Question about Danby DWM99W Top Load Washer
My washing machine only spins sometimes and also smells like burnt rubber if I leave it on.
Tub not spinning
tub will not spin, smells like it is burning
Aug 16, 2012 | Speed Queen AWN412 Top Load Washer
Smokes on final spin
door gasket. pain to replace. clean stainless steel drum where it contacts rubber before installing a new one. I used baby oil and very fine steel wool.
Dec 12, 2011 | General Electric WCVH6800J Front Load...
My machine is a maytag LAT2300AAE on spin cycle it will not spin and makes a noise and can smell burnt rubber what is wrong? Also how do you open it to check it out? thanks
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 14, 2010 | Washing Machines
Whirlpool wash machine stopped spinning , motor stopped water did not leave- smelled of rubber
pump/or basket not spinning causing the belt not to turn thats the reason why is smells like rubber check pump and basket for free turning
Dec 09, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machine has burnt rubber smell
your problem is probably the coupling that ataches the motor to the transmission , take the skirt of the washer off , take the motor off and you going to see the rubber coupling if is bad just change it , cheap part
Jun 18, 2009 | Amana LW8203
Burnt Rubber smell and spin cycle didn't work
the main motor needs to be serviced , sounds like the couplings broke , hope this helps , AJ
May 18, 2009 | Maytag Dependable Care LAT9416
Washing machine was making noise when agitating & spinning
This sure sounds like a bad transmission. Turn the transmission by hand to feel and listen to it. It should be smooth and quiet.
May 04, 2009 | Maytag PAV2300 Top Load Washer
Danby DWM99W Top Load Washer Logo
317 people viewed this question
Top Danby Washing Machines Experts
shaun taylor
Samyfam
Samyfam
Gerry Harvey
Gerry Harvey
Are you a Danby Washing Machine Expert? Answer questions, earn points and help others
