Question about Dryers
I replaced the heat element on my DE 701, and moved the drum so I could access the element. In the process, I unintentionally disconnected the wires leading to the motor. Is it possible to tell me the order the four different wire colors go to connect to the motor. The wire colors are red, white, blue and green.
    Problem Solver:
  • 10 Answers
There should be colored dots on the motor start switch next to each lead. If there isn't, I'll pull the rear cover of my 1961 DE 701 and give you a definite answer.
Posted on Oct 01, 2009
    President:
  • 1,922 Answers
They're marked on most motors where and what term are what color if not most machines have a schematic diagram pasted on machine
Posted on Sep 29, 2009
How hard is to replace a heater element on a BEKO wm5140s washing machine! cheers Brian
Fairly easy.disconnect mains drain any surplus water via drain bottom front of machine.access to the heating element is from below so tip machine from one side against wall at45degrees.... I normally use a towel on bottom edge to stop it sliding whilst I unscrew any bottom plate.you will see the heating element housed at the base of drum unit.disconnect wires and unbolt or unscrew element housing .youtube has tutorials on this but many machines are similar in thus respect.good luck
Jan 29, 2015 | Beko Washing Machines
The dryer operates but does not produce heat. i think it is the heating element but i can not get in to the back of the dryer to check. i would like to get a service manual so i can check the element
1 Unplug the power cord from the electrical socket.
2 Remove the screws located around the edges of the back panel of the DVLR223 dryer. Move the back panel away from the cabinet.
3 Push the idler pulley away from the belt to loosen the belt tension. Remove the screws on the panel behind the dryer drum. Remove the panel.
4 Remove the four screws located on the underside of the top panel. Lift the top panel off of the cabinet.
5 Lift the drum up through the top of the cabinet and set it aside.
6 Unplug the electrical wires connected to the heating element assembly. Remove the old heating element from the DVLR223.
7 Insert the new heating element where the old one was previously located. Plug the electrical wires into the heating element assembly.
8 Replace the drum inside the dryer cabinet. Replace the top panel and the four screws that go on the underside of it.
9 Replace the panel behind the drum. Replace the screws that hold it in position.
10 Reposition the back panel onto the DVLR223. Replace the sheet metal screws around the perimeter of the back panel.
Jun 19, 2011 | GE DVLR223 Dryers
My inglis model 43 00SQ is not heating properly. after it was moved, it now requires 3 or 4 cycles to dry a load of clothes.
There's a possibility that one leg of the 220v to the heating elements shook loose. Even a good manufacture can miss a properly tighten wire. It happens more that you realize. The other possiblity is that the rough treatment during the move could have caused a break in one of the heatiing elements. If you have voltmeter or have access to one, pull off the back panel that gives you access to the wiring, make sure the dryer is unplugged, and disconnect one of the leads to the elements. Now set your volt meter to the ohms position, kinda looks like a horeshoe, put one lead of the voltmeter to the detached wire and the other one to the wire that is still connnected. If the element is good it should show how many ohms or resistance the element has. It will show an amount, for this purpose it's unimportant, that means the element is good. If the reading is "0" that means the element is broken and neads to be replaced. Repeat with the other element.
There is another possibility that could have happened. During the move, part of the element may have come loose and is touching element somewhere in the middle. If this has happened it can be put back and your full heat will return. If it stays like that it will eventually burn out early.
Apr 09, 2011 | Dryers
I am trying to take the back off of my Whirlpool clothes dryer model LEQ8611LW1 to replace the heating element, but the back will not come off. How do I get to the heating element?
The dryer doesn't have a removable rear access panel and the heating element is accessible through the bottom front panel. Using a flat-blade screwdriver, locate and release the two bottom front panel clips approximately 4 inches from the sides.
Once the panel is off, locate the heating element housing is on the right side and remove the hex-head screw from the heater shield.
Remove the hex-head screw from the side of the heater housing and slide the heating element out then slide the new heating element in and secure it with the hex-head screw.
Note:
The heating element is not necessarily busted and needs to be replaced when the dryer fails to heat up. The first thing to look at is the thermal cut-off. It blows open and cut power to the heating element if the high-limit thermostat is faulty. Disconnect the red wire from the thermal cut-off and the red/white stripe wire from the heater. Connect the red wire disconnected from the thermal cut-off to the heater terminal where the red/white stripe wire is disconnected from.
