Question about Kirby Ultimate G Bagged Upright Vacuum
Making a burning smell...not working as it should
I have had the Kirby Ultimate for about 5 years now and it's worthless! The belt will not stay on and it smells like burning rubber when in use. We even replaced what was supposed to be a brand new belt with another brand new belt and the same problem existed! Consumer Reports should always be checked when dealing with anyone trying to sell these things door to door! Give me my old Electrolux ANYDAY!!
Posted on Oct 03, 2009
  • 3 Answers
Remove the brush roll clean the brush end bushings and replace with a new belt
Posted on Sep 29, 2009
Burning smell Kenmore 50558
If the burning smell is an electrical smell it could be motor or wiring problems which are best handled by a professional. If it smells like burning rubber it is probably the belt. If it smells like burnt wood it could be the belt slipping on the brush roll, if the brush roll is made of wood. Dust and debris can also accumulate behind the end caps of the brush roll causing friction which can cause a burning wood smell.
Mar 30, 2014 | Kenmore 5055, 50557 and 50558...
I have a steam vac spinscrub carpet cleaner works good but it just started smelling like it was burning and started to smoke
Anytime someone says they smell something burning on any type of vacuum cleaner of carpet cleaner etc. All I can think of is the belt is rubbing on plastic which would cause the sense of something burning because you possibly are smelling the belt........
Mar 12, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Burning smell
The motor is burnt out. Good news is that most central vacuums are really easy to get into so replacing the motor shouldn't be too hard. I haven't worked on that exact machine but the fault is unmistakable.
Jun 26, 2013 | Electrolux Central Vacuum
Electrolux cylinder vacuum No suction and loud noise and smell of buring rubber
rollers are probably stuck the belt is burning check for restrictions in you hoses as well as in the vacuum as well if nothing else works a repairman
Jul 13, 2012 | Vacuums
Work well but smell like a burning belt
If it smells like burning rubber, the belt is probably worn and slipping. If it's another burning smell, your motor windings are probably shorting and will burn out soon
Oct 12, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Vacuum smells like something is burning
Ok...Check the brush roll is free not sticky..Next is the belt okay, not jamming on the brush roll making the burning smell...You could take off the roll and run motor on its own ..finding out if its the motor..
Apr 13, 2010 | Bissell Healthy Home HEPA Bagless Upright...
The motor makes a weird sound and starts to heat and smell like something is burning
If the motor sounds scratchy and is making a burning smell, or sparking you will need to replace the motor or the entire vac. Carbon brushes will rarely fix this as it is a high RPM motor
Sep 04, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Our vacuum smells like burning rubber. Does it
Burning rubber smell means the brush belt need attention. Make sure the brush is turning freely and replace the belt
Jul 05, 2009 | Eureka Vacuums
Sebo x1.1 - burning smell
Try replacing the belt. My vacuum cleaner had the same problem and once the belt was changed the burning smell was gone.
Jun 10, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Burning smell and smoke
When you turn it on....is the belt turning the brushes? Something may be caught causing the brushes to stick and the belt to just grind the brush assembly.
Jan 03, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Kirby Ultimate G Bagged Upright Vacuum Logo
234 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
