Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
Cannot access d-link router
I cannot access my d-link router. I tryied to reset it, but it didn;t work?
  • 2,263 Answers
Are you trying to setup router?
this is very easy.
Click Here for step by step solution.
Posted on Nov 29, 2009
Login failed
Okay. You have to reset your router for factory default. The reset button may be located on back side or bottom side of your router.
Power on the router and insert a needle through the reset hole for 10 seconds for reset your router. Give new password.
Before you do this, keep in mind that your Internet connection's User name and password.
Jan 18, 2014 | D-Link Computers & Internet
My linksys router doesnt have a default gateway and the reset buttton on the router doesnt work either
When you look between the Ethernet port and Power button, there should be a reset button there you should hold for 5 seconds. Of course if you do that, If you changed Network name and key that will be reset to the default settings, Also is wireless network showing when you pull up the Networks? You can leave user name blank, but default password is admin. Also email me with more info I will be glad to help
http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&app=vw&vw=1&login=1&json=1&docid=1e97db4854604b0fb5cc8c0d74491e35_19584.xml
Dec 26, 2011 | Linksys WRT54G3G Wireless Router...
My ex partner set up my internet access using a Zyxel router P-660HW-T1. Now my daughter has purchased a laptop and wants to connect to the internet. Unfortunately, he didn't tell me the security key...
There is a reset button on the back of the router. You have to press it in for about 10 seconds. (While the router is on) This will reset the router to default settings. You will lose all security, and your network will be "Open". You will then have to refer back to the guide in order to setup your network security, and create a new password.
Here is a link to the guide.
ftp://ftp.zyxel.com/P-660HW-T1/user_guide/P-660HW-T1_3.40.pdf
Sep 04, 2011 | Zyxel P660HW-D1 Router
Good morning! I can't access to the software of my d-link dsl-2640b. once I could and put wep key, but now I can't. I think I didn't change the default IP adress of my router, then I'...
Please reset the router. Get a paper clip and push the reset pinhole for 15 secs. Please check the link below. It do have a picture of the device where you can easily see the reset pinhole on the back.
http://www.avbell.com/Manual/DSL_2640B/UserManualDSL_2640B.pdf
Thank you!
Jul 10, 2011 | D-Link Computers & Internet
I can't get the password on my dlink. i put in admin were it says password and i even tried putting password where password did,t work. tried resetting the router and that didn't work... i had this...
best solution is to reset the router to default settings:
In order to do that use a pen or paper clip to push the reset button for around 30 seconds.
Please download and refer to manual I linked below:
Manual
I hope this information helps.
May 11, 2011 | D-Link DIR-615 Wireless Router
I recently bought a Dell laptop that has B+G wireless networking. Should my 2300 router work with this computer? I am having trouble getting a signal to my work area.
yes you can work with it.
If you face problem in gettings signal strength then you need to change frequency channel in router.
for that access your router with following link
If it is not in netwrok then connect your router to computer with ethernet cable.
Then access thisd link http://192.168.1.1
or
http://192.168.0.1
type user name as "admin" and password as."admin" or blank or "password"
then if you cannot access it then you have to reset your router to factory defauls settings.
For reset you have to press RESET button for 10 seconds it is in back side of router .
then access with above link
then go to wi fi and change channel type to 4 or 6 or 11 try 1 by 1 then save settings in router then restart bot computer and router to then check signal strength set that channel which give you high signal.
Aug 13, 2009 | Dell TrueMobile 2300 Wireless Router...
Unable to establish a wireless internet connection
Does your computer normally recognize other access points? Example, free wifi in some bookstores in fast food restaurants. If it does, check and make sure the wireless router is on. Also, plug the PC into the router with a network cable, determine the gateway IP address, enter that into your browser, and make sure the SSID is being broadcast. If you don't know how to do this, the following links may help:
http://wiki.answers.com/Q/How_do_you_find_the_gateway_address_and_subnet_mask
http://support.dlink.com/supportscope.asp
The d-link support will help with your specific router.
Mar 20, 2009 | Computers & Internet
Forgotten key to access my secure d-link wireless router model
hey what you can do is you can reset the entire router... by using the reset button on your D-Link router... Or else you can also access the router by using the following IP address in the internet exlorer...
try 192.168.1.1 or 192.168.1.0 & then go to the wep settings & reset the router or change the password for the router...
Jan 18, 2009 | D-Link AirPlus DI-524 Wireless Router
Can not get netgear to go on line
give a try by resetting your router n reconfigure it,that might fix your problem
Dec 13, 2008 | NetGear WGT624 Wireless Router
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
294 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
