Question about Baby Gear
2002 xr6 rear seatbelts
They are not retracting why?
  • ferro Dec 21, 2007
    Thanx buffalo will let you know how i go
  • ferro Dec 24, 2007
    thanx buffolo let u know how i go merry xmas
  • 625 Answers
One end of the belts are fixed, the other end has a flat tempered spring wound around a spool. on the end furthest against the spool is a tang that hitches into the spool. this is probably broken. take apart the retractor and you'll see what I mean.
Posted on Dec 18, 2007
Rear seat belt is not retracting. Repair or replace?
Replace if a seatbelt stop retracting the gears r messed up and will not protect in a crash
Aug 17, 2015 | 2002 Hyundai Accent
Seatbelt will not extract on driver side
There should be a mechanism in the door jamb near-to the seatbelt. If equipped, push on it while jerking seatbelt until it retracts. If not equipped, close door firmly while jerking seatbelt to activate retract.
May 09, 2014 | 2004 Mazda 3
2002 tahoe back seat seatbelt is twisted and won't retract. The bolt holding the paneling on that covers the pulley is stripped and wont come out. Looking for two solutions: how to get that screw
TO get that screw out you need to use a tool that looks like a nail puller and you put it under the screw head to lift while you unscrew it. Once you get to the mechanism for the seatbelt, you should be able to free it because it will he able to have slack and the dogs will loosen up. Be mindful of airbags and seatbelt tensioners that are in that area though
Jan 28, 2013 | 2000 Chevrolet Tahoe
I have a 2002 Chevy Tahoe and the 3 point seatbelt on the rear passenger side rear seat has been pulled out all of the way and now it won't retract back into it's holder. Is there an easy wa
The re-tractor is called an Inertia Reel. There on the side, remove the cover and there is a trigger release on most. If the spring is broken, you will need to replace the reel. Check at a local junk yard for the best price.
dc don
Sep 03, 2012 | 2002 Chevrolet Tahoe
2002 Mazda Protege5. While changing rear struts, the rear seatbelts had to be unmounted. I allowed the seatbelt to retract and now it will not extend (only retracts/takes in) far enough to mount it back....
Hi, these retractors or sensitive to direction so that if the are not sitting properly they will not release. as if in a roll over situation. try holding the retractor at the angle at which it was mounted and then apply slight tension on the belt pulling out. Don't take the plastic covers off or the spring inside will come a part and you will be buying new belt assembly's
Aug 27, 2010 | 1999 Mazda Protege
I have a 1997 Ford Escort. The rear seat belt is stuck
make sure that the rear seats are properly locked into rear catches as this can stop your seatbels from working if ok then sounds like your seatbelt is faulty req new seatbelt.
Mar 07, 2009 | 1997 Ford Escort
99 maxima rear drivers side seatbelt does not retract.
Inertia reels get stuck permanantly if pulled out suddenly over time or after an accident. You may be able to remove it or pull lightly out with little tension and tap on it, if not you may need to replace the inertia reel.
Jan 06, 2009 | 2000 Nissan Maxima
My driver and passenger seatbelts wont retract.
return it to the shop. they are obligated to correct that safety issue.
Jan 03, 2009 | 2002 Dodge Stratus
Rear center seatbelt won't release
follow the belt back to the anchor point there could be somthing stuck in it or you should be able to undo it if you remove the plastic cover and look st the way it works.joe
Nov 24, 2008 | 2002 Volkswagen Jetta TDI
2002 Toyota Solara Convertible seat belts not retracting
The front seatblet retractor springs have weakened. Unfortunatly, there are no "user serviceable parts" on them. They would have to be replaced. How many miles is on it? If you have low mileage, the Toyota Customer Experience Center may provide you some assistance, as the belt replacements are quite expensive. I'd call the CEC and explain your dilemma. Here is the number: 1-800-331-4331
Sep 22, 2008 | 2002 Toyota Camry Solara
Baby Gear Logo
93 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Marvin
Marvin
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
