Question about HP PSC 1510 All-In-One InkJet Printer
My printer has trouble grabbing the paper from the tray to print. I have to feed it one page at a time with my hand. very annoying.
    President:
  • 1,187 Answers
The pickup rollers need cleaning or there is too much paper in the tray (paper lift spring not strong enough).
Clean the pickup rollers on the tray with Q-Tip / 70% alcohol ... or lens wipes (for glasses and monitor screens).
Use less paper in the tray for now.
Posted on Sep 29, 2009
My HP P2015DN only prints one page at a time. If I have a 5 page document, the first page prints and then I must print the go button for each page to print.
Is the paper feeding from the manual tray or tray 2. If you are printing from tray 2 and have this problem then it is likely that your driver or software is looking for different paper types than you have loaded in the printer. For example, if you have plain paper in tray 2 and your software wants to print on letterhead, then the printer will stop after each page and by pressing the button you are telling the printer that it is ok to print on different paper. If you have the paper in the manual feed tray (tray 1) then I would check to make sure you are telling the pirnter to print to tray 1 and not manual feed when you send a print job.
May 02, 2011 | HP LaserJet P2015dn Printer
Oki c810 printer is having constant paper jams and tray not feeding paper at all
Your paper is too smooth for the rubber rollers to grab it.
You need to wet the rubber rollers. Ever licked your finger in order to turn a page in a book? Same concept solution here.
Remove the paper tray. Take a look inside the space created where the tray was, and locate the rubber rollers. Lick your fingers, and use them to moisten the rubber rollers.
Reset printer and print again. Or try "un-smooth" the paper where the rollers grab it.
Oct 05, 2010 | Office Equipment & Supplies
Paper not feeding through from trays
Sep 10, 2010 | Brother MFC 6490CW InkJet Printer
Question re: test page
i have this printer, what you have to do is when you power it up, wait and listen until the printer grabs the paper to do the test print, then quickly press the CANCEL button once, the paper will pass through the printer but not print, then just put the paper back in the feed tray and start your day with a smile. The cancel button is on the left hand side underneath the power button. The printer prints a test page when you change ink cartridge as well by the way.
Apr 26, 2010 | HP PSC 1350 All-In-One Thermal Printer
I cant get the machine to grab the paper and it says its out of paper, yet its not out of paper.
Hi, the Ip3000 has 3 different feeding trays...
make sure that the printer is trying to "grab" the paper in the tray that you have chosen to use in the printer properties box...
when you give the print command can you see the rubber roller moving to grab the paper in the top feeder tray???
if the roller that feeds the printer is not moving you may have accidentally changed the settings to grab paper from the bottom tray...the one right under the door that opens to let printed pages out of the printer...
the 3rd feeder tray is the DVD/CD printing tray...
I suggest that you look at the printer Properties for remedial action...
hope this helps you with your problem...
cheers
haitchhcee
p.s.
suggest you place paper in the bottom tray before making adjustments to see if it is trying to grab the paper from there...
Dec 08, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Paper feed grabs more than one sheet
Try fanning your paper several times. Take that nice neat pile of paper in your hands and wiggle it so that your thumb fans through the edge of the whole stack. Do this on both edges so that the stack of paper is slightly less perfect. You can also gently fold the whole stack slightly in both directions. Do this every time you add fresh paper. It should only take a few seconds.
Apr 21, 2009 | HP Hewlett Packard Officejet Pro L7680...
Magicolor 2400w won't feed paper
CLICK HERE for the manual
See page 55 for cleaning the media roller.
Jan 26, 2009 | Minolta magicolor 2400W Laser Printer
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
Printer will not feed paper / message E2 ...cannon pixma mp 160
don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
someone replied to my problem, i tried it and its fixed 1st time, for others its taken a few attempts and then worked..
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving PUSH it through! and hey presto it worked for me, everything printing fine now. hope this helps, let me know how you get on. Garty
May 08, 2008 | Canon PIXMA MP160 All-In-One InkJet...
HP PSC 1510 All-In-One InkJet Printer Logo
135 people viewed this question
Seeker5211
Seeker5211
