Question about Gateway FPD 1730 17 in. Flat Panel LCD Monitor
Unhooked and moved my computer to another part of my room and the monitor now comes on with the power saver display and button is blue, then power saver display goes off and button turns yellos light and no picture. Computer working fine. Gateway computer and monitor (flat screen)
    Scholar:
  • 78 Answers
Sounds as if your monitor is not receiving a signal from your video card. In all likelihood, the video card came unseated during the move. Open the case and re-seat the video card, that should do the trick.
Write back if that does not solve the problem.
-Jon
Posted on Sep 29, 2009
It shows power saving mode
Power saver modes on the monitor has several functions. First the power saver preserves the devices from consuming current while viewer is mometarily away. Screens that display power saver modes returns to regular viewer mode soon as the remote controls or buttons are manipulated slightly as indication of request to regualar views. The power saveer mode of the screen can be disabled. Obser ve the feature functions of the device iether on the remote controlof device buttons. Power savers perform simialr to screen savers or device feature manipulations. Access the devices settings or menu buttons to display the entire list to buttons for disactivation of power savers modes. Usually the power saver mode may be onsctruting viewer experiences for situation that momentary displays ate idleness requiring to retore to viwer display screen. Refer to the devices userguide to attain details.
Feb 08, 2011 | LG Computers & Internet
No desply monitor aoc crt problem
WHY IS THE POWER LIGHT ON MY MONITOR NOT COMING ON? Make sure the power button is ON and the Power Cord is properly connected to a grounded power outlet and to the monitor.
THE POWER LIGHT OF MY MONITOR IS ON AND THE COLOR IS AMBER, BUT THERE IS NO VIDEO OR DISPLAY. WHAT IS THE CAUSE OF THIS? Your computer may be in screen saver mode, it has instructed the monitor to go to power saving mode, or the the monitor's video cable is not properly connected to the computer. Another possible cause of this is a locked-up or in-operative computer since the computer is what supplies the monitor with all the display data or information. Move the mouse or press a key to de-activate the screen saver or power saving mode. Check the monitor's video cable and make sure it is snugly connected to the computer. To see if the computer is operating properly, press the CAPS LOCK key on the keyboard repeatedly while checking the CAPS LOCK light. If the light is not turning ON & OFF, the computer is non-functional. Contact your computer manufacturer for help.
Feb 04, 2011 | AOC Monitor
How to close the small blue monitor control window that pops up unexpectedly? Escape does not work, the cursor disappears behind the window. Compaq model FS7600
From what I can gather from the "help" files on the hp website when the display comes up (presuming you are referring to the control display) then you need to use the buttons on the front of your monitor to exit it.
Button 1 launches the control display
Button 2 moves backwards (left) through options
Button 3 moves forwards (right) through options
Button 4 is the "select" button
Button 5 is the power button.
When the display comes up, you need to use buttons 2 or 3 to get to the "Exit" label on the display. Then press button 4 to select this.
The user guide for this model is here
Nov 10, 2009 | HP Compaq FS7600 17" CRT Monitor
Out of the blue one day, monitor started displaying "anaolog power saving mode." This is a stand-alone computer which has never been hooked up to internet.Took tower unit to PC World to see if it was a...
you go to control panel starting your pc ,, then display settings,, from there,, screen saver tab, then make screen saver to none, and click on button power,, there you make everything to never,, and then see. it should work good
Sep 27, 2009 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Screen stays either black or white
Replace the entire DAC board (board with power suplly going into it) for easiest solution.
Aug 19, 2009 | ViewSonic VA703mb Monitor
Black screen
Don't let the computer turn the monitor off. Go into control panel and click on power option. don't let the computer turn anything off and disable hibernation if on. go to screen saver and have it come on in about 30 mins.
May 27, 2009 | ViewSonic VX2235wm LCD Monitor
Hp vs17e monitor says it's in sleep mode then goes blank
If you are running Windows Vista,do the following,
  1. Click start,Control panel,
  2. Double click Power options,
  3. On the left menu bar,Click Change when the computer sleeps,Change "turn off the display" to never,
  4. Go down to the botton and select "Change advance power settings,
  5. Scroll down to Display and click the + symbol,
  6. Click the + symbol beside "Turn off display after" change to never,
  7. Click on the next plug + symbol beside Adaptive display and change to off (You may or may not have the adaptive setting)
  8. Click apply ,click ok,
  9. Restart your computer.
If you are running windows Xp
  1. Right click on an open area on the desktop
  2. Click properties
  3. click the screen saver tab
  4. Click the power button at the bottom
  5. Change the "Turn off monitor settings"To Never
  6. Retart computer
if this doesn't fix your problem,please let me know
Please rate this a fixya
Feb 02, 2009 | HP Vs17 17" LCD Flat Panel Monitor
BeNQ FP71E Monitor won't display desktop
The problem seems to be with the monitor.When there is no Display,if you power-off and on again do you get a Benq Startup screen?If not the problem should be dry solder on the Invertor board.Try tapping screen lightly,if it comes on the problem is dry solder on Invertor board.
Provide feedbacj and rate this solution.
Samir
Jul 28, 2008 | BenQ FP71E 17" LCD Monitor
Sceptre X7g Monitor Flashing Red & Blue Lights. Blank Screen
i fixed this problem by unplugging the monitor, unplugging the video cables. Then hold down the power button while plugging it back in. Release power button and then press power button for on. It worked then. I got the icon for no signal, i plugged back in my monitors. Sceptre X9W
Sep 11, 2007 | Sceptre X7GNAGAV 17" LCD Monitor
Stuck in power saver
Try the unlock procedure: With the monitor on press and hold the "MENU button for abot five seconds and see if it resets. If that doesn't work tell me a bit more about the screen - is there any OSD (on screen display) or error messages? Is the power indicator light on? If so, what color is it? Blue indicates that that you may need to turn the brightness and contrast up...\ If it is actually in power save the indicator light will be amber. What color is it? If the light is amber and all the connections to the computer are correct and it still won't come-up then it's an internal problem and the protect circuit may be keeping the screen from lighting. Good luck... And let me know. Bill
Jun 07, 2007 | LG L1722P 19" LCD Monitor
Gateway FPD 1730 17 in. Flat Panel LCD Monitor Logo
106 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
