Question about General Electric Stove/Oven/Range Chrome Timer Knob Set - WB3X459
How do I replace door handle end cap on model JGBP34GEP3AD
    President:
  • 3,085 Answers
The liner on the inside of the door has to come off by removing the two large screws, you can probably just pull the liner back to get to the end cap screw.
Posted on Oct 28, 2009
2006 Mercedes 560 SL interior door handle
1st you need to open door, remove plastic trim on inside of door by the handle, there is a hole where a 25 torx screw is holding handle end cap, pull door handle in open position, slacken screw until end cap is loose, remove end cap & slide door handle to rear of door out comes the handle, check with torch for any broken parts
Feb 11, 2015 | Mercedes-Benz SL-Class Cars & Trucks
I have a side by side samsung fridge freezer and it wont fit through my front door can you remove the door handles?
See if the end caps will pry off of the handles and see if there is a screw holding it on. You need to post your model number for more specific info.
Feb 14, 2011 | Samsung 24.8 Cu. Ft. Side-by-Side...
I need to know how to remove and replace the door handles on my Kenmore side by side Frig model number 106.9555752. Would prefer a site to download or read the manual on how to do this.
Hi!!
To remove the door handles on your unit, all you need to do is remove the handle end caps using a small screwdriver or similar object and the two 5/16" hex-head screws. same for both doors. Click on the following link for door diagram. http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/10042576-00006.png
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Nov 12, 2010 | Refrigerators
Interior door handle right side
first you need to order a new handle and trim ring, 2 separate pieces. beige or grey are your only choices. www.tnaautoparts.com cheapest and only one i found that caries beige. i did both front doors for 25 dollars total including shipping. Remove door panel, 2 screws under round plastic caps that pry out and off, 2 screws at bottom, 2 lg screws in middle handle, 1 plastic retainer in side that prys out, 1 screw under square cap in the center of the trim ring. remove black plastic triangle shaped piece near the mirror, prys off easy. grab door panel and pull out then lift up. leave wires attached and let panel hang loose. remove screw from old door handle. remove linkage from handle and from lock. connect linkages to new handle and lock (look carefully at the old one before you remove the linkages) , install the last screw you removed to hold lock in place while you check to if everything works. when i finished mine neither door would open from the inside. i had to take pliers and slightly bend the linkage at the elbo's to shorten the travel distance. check this before you put everything back together by just putting the door panel back in place down fist then in, window down, close door, reach in and open door, if it doesn't open bend linkage and try again. when you are sure everything is ok install all screws except the one that was under the square plastic cap in the trim ring. to install trim ring look for notch on back side toward front of ring, push ring in notch end fist, back end slightly out, when the front end is in and seated push the back end straight in. install screw and push cap in. this job is not as hard as it sounds and will make sense when have the panel off and can see.
Nov 07, 2010 | 1998 Toyota Camry
Door Handle coming loose
Hello,it would depend on the brand of appliance,its model number and how it was designed.In many cases the door may have to disassembled to access screws or nuts holding the handle ends.If the end caps which the screws or nut fasten to are stripped,the handle may need to be replaced.
Thanks
May 27, 2010 | Ovens
My samsung SMH7187STG microwave handle broke off.
You can order new "cap handles" (the plastic parts that join the aluminum handle to the door for 3.99 each plus 8.99 shipping and handling at the Sears Parts Direct Website. The part number is DE67-00222C. When you have the parts in hand, open the microwave oven door. On the inside surface of the door their is a black plastic frame around the door that pops off easily (gently use a screw driver to pry up the door frame) so that you can have access to the screws that attach the end caps to the door. You will need to hold the remant of the cap handle (the part that is probably broken off even with the glass surface on the outside side of the door) still while you unscrew the screws. Once the screws and broken remnant of the handle caps are out, you are ready to put new handle caps on the handle, then put the handle with the new handle caps on the door. By the way, Samsung was absolutely NO help with this. The agent I chatted with denied that their were any reports of the handles breaking off, so I had to cut and past the postings about the door handle breaking off ON THEIR OWN WEBSITE under "Community Q and A" into the chat box -- still the agent did not acknowldege the existance of these reports...or the possibility of a poor design. I asked for them to send me a couple of the $4 parts as a good will gesture....got nothing but lofty words about Samsung commitment etc. and only a authorized technition blah blah, no action. All you need is a strong thumbnail, a phillips head screw driver, new handle caps.
May 02, 2010 | Samsung 1.8 Cu. Ft. Over-the-Range...
REFRIG. DOOR HANDLE GETTING LOOSE
Hi, look at the ends of the handles and see if there is an end cap that can pop off. Sometimes there is a cap the whole length of the handle. Pop off the cap and there should be a screw holding the handle on.
I hope this helps you. If there are no caps, get me a model# and I can look this up for you.
Thanks
Vic
Jun 20, 2009 | Refrigerators
Change refrigerator door handle
Hi, look at the ends of the handle and see if there is a cap you can remove. It looks like there is a screw behind the end caps.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 05, 2009 | GE GDS18LBP Bottom Freezer Refrigerator
Refridgerator door handle
The entire handle slides upward and out to detach from the door. There are two screws attached to the handle which can be tightened once the handle is off. Those screw heads are what reattach the handle to the door by sliding them through the door bracket opening, where they follow a short channel down leaving the handle secured again.
Dec 30, 2007 | Whirlpool Gold White-on-White 21.9 cu. ft....
General Electric Stove/Oven/Range Chrome Timer Knob Set - WB3X459 Logo
122 people viewed this question
Top General Electric Hardware & Accessories Experts
jdthefixer
Craig Butler
Craig Butler
Are you a General Electric Hardware and Accessory Expert? Answer questions, earn points and help others
