Question about Brother MFC-8840D All-In-One Laser Printer
It says Doc. cover open
Doc. cover open
2 Suggested Answers
Soulvisitor
  • 1113 Answers
SOURCE: doc cover open
Yes there is and I know your problem have a look at the left hinge on lid that you lift to put down an original for copying, it will be breaking apart, the switch is black in that same corner on doc feeder base, as the hinge breaks apart the doc feed lifts in that corner causing "doc cover open" cause that switch no longer gets pushed in when lid is shut
Dodgy repair - tape switch closed, but doc feeder will not work properly/can use glass.
Repair - Easy removal of three screws and replacing 20buck hinge bought from brother dealer...part no.LE8731001 Hinge assy left.
Now that's FIXYA!
Posted on Nov 19, 2007
WONT MAKE A COPY IN TOPFEEDER
Check the connection of the doc feeder to the copier. if you open a cover on the doc feeder does reflect on the copier? Ensure the doc feeder is aligned there is a small magnet right front side of the doc feeder that sits on top of a switch (Can not be seen underneath front plastic the copier when down. Adjustment bolts for the doc feeder is the rear right hinge only.
Mar 21, 2014 | Konica Minolta Bizhub C253 With Document...
Tip
Main Error MINOLTA DI 1611, DI 2011 Messages and Their Remedies
PAPER JAM A paper misfeed occurred in the
main unit.
Open the cover at the indicated
location, and then remove the
misfed paper. (“When the Message
(Flashing alternately)
OPEN XXX SIDE COVER
All misfed paper was not removed
from the main unit.
Check the message in the display
for the location of the paper misfeed,
and then remove the misfed paper.
ORIGINAL DOC.JAM A paper misfeed occurred in the
Document Feeder.
from the Automatic Document
Feeder.
Open the Document Feeder Cover
and the Document Feeder, and then
OPEN DOC.FEED COVER
∗REMOVE PAPER IN
BYPASS TRAY∗
Paper is loaded in the Manual
Bypass.
Remove the paper from the Manual
Bypass.
FRONT COVER OPEN The Front Cover of the main unit is
open or not securely closed.
Securely close the Front Cover.
CLOSE FRONT COVER
DUPLEX COVER OPEN The Duplex Unit Cover is open or
Securely close the Duplex Unit
Cover.
CLOSE DUPLEX COVER
DOCUMENT COVER
OPEN
The Document Feeder is lifted up
(while a document is loaded into
it).
Securely close the Document
Feeder.
CLOSE DOCUMENT
COVER
DOC.FEED COVER OPEN The Document Feeder Cover is
open.
Feeder Cover.
CLOSE DOC.FEED
COVER
TONER EMPTY The toner is empty. Copying and
printing cannot be performed.
Replace the toner bottle with a new
one.
SUPPLY TONER
PAPER EMPTY The selected paper tray has run
out of paper.
indicates the paper tray, and
“XXX” indicates the paper size.
Load paper of the specified size into
the specified paper tray.
on Dec 18, 2009 | Office Equipment & Supplies
Tip
Doc feeder Nogo/ Doc cover open?
If you can use the glass and can print, but you cant fax or use doc feeder, then have a look at Left hinge it will be cracked, If you push down on left corner you should be able to use doc feeder when in that position
Here is part that breaks on every machine.
Here is link to purchase one for $25 bucks, three screws and job done, easy fix!
on Dec 24, 2007 | Brother MFC-8440 All-In-One Laser Printer
Bizhub 211 - doc cover open
Something is open. Check and make sure you closed everything securely.
May 30, 2012 | Office Equipment & Supplies
The error message says Doc. Cover open but the cover is closed
You will probably have a broken hinge at the back left hand side of the Doc. cover.
This means that the cover won't close properly at the back corner, and the cover sensing switch won't actuate.
Dec 08, 2009 | Brother MFC-8840D All-In-One Laser Printer
Dcp 8045D laser printer error say doc cover open, I don't no what is a doc cover, and the manule the machine came with can't be found
The document cover (or lid) is the large part that you pull up (open) when you want to scan a single page using the "flatbed" part of the scanner instead of the automatic document feeder (AFD).
There may be something under the lid that is holding it up slightly open.
Lift the lid and close it...
It should work, now.
If NOT, Turn OFF, unplug from outlet, wait a few minutes and plug back in.
Hope this helps!
Sep 10, 2009 | Brother DCP-8045D (Bundle) All-In-One...
My Nikon Coolpix S5 has a broken lens; it son't fully close/ open. The message displayed on the screen says "Lens cover error". Is it something that can be repaired? How much would it cost to fix...
Hi , The lens cover error is because the stepper motor in the camera is unable to open the lens cover. I have a solution posted in doc "nikon s5 s6 lens cover error repair.doc"  uploaded on site http://www.esnips.com/web/papputatiyasStuff    It will be helpfull for you. You have written that your lense is broken. In that case you can follow the procedure given in my doc to open the camera. You can replace the camera lens if broken.
Happy debugging Mukesh
Jul 01, 2008 | Nikon Coolpix S3 Digital Camera
Doc. Cover Open
Broken left hinge stopping doc cover switch in left corner activating
53b706a.jpg Here is link to purchase one for $25 bucks, three screws and job done, easy fix!
Jan 29, 2008 | Brother DCP-8045D (Bundle) All-In-One...
Doc cover open
3 screws easy fixf5f7046.jpgno tec needed bout 25 bucks for hinge see my other post re this problem 8025, 8820,8840,8225 same same
Dec 26, 2007 | Brother MFC-8840D All-In-One Laser Printer
Doc cover open
Now that's FIXYA!
Nov 19, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-8840D All-In-One Laser Printer Logo
83 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
