Question about Garden
I'm looking for the spec on the magneto gap to the flywheel of a briggs & stratton 5 hp -
  • 2,418 Answers
Use an old shool match book cover, Thats all the gap I have ever used.
Posted on Sep 29, 2009
What is the gap between coil and magneto
I use a piece of A4 copy paper to set the gap.
Apr 05, 2015 | Garden
Need magneto gap specifications between the flywheel and magneto.
I don't know the specs, but a business card inserted between the two always works for me.
Oct 12, 2014 | Garden
What is the correct gap between the magneto core and magnet?
The gap is .010. You can also use a card to gap the coil and after you tighten the coil and remove the card turn the flywheel by hand one revolution to make sure the magnet does not rub on the flywheel.
May 30, 2014 | Briggs Stratton H7159 & Stratton® 5500,...
I have a Sears 18 HP BS 31P777 Just got a long block moved every thing over and it will not turn over I get a spark on the plug and a backfire every once in a will but thats it Things I will check...
a simple way to set the gap is to use a couple of regular business cards (2) stacked on each other, loosen the magneto and let it fall onto the flywheel, with the cards in between, and then tighten the magneto hold down bolts, and spin the flywheel to remove the cards, with the gap you have the motor is fighting to fire and is doing so too slow, which is causing the backfire,
Jul 21, 2011 | Briggs & Stratton Briggs Stratton Intek V...
What is the magneto gap for a 6HP Briggs & Stratton 12H802 series engine?
Briggs lists it as .006 - .010 on this 6 HP L-head engine. The .010 width can easily be attained by using a standard sized business card as a feeler gauge (and it doesn't stick to the magnets in the flywheel). I double up the card, loosen the coil and let the magnets in the flywheel draw the pickup legs in until they press on the card, tighten up the retaining screws (threadlocker is optional) and your air gap is set.
http://www.smallenginesuppliers.com/html/engine-specs/briggs/common_specs_single_cyl_lhead_engines.pdf
Jun 10, 2011 | Briggs & Stratton Briggs Stratton...
Have 303447 briggs 16 hp only fires one cylinder
Have you also changed the spark plug too. The ignition circuit is pretty simple, from the battery, the Coil is energized, the "points" or equivalent, through the "Distributor" or equivalent, and onto the Spark Plug. So it is a simple matter to work along the path, proving the "Integrity" at each, point by testing. IF it still doesn't fire after ensuring all Leads are OK, the Spark Plugs are proven OK, the Cables, the Points, & Distributor, . IT is either that or the Ignition Timing is OFF. Please check all those points.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Need timming specks & torgue speck for rod bolts
There are no timing "specs", if the flywheel key is good and the magneto air gap is properly set, the timing will be right.
Torque for the rod bolts is 45 INCH pounds - NOTE INCH pounds not foot pounds
Sep 23, 2009 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Timing for briggs and stratton 15.5 engine
There are no timing marks, timing is correct when the flywheel key is in place, the flywheel is properly torqued and the air gap for the magneto is properly set
May 18, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
No spark
If your engine is 11 years old it will have points @condensor under flywheel there are two wires coming from the condensor one goes to the coil and the other goes to a ground switch thats most of the time on the throotle linkage,if that wire is grounded against metal there will be not spark . the gap between coil and flywheel is 10 thousands (you can use an index card to set it .
May 16, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Cant get a spark on my briggs and stratton 4hp engine, trying to
gap from coil to flywheel is .010. if you've replaced coil, points and condenser with no spark i would try replacing the coil and points with an magnetron kit or a coil that allows for the elimination of points.
Mar 21, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Garden Logo
79 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