Reconnect power then start the dryer. The problem is indeed with the two bypassed components if the dryer heats up. Replace both the thermal cut-off and the high-limit thermostat and it should solve the heating problem. Do not use the dryer with those parts bypassed due to high risk of fire hazards.
Apr 01, 2011 | Whirlpool Dryers
The dryer is not producing heat.
If the Drum is rotating and the Blower Motor is operating (meaning you can feel air moving in the Drum), then the likely culprit that is causing your lack of heat is the Heater Box. By box, that means a metal box that usually sits behind the drum containing a heating element that heats the air going into the drum. If this heating element is not working then, you heater box is at fault. Don't assume that the element is bad, more often than not is is a thermostat, switch, or perhaps a wire that is connected to the box. While the other electric components on your dryer operate at 125VAC, the heater box uses 220V AC. You will need to get a multitester to check continuity. On some models, you can access the box from the box, but on others you will have to remove the front door and take the drum and belt off (a pain in the neck to remove). Hope that helps.
Jan 12, 2011 | Dryers
No heat, but dryer turns.
There are three common causes of a dryer not heating. First is a busted heating element. Second, the thermal cut-off has blown. Third, the high limit thermostat is not working.
Disconnect power to the machine and remove the screws at the bottom of the lower front access panel (toe panel) holding it in place. Pull the panel down and off the cabinet. You now have access to the heating circuit.
Remove the heater shield by removing its mounting screw and pulling it off the heater housing.
The heater terminal block is located at the left opening of the heater housing. Disconnect the wire from one of the heater terminals and measure the resistance of the heating element using an ohmmeter set to X1. The resistance should read 7.8 -11.8 ohms. Replace the heating element if the resistance reads open.
Disconnect the wires from the terminals of the heating element and remove the screw securing it to the heater housing. Slide the busted heating element out of the housing and install the new heating element. Secure it with the screw and put the terminal block in place. Connect the heater wires and reinstall the heater shield.
Slide the lower front access panel up into the cabinet and secure it with the screws.
Feb 28, 2010 | Kenmore Elite HE4 Electric Dryer
How to gain access to replace the heating element
Before you do that, please tell me that you checked the lint trap on the dryer.... after cleaning that, you need to walk outside to where the dryer exhausts air and make sure you have good flow- if you don't, you most likely have lint built up inside the line. Are the clothes warm in the dryer at all???
Dec 31, 2009 | Dryers
Need to get into dryer to check heating element unit does not heat up all else seems ok model no. MDE9316AYW 5600 watts...help rubenandyolie
Check the house electrical panel dryer breakers (pair), push OFF, then ON. If breakers trip again, problem is a short inside the dryer. Pull the power plug from the socket. The top must be opened which allows access to front panel screws from inside. Lift the panel and pull away from cabinet. Disconnect the wiring to door switch and light. Make a diagram of wiring colors and where they went. Uncouple the drive belt from the motor--go through a sub-panel in the back and release a large tension spring from the idler pulley, then remove belt from motor. Remove several screws from inside of drum center, then lift the drum from the case. The heating element(s) are mounted in back of the drum on a supporting wall. Look for any burned areas or wires that touch the surrounding metal. On reassembly, check the condition of the drum belt--any cracks or missing pieces--replace the belt now.
Aug 01, 2009 | Dryers
The drum is stuck - it will not move
overloaded & unballanced has mabe pulled drum away from the rear bearing!
& jammed iself!
only way now is to disconnect power & water & undo cabinet to inspect it!
Cheers rob.
Jul 28, 2009 | Washing Machines
HEating element
The heating element is located in the bottom left corner. You will need to remove the drum for access. Once you have the drum out of the way, look for a square box with wires attached. There are 10mm fasteners that hold the heating element to the vent. Rome the screws, mark the wires and positions then remove the heating element. Before replacing the element make sure the thermal fuse and the high limit switches are not faulty.
Jan 10, 2008 | Amana DLE330RAW Electric Dryer
Open Questions:
Dryers Logo
59 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
