Question about Target Saws
I need to change a blade on a Target wet tile saw. Which way does the bolt come off? Counterclockwise or reverse threaded?
3 Suggested Answers
  • 29 Answers
SOURCE: Tile Saw
i know blades on tile saws don't have to be super tight, i'm not familar with that kind of saw, i put a wrench on the nut and hold on to the blade with my hand and hit the wrench with a rubber mallet, and of course have the unit unplugged
Posted on Mar 26, 2009
woobie dog
  • 1273 Answers
SOURCE: I have a small ceramic tile saw. I have
Look for a button that you can press to lock the shaft in position. When you depress the button, you may still have to revolve the blade and shaft until the lock engages the shaft. Then unscrew the bolt from the shaft. Some others have an Allen wrench well in the end of the shaft, and you can insert the allen wrench to hold the shaft while operatiln the wrench to loosen the blade. Some others have a slot in the shaft end for inserting a slotted standard screwdriver for holding the shaft while the wrench is used to loosen the blade.
One of these methods will be available to you!
Best regards,
--W/D--
Posted on Nov 10, 2009
Changing the blade on the 3540 wetsaw
Blade should be secured to motor. Make sure bolt is tightened while holding blade with a pair of channel lock.
Nov 07, 2012 | Skil 3540-02 7-in Wet Tile Saw
Can't unscrew arbor nut on my MS250 Delta Miter Saw. Tried everything to turn it counterclockwise with no success.
The arbot bolt on your saw has reverse threads or righty-loosey, lefty tighty. You should be turning it clockwise as you are looking at it or in the same direction the blade turns when cutting. The arbor bolt on these saws are reverse thread so that they are self tightening while the saw is in use.
Feb 08, 2012 | Saws
What is the the thread direction to remove blade is frozen
the threads arent reversed,so left or downward will loosen the blade,i have the same saw,dont over tighten when installing the new 1
Feb 24, 2011 | Imer Tile Saw Combi 200va Portable Tile...
I have two 101's and both saws have a terrible wobbling. I have put new blades on both and no corrrection. I put the same blades on a 10" target and they boith cut perfectly....i am at a loss
well you might check the belt tension,you can tighten it by loosining the 4 nuts that hold motor then tighten the middle bolt in the back,that slides your motor forward,then retighten the 4 motor nuts.if saw sounds louder than normal, it probably needs new bearings
Nov 17, 2010 | Mk Diamond Mk Tile Saw Mk-101 Pro24 10in
Looking for shaft lock to change the blade on MK 170 wet saw
Just use a rag and grab the blade. Unless the threads are messed up you don't have to hold the arbor still, just the blade.
Apr 27, 2010 | Mk Diamond MK - 170 Wet Cutting Tile Saw
How do i change the blade on my delta 10" mitre saw
Exploded diagram for your SM100M miter saw is here.
User manual is here.
Page 20 covers blade change operation.
Make sure you unplug your saw! You need to remove a screw from the cover and rotate the cover to the rear. Use a hex wrench in the motor shaft to keep the saw blade from turning, and loosen the arbor nut with a 1/2" wrench. The arbor is reverse threaded, so you'll turn it clockwise to loosen, then counterclockwise to tighten it up after you have swapped the blade.
Rotate the cover back after that's done, and replace the screw.
If this was useful, please vote. Thanks.
Nov 23, 2009 | Delta SM100M 13 Amp 10" Compound Miter Saw
Best regards,
--W/D--
Nov 09, 2009 | Saws
I need to buy a tile saw I was searching on the internet & after spending 3 hours I came across this impressive website http://www.ciciliotandson.com/. I just want to ask you that are they reliable ?
Hi, I just went to that site you posted, I don't know what saw you were looking to buy, the saws looked like good quality, BUT they all looked very overpriced. Ive been doing tile since 1984 and have owned, mk,target, felker, pearl, tile saws. everyone of these saws have a 10 inch blade and are very very good for a thousand dollars you can get these saws with saw stand,blade all the gauges ready to cut.the pearl saw \pearl abrasive co.\vx 10.2xl has a 1 1\2 hp motorweights 83 pounds and cut a 2 foot by 2 foot tile or a 18x18 diagonally,great saw,the mk, target and felker have saws that will cut the same size of tile but are bulky in size.if i was you go ask tile setters at a tile store, before you buy a saw.good luck Chad
Jun 11, 2009 | Saws
Wobble blade /rough cuts
You may wanna check the Conveyor Cart Wheel. Replacing this wheel maintains smooth rolling action which contributes to straight, chip-free cuts.
It costs for only about $28.72. Here, you may check this link if you wish to buy the Conveyor Cart Wheels:
http://www.diamond-blades.net/target_tile_saw_access.html
Unfortunately, I couldn't find any service center where you can bring your Target Tile saw for repair. But you may check the manufacturer's contact number on the user's manual.
Have a great day!
May 30, 2009 | Target Saws
Need the Brick Carriage Rolling Bearings
i dont know where your located at, but when i need any parts for my tile saws i get them at the tile shop, that sells me the tile, most good tile distributors sell tile saws and most carry parts for saws targets a great saw and a good tile store will probably have those roller bearings in stock.good luck.chad
May 15, 2009 | Target Saws
Saws Logo
71 people viewed this question
Top Target Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Target Saw Expert? Answer questions, earn points and help others
