Question about Kenmore Elite HE4 Electric Dryer
I have a kenmore he4 no. 110.85871400. i have no heat replaced thermal fuse high limit thermostat anf thermal cutoff switch. still ni heat. elements are good. cleaned all lint. do i need to get a thermistor allso
    Scholar:
  • 103 Answers
Check thermistor with ohm meter, make sure you unplug unit first, make sure wires are removed from thermistor or you will read ohms thru the wiring. If thermistor checks ok, the you have a relay board problem. replace power board.
Posted on Oct 01, 2009
Kenmore dryer model # 110-60212990 heater element not working. replaced element, thermal fuse, thermal cutoff
Hello
Check high limit thermostat continuity. If ok ,Check for voltage at thermostat side of the heater element.If voltage present timer ok.Most likely centifugal switch at motor.Motor has to be running for element to work.
It's all fixable!
Jul 28, 2011 | Kenmore Dryers
Kenmore elite model 11062952100 My dryer will not heat I replaced The thermal cutoff and high limit thermostat the dryer produce heat briefly but is not producing heat again.
There is a high limit switch (looks like a button with two wires hooked to it) on the bottom of the vent frame. When the vent fills up with lent at the bottom it gets hot. For safety, this limit switch will turn heat off. Remove the vent frame and clean it out and check the continuity of the switch. Also, make sure both heater elements are working properly.
Jun 19, 2011 | Kenmore 63942 Dryer
No a kenmore 80 series dryer will not heat . if the heating elment is good & fuse is good what else could be the problem
The heating circuit is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The problem is very likely in the thermal cut-off and the high-limit thermostat located on the blower housing. The thermal cut-off blows when the high-limit thermostat fails and cuts power to the heating element. Both the thermal cut-off and the high-limit thermostat need to be replaced if the former is blown open. Click on the link below for the detailed instructions in troubleshooting this kind of problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Mar 09, 2011 | Kenmore Elite HE3 Steam 8676 Dryer
Kemore dryer model110.67522600, checked continuity on heating element,OK, Thermal fuse OK,cutoff-tml ? Thermostat #3977767 no continuity.Thermostat #3387134 ?
Both the high limit thermostat #3977767 and the operating thermostat #3387134 are normally closed switches and should have continuity. These thermostats are usually replaced as a set because when one fails its often caused damage to the other. The part # for the kit is 279816 and comes with both and is cheaper than if bought separate
Sep 16, 2010 | Kenmore Dryers
Replaced elements but does not heat in bowl
Check the thermal cutoff located on the element.  It is designed to blow if the element gets too hot.  If the thermal cutoff is blown, the hi limit thermostat (also located on the element) will also need to be replaced.  It will have two terminals on it and if it is good it will have continuity.  Trace the wires back from the element.  The first one it comes to will be the thermal cutoff, next will be the high limit thermostat.
Nov 07, 2009 | Fisher and Paykel Dryers
Runs, doesn't get hot
Either your element is out our your thermal cutoff.  Check your element for continuity if it is open, replace the element.  If not check the thermal cutoff which is on top of the element.  If the thermal cutoff is open you will also need to replace the operating thermostat and Hi limit thermostat.  The high limit is on the element below the thermal cutoff, and the opperating thermostat is on the exhaust duct.
Oct 25, 2009 | Kenmore Dryers
Clothes dryer not heating
I eventually changed the thermal cutoff switch and the high limit thermostat as suggested in one of your replies to another consumer and now the dryer is working fine. Thanks.
Nov 13, 2008 | Zanussi TC7114W Electric Dryer
Whirlpool Dryer Thermal Cutoff Wiring
the thermal cut off wires do not matter how you put them on.. The high limit is wired in series with the heating element.one red thick wire to element the wh/red top side of the high limit stat out of the high limit sat(other side) then goes to the other side of the heating element
Feb 20, 2008 | Dryers
Kenmore Elite HE4 Electric Dryer Logo
495 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
