Question about Garden
How to connect gas hoses - Garden
    President:
  • 1,776 Answers
Typical fuel line routingHow to connect gas hoses - 2.gif is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Posted on Sep 29, 2009
Car won't start with vacuum hose connected but will with hose not connected also has no gas pedal pressure, after running for 10 minutes or more
Need more details, such as which vacuum hose and what happens if the hose is connected after the engine starts?
I don't understand your reference to gas pedal pressure? The pressure felt in the accelerator pedal is merely the pressure of the return spring which is unlikely to be there and then not be there ten minutes later.
Jun 27, 2016 | Cars & Trucks
On carb...which hose connects to gas intake (small hole on top). Now big hose connected to bowl, no top hose
Hi, Lee it all depends on the year, make, and model of your motorcycle please ask your question again with this information in the details box. Good luck and have a nice day.
Jan 27, 2016 | GAS Motorcycles
Need diagram of were the air intake hoses go and gas tank hose thank you
Air Cut Off Valve, Fuel and Vent Hose Connections for a ...
? 4:11
www.youtube.com/watch?v=Jb6gckj_saw
Sep 16, 2013 - Uploaded by smallengineshop
Air Cut Off Valve, Fuel and Vent Hose Connections for a 1985 Honda Shadow .... How to diagnose carburetor vacuum leaks on your motorcycle
Aug 04, 2015 | GAS Motorcycles
STIHL FC90
the fastest way is to replace the line it connects to pull the old line out take the new hose and trim it down to 1/3 about a 1/2 long feed a stiff wire threw the hose opening and out the gas cap opening slide the line over the hose and slowly pull the wire back til the hose sticks out then pull the hose threw connect the filter to the hose then pull into place trim the hose to size
Aug 11, 2012 | Garden
Hello My side burner is leaking gas. I can hear the gas flowing even thought the knob is in the off position. But it doesn't click like all the other burners. Eddie
If the gas you hear is coming from the burner, rather than the side burner gas supply hos, the control knob may be stuck in the "IN" position. Turn the gas tank OFF, before attempting any repairs and disconnect the hose from the tank.
Now that there is no pressure on the side burner control knob, try using it as you normally would. What you're looking for is full function of the knob. Push it it and turn it to the light position. Does the knob pop back out when you release it? If it does, that's a good sign. If memory service me correctly, the gas supply line to the side burner as a quick connect on the hose to connect it to the burner. if so, disconnect and reconnect it to the burner. Does the quick connect slide back into place and connect properly? If not, that is what's leaking. But, to make sure, there needs to be gas going to the grill. Reconnect the hose to the tank and open the tank valve VERY, VERY SLOWLY (Slow motion, slow). Once the valve is fully open, test the side burner hose connection and the hose (squirrels like to chew on the hose) by brushing on a soap & water solution to check for leaks. If you see bubbles that grow in size, that's a leak. Turn the gas tank back OFF. The side burner hose will need to be replaced.
If there were no leaks on the connection, check the burner knob for operation. Does it operate like it should with no smell of leaking gas? If not, the control knob valve will need to be replaced.
The parts you may need can be purchased from Ducane Customer Service 1-800-382-2637.
I hope this helps you to troubleshoot and solve the problem. Thanks for choosing FixYa.
Aug 03, 2011 | Ducane 30400040 Stainless Steel Grill
I can smell gas outside car. No gas drips on ground. I Just filled gas tank and as I went around a sharp turn, a car in back of me reported gas comming from rear of car. When air is on max, we can smell...
Have the filler hose checked for a break. The hose that connects the filler tube to the gas tank. Sounds like it is loose or broken, when you turn the corner the gas slops out of the tank cause the filler tube is not connected good.
Jul 17, 2011 | 1997 Mercury Grand Marquis
We are leaking gas where the hose goes into the block. We have purchased a new regulator assembly which didn't seem to stop the gas problem. It still leaks where the gas needs tto enter the grill.
Turn the tank valve OFF and disconnect the hose from the tank. Then remove the hose connect at the grill manifold. Use several wraps of gas approved Teflon tape on the threaded male part, that the hose connects to. Make sure the wraps of tape are applied in a clockwise fashion. Or it won't seal. Be very careful not to cross thread the coupling.
Hop this solve the problem for you. Happy Grilling!!
Jul 03, 2011 | Weber Genesis Silver B Grill
Heater will not fire....there is gas flow to the unit, and the ignitor does spark, but no flame. gas valve seems to not be opening to allow gas to burner
What about the two small tubes that come out of the air hose at the back of the heater? Are they connected to both the air hose and the blower assembly? If not connected no gas will flow.
Tom
Oct 21, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I have hose leaking gas under neath,its not connectted to anything and can't find anyplace it could be connected to.help
It is probably connected to the carburetor on one end. This would be an overflow hose line and any gas in it is suppose to drip on the pavement. No dripping is what you should have. The float in the carb the hose is attached to is not fully closing. This could be due to trash from the gas tank or a float that is partly filled with gas and no longer floats as it should. Clean the carb and determine why the float needle is not fully shutting off the flow of gas. Please rate my answer. Thanks.
Aug 07, 2010 | Yamaha RD 250 Motorcycles
My leaf blower is leaking gas
Check the gas hoses (or hose connections) connected from the gas tank to the carb. to see if the hose(s) has holes someplace or lose connections. If all is ok in that area check to see if you carb have vibrated loose allowing gas to escape. You can also check to see if the carb needs to be cleaned and diaphragm replaced if it is no longer soft and pliable. Sometimes the diaphragms in carb turn to paperlike substance when exposed to gas for any length of time and will not close off that area of the carb allowing it to leak gas.l
May 07, 2009 | Homelite 'Yard Broom' Leaf Blower
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
