Question about Husqvarna Garden
Acts like it is runing out of gas has clean carb and new filter
    President:
  • 2,220 Answers
This can be caused by a loose carburetor, cracked fuel lines, plugged fuel filter, old fuel mix, and a few more things that aren't coming to mind. HTH
Lou
An IPL (exploded parts list) with what little fuel routing detail there is can be found here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Posted on Sep 29, 2009
Can.t get carb to pull gas from tank has new lines filter and carb runs find as long as you pour gas down carb
There is a very fine screen in your gas tank that acts as a filter. Check to see if it is clean, also check the fuel line that goes to the carburetor. If very old they tend to collapse inside themselves.
Overall I think you are having a fuel delivery problem. GOOD LUCK FRIEND.
Jun 06, 2015 | Garden
Why is my car poring gas out of air filter when the car is runing
1.8 L honda 34mm keann carbs.Altitude adjusting via all vacuum lines 1984 to 87dx models they just get old and they have plastic floats 1 carb.1 float set they are a discontinued oem part they will fill up with gas and sink causing them to flood.Find some old stock float sets and carb.kit should fix right up.Maybe some one out there makes custom carb floats out of brass???That is what they need!!!!
Feb 22, 2015 | 1986 Honda Prelude
New carb on 49cc scooter. only runs for 30 secs then acts like it runs out of gas. still gas in new fuel filter that cam with carb
Sound like the float in the carb is getting stuck the way to tell is loosen the screw at the very bottom or carb and see how much gas comes out it should run forever if only runs for a few secs the clean out carb
Aug 07, 2013 | 2008 Keeway Matrix 150
19 hp kawasaki carb acting up
sounds like the carb is gummed up from the old gas you will need to clean and rebuild te carb(this is a easy job)...good luck
Apr 04, 2010 | Garden
McCulloch EB358A starts but acts like it is running out of gas
ok you have what sounds to me a blockage in the carb. take it off and thouroughlly clean it. check the diaframs in the carb to see if they are hard and stiff. if they are hard and stiff replace them and clean the carb really well and see if this works.
Oct 24, 2009 | Garden
Ryobi lawn tractor mtd the problem is it begins
YA IT DOSE THAT WONT STOP IT FROME RUNING SOUNDS LIKE TO ME THAT YOU HAVE SOME TRASH IN THE CARB YOU MAY WANT TO CLEAN IT OUT IT MAY NEED A CARB KIT
Oct 15, 2009 | Briggs & Stratton Garden
My yard man mtd lawn mower.starts and stop runing it wont start inless i got the chok out and then it stops runing
i would check the linkage at the carb 1'st to make sure nothing is broken or disconnected.hope this helps
Jul 16, 2009 | Mtd Garden
Trot Bilt 4 cycle weed eater catches, but wont run.
rebuild carb to fix problem.let me know if this help you.ok
Jul 12, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Won't start up
Check to make sure you are getting fuel pressure. Can you hear the fuel pump come on? Will it start with carb cleaner being sprayed in the carb (watch for back fire)? If it will start with carb spray and you can not hear the pump its the pump. Try to get it to go like a old stuck starter. Have someone turn the key and use your fist to bang the fuel tank sometimes that will get it to go. Sounds like you need a pump.
Mar 01, 2009 | 1988 Chevrolet C1500
Garden Logo
89 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
