Question about Kenmore Elite HE4 Electric Dryer
Clean Dryer Lint Vent in Kenmore elite HE4
How do you clean the lint vent of kenmore elite HE4. I have cleaned the lint tray and all I can see within the dryer. Using a lint brush at the bottom of the dryer it hits an obstruction -> is this a blade/extra filter or what. How do you clean underneath to ensure front to back the lint dryer exhaust area is fully cleaned.
  • 5,911 Answers
If you wish to clean the interior cabinet of the dryer follow these steps:
1. UNPLUG the dryer. Dangerous voltages are still present even with the dryer turned off.
2. Open the dryer door and remove the lint screen. IMPORTANT: You must remove the lint screen first in order to remove the blower fan housing.
3. Remove the lower toe panel directly below the dryer door by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. NOTE: For better access, you can prop the front feet of the dryer up (a 2x4 works well).
4. Loosen the screws on the blower fan housing directly below the drum and remove. There's usually a small clip holding the cover in at the bottom that you may need to pull out to release. NOTE: You may also have to disconnect the auto dry sensor plug (yellow wires with white plug - use a small screwdriver to release the locking tabs) and/or ground wire to accommodate removal of the cover.
You should now have access to the dryer interior and the blower fan squirrel cage motor. Take the time to clean out the blower fan housing cover as well. A long bristle brush made for dryers works well at removing any lint inside the dryer in the hard to reach places, followed by vacuuming.
NOTE: After cleaning, you may experience a slight burning odor. This is normal as lint gets stirred up in the cleaning process and can settle on the heating components. The odor should dissipate after a short period of use.
If you have any questions, please let me know. I hope this helps you.
Posted on Sep 29, 2009
  • Kristen Clinton
    Kristen Clinton Feb 16, 2014
    Can you do this with out removing the pedestal?
Dryer taking a long time to dry
Open the door after is has been running for a bit. If it is hot inside, then you have a vent problem (clean the dryer vent and lint trap...kits are available for the vent).
Oct 16, 2011 | Kenmore Elite HE4 Electric Dryer
It takes several cycles to dry clothers in my Kenmore elite He4 dryer, it feels like hot air is blowing but the clothes are not getting dry any suggestions?
werw
Sorry to read about your problem, I hope this helps you out.
Clean your dryer vents, and lint filters. You may need to clean vent from wall to outside. to test this.. unhook vent pipe from wall..and run dryer and see what happens. or you have a defective heat coil
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 28, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE want to know where the filter is so it can be cleaned top load, super capacity, have a clean machine cycle, but is there a filter that needs to be cleaned periodically?
most just have a lint filter at front of machine they should be cleaned after every load and chect where dryer vent goes outside wall of house see if it is clogged with lint clean that out as well
Dec 26, 2009 | Kenmore Elite HE4 Electric Dryer
The dryer isn't drying properly. It gets hot its not drying. Its a Kenmore Elite. Also the coil has been cleaned and its not catching lint.
Make sure the drum is turning and the blower is functioning. Vacuum out all air passages including the hose going to the outside vent. Remove the lint trap, and wash it in hot water and detergent to clean away fabric softener deposits from the screen. If the motor is not running, find out why.
Nov 20, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 does not dry the cloths all the way.
if dryer is filled with lint or vent line is blocked the clothes will not dry correctly,shop vac is great for this it sucks and blows,vac out what you can see and then blow out the lint from back and on motor,clean out the lint duct,where ever you pull out your lint filter either on top or inside dryer you have to clean out the duct.now go outside and check the flapper,if it isn't blowing open or hardly opening i use a leaf blower and take off the vent line from the back of dryer and blow it out,good luck
Nov 02, 2009 | Kenmore Elite HE4 Electric Dryer
Cloths not drying all the way
if you have heat and the clothes take to long to dry you need to clean out the dryer the lint duct and blow out the vent line,also go outside and make sure there isn't a cage or something acting like a lint catch stopping air from blowing out where the flapper is
Kenmore elite HE 4 IS NOT DRYING AND GIVING BURING SMELL
ensure the lint screen is clean, check your discharge vent hose for blockage or kinks. You may need to move the dryer out from the wall to thoroughly inspect the vent hose. while the vent hose is removed from the dryer, start the dryer momentarily to ensure the is sufficient air flow exiting the unit.
Feb 08, 2009 | Kenmore Elite HE4 Electric Dryer
Back panel removal
it is..remove bottom panel ..after unplugging from wall..remove lint screen next remove 3 screws holding the lint screen/blower housing in place ..clean out housing clean blower wheel with long brush or a long arm clean lint from base and on element housing on right side especially on top of the housing..that is the most important location if lint gets too thick on element housing ..fire hazard....ckd vent behind dryer and to outside if you find a large amount of lint .that is good indication of a restricted vent
Aug 22, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Dyer blowing cold air
Try cleaning out the the vent tube. Sometimes lint gets caught up in there over time. Hope this helps.
Mar 12, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
5,528 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
