Question about Whirlpool Duet GHW9150P Front Load Washer
How do i install a new pump for my Duet washer
  • 5,911 Answers
The following link explains step-by-step how to replace the drain pump on a Whirlpool Duet:
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
If you have any questions about this repair, or if you need additional assistance, please let me know. I hope this helps you.
Posted on Sep 29, 2009
2 Suggested Answers
  • 127 Answers
SOURCE: how do we install new
Take back off of the machine. If you can get to and remove the old pump, you can install the new one. You may have to remove the sides as well to get to the pump.
Posted on Jun 01, 2011
What is code message F02?
Repairing the F02 error code can usually be done without ordering parts. Tools needed to repair your whirlpool Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out.
With the filter out clean and install it back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back, it may require you to clean the drain pump filter again.
If you require a new drain pump motor, you can purchase the part from the link below.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-error-code-f02-duet-sport-error-f02-fix/#sthash.PuGd0iuQ.dpuf
Sep 09, 2014 | Whirlpool Duet Sport HT WFW8400TW 3.7 Cu....
Why does my whirlpool frontloader stop in the middle of a cycle and read f 02
Sep 06, 2014 | Whirlpool Washing Machines
My whirlpool duet washer had a F02 code now it won't pump water
Aug 24, 2014 | Whirlpool Washing Machines
I have a frontload whirlpool washer and the water will not drai n out. I have clean the filter but it wil still not drain
hello, Chances are there is something in the pump and usually it will break off the impeller. You might have to install a new pump. Try unhooking the pump hoses and put the unit in drain and see if the impeller is turning or damaged before buying a new pump. please dont forget to rate me..Thank You..
Jun 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How do we install new pump assembly in WHirlpool duet sport washer
Jun 01, 2011 | Washing Machines
Whirlpool duet washer GHW9150PW will not drain.
Needs new drain pump. About $140. Will fix F02 / SUD error. Basically the drain pumpm isn't pumping water out. about 5 minutes to replace.
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How do you install a pump
turn the washer to open the back and remove the cover. locate the pump that is the part with hose in and out with electrical cnection, disconect the hose, disconectthe electric plug, see the part numbers to order a new part, same proces bacuard with the new part.
Aug 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer won't spin
Sounds like the whirling noise is the pump, pumping. Does it drain at all? Check the drive belt and make sure that it is not broken. This system uses a drive belt with a clutch system to agitate back and forth. The clutch system could be bad as well.
This might not be a cheap fix, these are the main components of the system
Mar 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WATER PUMP ON DUET
Was easy to remove clamps with a pair of Channel-lock pliers
Jan 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
229 people viewed this question
Dan Webster
Dan Webster
Sal De
