear of the dryer and check for strong air flow at the outlet. If it seems strong enough then run a vent through a window or out into another room and do one load in this fashion. If this resolves your problem the blockage exists in the vent line outside your dryer and disassembling dryer becomes unnecessary.
If not, ensure you have seen and touched every inch of interior dryer piping and hold the lint filter up to the light to be sure you can see through it. Disassemble and clean ANY section of piping you can't get your hand into. The area below the lint filter tends to catch a lot of lint and can only be accessed by removing the housing at the rear on the left side as you face the rear. Ensure the blower wheel turns when the motor turns. (Newer models may have the filter housing at the front)
Having performed all these actions will likely resolve the problem.
Posted on Sep 29, 2009
GE Dryer DBSR453Eb2WW takes twice as long to dry clothes
A clogged or partially clogged vent will reduce the air flow through the dryer and greatly increase the drying time. I assume you checked the drying time again after you cleaned the vents. Have you also checked that the lint trap is clean? Make sure no lint has found it's way around the lint trap and has jammed the intake.
I would be very suspicious of the 240 v breaker double breaker feeding the dyrer; maybe the dryer is only running on 120 vac instead of the full 240vac. The motor would be getting full power, but the heating element would only be getting half power.
Mar 26, 2013 | Dryers
I have A ge DBXR463ED2WW .it takes about 80 minutes to dry A load.dryer seems to only have A fourth to half heat.
This could be the clothes are coming out of the washer wetter than normal, or poor air flow. 80 min in a little long but a lot depends on the wetness and amount of clothes. If the vent system is clear then I would try smaller loads and checking the washer.
Eric
Jul 21, 2010 | GE DBXR463EDWW Electric Dryer
Dryer not drying in alloted time
there is a thermostat. it usually is located on the heating element housing
May 26, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My dryer takes 2 times as long to dry a load
make sure u have proper venting...your vent pipe might be crushed or clogged...to many bends in the pipe also reduce the efficiency ...Good luck
Apr 04, 2010 | GE DWSR405EBWW Electric Dryer
Dryer is not drying clothes.
well im not going to look up the model # to see if its gas or electric,but check the exhaust tube for blockages
Apr 21, 2009 | GE DBSR453EBWW Electric Dryer
Dryer isn't getting as hot as it should, clothes take twice as long to dry
clean out your wall vent,dryer hose and lint trap that should do it,what happens if you have a clogged vent the dryer keeps the wet hot air in loner and it take twice as long to dry-mike
Apr 20, 2009 | Dryers
Dryer taking too long to dry clothes
Hello :)
Very common problem. You need to call a
duct cleaning company and tell them to clean
your dryer vent. Rule-of-thumb: dryer vents
should be cleaned every couple of years to
prevent them from being clogged with lint and
causing lint fires. This is definitely your problem.
Good luck :)
p.s. one way to verify a clogged vent is
to go outside where the vent exits the house
and feel the air-flow. should have adequate air-flow.
Apr 03, 2009 | GE Profile DPSB620ECWW Electric Dryer
Wet clothes take two 'trips' to dry.
UNPLUG THE DRYER THEN PRESS THE MORE TIME , AND THE LESS TIME BUTTONS AND THE POWER BUTTON FOR ABOUT 10 SECONDS. THEN WAIT FOR 3-5 MINUTES THEN PLUG THE DRYER BACK UP . SEE IF THAT WORKS BY THAT RESET.
Dec 01, 2008 | LG DLE2514 Electric Dryer
Dryers Logo
111 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
