Question about Miele T9820 Gas Dryer
Miele T9820 runs except no heat - Miele T9820 Gas Dryer
  • 177 Answers
You have probably blown your thermostat especially if your condenser is blocked and hasn't been cleaned. this causes the unit to over heat and to protect the heater element the thermostat blows and breaks the electrical circuit. you will need a Miele service tech or service agent to repair the unit.
Posted on Aug 24, 2010
Drum not turning. There is heat. Opened machine found broken belt. Drum will not turn by hand. What would it cost to fix?
in the package of the new belt, the belt for the dryer the instructions are right on or in the package, if not normally you take the front and possibly the top of the dryer 1st.... off slide the belt over the drum, and the insert it through the tensioner and then unto the motor. you have to make sure the belt has tension on it this will show it will be able to move the drum.... you can download maintenance manual form here
http://www.slideshare.net/avermapub/miele-gas-dryer-t9820-service-manual
price depends where you purchase it.. $ 20 to $ 45
Sep 25, 2014 | Miele T9800 Electric Dryer
Miele dryer doesn't stop
Stuck buttons have tech inspect
May 17, 2014 | Miele T9820 Gas Dryer
Miele t9820 service manual
did you get your software update done during the campaign? Call miele for the software update. while the tech is there, ask him any question you want. it is free of charge, and it is a safety issue on that dryer. 800 999 1360. dsc software update.
May 02, 2012 | Miele T9820 Gas Dryer
Motor humming and not moving
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 29, 2011 | Miele T9820 Gas Dryer
The dryer doesn´t work
I had the same problem with my dryer. The Miele technician came and took a look at it. There was nothing wrong with any parts. My vent pipe was kind of crumbling, so he replaced that. He then scrubbed and washed the lint filter with dishwasher soap and
the green scrubber, He also did a PC update of the firmware. My
unit already had the latest version, but he did erase all the error codes.
After all these rather simple steps the dryer started working like a charm.
He said the most probable caused was gummed lint filter because of using the dryer sheets. Miele dryers are designed to prevent static cling and he advised not use these sheets as they contain wax-like substance.
I would suggest scrub cleaning the lint filter first and see if that helps.
Aug 02, 2010 | Miele T9820 Gas Dryer
Miele gas dryer drum won't turn, but turns on like it works
check out my tips on dryers
the tensioner and belt needs to be replaced more than likely
May 09, 2010 | Miele T9820 Gas Dryer
Clean filter / vent indicator stops unit after T9820 MIELE GAS DR
Call Miele and schedule a PC update. When the technician comes he will do the update, if needed, and will reset the error codes.
Apr 04, 2010 | Miele T9820 Gas Dryer
How do i replace the dryer belt on my t9820 miele gas dryer
Don't mess with it. Call Miele. The front seal is probably worn and caused the belt to break.
Feb 04, 2010 | Miele T9820 Gas Dryer
Pop the top miele t9820 dryer gas
Open the door, at the top of the recessed door opening you will see two round plastic caps. Remove these and you will see screw behind that you have to remove. Some models the caps are on the right and left hand sides. Slide the top towards the back after removing screws and the top will lift off. Good Luck, Appliance Specialists
Jan 06, 2010 | Miele T9820 Gas Dryer
Check vent/lint indicator alert
Contact Miele 1800-999-1360 for a new blower fan
Jun 07, 2009 | Miele T9820 Gas Dryer
Miele T9820 Gas Dryer Logo
390 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
