Panasonic PT-53TW53 53 in. Rear Projection HDTV-Ready Television
Problem for Panasonic PT-53TW53 53 in. Rear Projection HDTV-Ready...
Convergence blue stopped working. Unable to adjust
By pilotbob874 on Sep 29, 2009
convergence blue stopped working. Unable to adjust with controls. what board is it that controls it? The blue is still firing but other colors are starting to waver.
Best Solution
posted on Sep 29, 2009
Very Helpful)
asnowman
Rank: Guru  Panasonic Televisions & Videos  Expert
Rating: 95%, 610 votes
Your symptom sounds like a damaged convergence IC. They are on the Signal board on the left as you look from the back of the set.
There are two and large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110, and they are located on the signal board (on the left as you look into the back of the set).
What happens in the Panasonic set is that the convergence IC’s will short and cause the power supply to shut down from the overload of current. Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
There are also two resistors on the front of the board located in the middle that are fusible link resistors, these should be checked for opens and replaced if they are found so.
I would suggest that you contact a service center in your area for a complete diagnosis and repair, as this type of repair can get a little tricky. But if you want to repair the set yourself, just remember to be careful. The capacitors and CRT’s can hold a charge and may shock you.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
Was this helpful?
Yes
No
3 people thought this was helpful
Asker's Testimonial
" Thanks for the fast reply. I did some research and it is exactly what you posted. Thak you very much. " - pilotbob874
Popular Solutions for Panasonic PT-53TW53 53 in.
Questions and Unsolved Problems for Panasonic PT-53TW53 53 in.
Do you recommend Panasonic PT-53TW53 53 in. Rear Projection HDTV-Ready Television?
Answer
Answer
My Panasonic PT-53TW53 53 has no picture and no sound this morning. The red light is blinking 5... (More)
Answer
When i turn it on the screen is really blurry, and after a few seconds the screen goes black and the... (More)
Answer
what size screws attach the tv to the base? tv is insigina ns-lcd32-09, can you help? We called the... (More)
Answer
my tv. wont turn on and no sound. But I hear a wierd noise.
Answer
my bottom part of tv to the left side became a little wavy and it's showing double and you can see... (More)
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
