Question about Saeco Incanto Classic Espresso Machine
Incanto de Luxe always tells me there are no beans in container
8 out of 10 times when I want to make a coffe the machine tells me that there are no beans in the container after it started grinding for a few seconds. Even though the bean container is full this message comes up. Usually if I try to push the beans down with a wooden spoon I end up with a nice coffe but there is a lot of wasted beans if I don't do that. Thanks for all your help.
  • 1 more comment
  • danidor Dec 19, 2007
    Thank you for your time. I have tried both and it didn't help but after posting our problem we realized it might have to do with the oily beans which we were using lately. Now that we have switched back to drier ones the problem might be solved. Cheers
  • Jase077 Feb 02, 2008
    I am having a very similar problem, the beans compartment is full, the water is full, and the machine is clean in all areas. when making either half or full cup, the machine begins to grind beans as normal, but only for a few seconds, then the water/add beans red light comes on solid, and you hear the pump clicking and cleaning out the ground beans to the wast grinds container. this is happening like the prevoius post said about 9/10 times, the only time it may work is if i clean everything, mix around the beans in the grinder, trying to push them down to the grinder, switching off then on again , and start.
    anyone have any Ideas?
  • danidor Feb 03, 2008
    Hi thanks everybody for the input, since going back to the normal type of beans (dry, not oily) the problem hasn't occured again and we are not wasting our beens anymore.
    Cheers and enjoy your next cup of coffee
I do have the same problem.
I have removed and cleaned the grinder mechanism.
Being an electronic technician I did have a look and tried to find what method they use to detect that the new beans reservoir is empty and I did not see any kind of detector.
I suspect that they monitor the motor current to do this. If it is so would'n it be possible to desable this fonction since it is more then evident when the reservoir is empty or about to be?
Any body knows how they do monitor the status of the new beans reservoir?
Posted on Aug 25, 2008
We have had two different models of these Saeco supers and have had the same problem with both of them. The machines appear to be the same basic internal construction with added bells & whistles.
The issue seems to be with the design of the bean hopper; the beans don't move with gravity from on top of the grind adjustment piece, down to the grinder area.  I have found that if one lightly pushes the beans down at the back of the hopper, pushing down towards the front, that the beans will fill the air pocket which forms around the grinder inlet. It works better with the hand than with a spoon.  I'll also tap the side of the
hopper when the beans are grinding to help the beans shake loose
and drop down in the hopper.  Unfortunately, it doesn't seem like
this gets any better with cleaning, degrees of bean roast (oily-dry) or time; It's just something you have to get used to doing whenever you make coffee.
Posted on Feb 03, 2008
  • Saeco Expert
  • 223 Answers
Try increasing your grinder size. Normally the machine come on 8, however depending on the coffee type and darkness it may differ. You can also try cleaning your grinder out.
These grinder instructions are similiar to your machine
Saeco Parts and Cleaning Supplies
Posted on Dec 19, 2007
The plastic shield in the coffee container on my saeco incanto de luxe broke yesterday and fell directly onto the beans, but I was still able to make my coffee this morning, but this afternoon, the...
Vac out the bean chamber, then remove the 2 or 3 screws and carefully lift the bean hopper off the machine, then continue cleaning the grinder, careful not to lose the gasket around the top of the grinder. When done reassemble and try to brew but do not add beans to hopper as yet. Until you are sure all the plastic pieces are out.
Sep 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
Fix Saeco Magic De Luxe Not Grinding problem
If you leave the machine for a while, the residual ground beans in the grinder stick and clog the grinder.
- thus "timing out" with the "No beans" light.
After taking apart the grinder and cleaning it out, it still didn't grind. -
Then we ran some ground beans through it a couple of times, and then put fresh whole beans on top of the preground, and it took.
Worked great after that.
on May 06, 2009 | Saeco Magic De Luxe Espresso Machine
Beans fall from inside into the tray, sometimes onto the floor unable to find problem
the only thing i can see the cooffe bean container there a rubber seal that seal beetween the grinder and container you need to empty the beans remove container 2 screw that hold the container black seal is there let me no pierre
Aug 02, 2009 | Saeco Vienna De Luxe Espresso Machine
Out of 10 cups of coffe maybe i get 4 cups
Try to make a cup of water (the) and see if you can make a full cup.
Try to take out the brewing unit (central unit) and wash it in warm water.
/Best regards
Jan 29, 2009 | Saeco Incanto Classic Espresso Machine
From 1-7 on the coffee grinder, which is the finest grind.I Hve misplaced my manual
If you take of the bean hopper and the adjustment pin, then you can turn the outer ring clockwise 4 step.
Check also that the ring not is loose.
Jul 15, 2008 | Saeco Magic De Luxe Espresso Machine
descaling it with special produit not vinegar 1 part descaler 1 part water put in water container start machine open water valve for few second leave it for 15 minute repeat untill empty rinse very good cheers
Jan 21, 2008 | Saeco Incanto Classic Espresso Machine
Machine Is Stuck on "VENTILATE" Command
Sounds like you all have the same problem. Your flow meter has been obstructed with a small chip of coffee bean that got into your water tank receptacle when your tank was off. You need to remove the top or back depending on your machine and remove the flow meter. It twist apart. The intake is a small opening and that is creates the jet of water that spins the flow meter. If it gets obstructed the meter doesn't spin and you will get the ventilate message.
Dec 05, 2007 | Saeco Vienna De Luxe Espresso Machine
Help....we poured some water into the bean grinder/container
You have to take off the bean hopper, turn the ring on grinder anticlockwise to you see the claque. Take out the middle off the grinder and clean everything carefully.
After that you have to put it back again, when you have the middle off the grinder back you turn the ring clockwise to the end, after that you turn it anticlockwise 14 "tick".
Sep 04, 2007 | Saeco Magic De Luxe Espresso Machine
Coffeee beans won't feed into grinder
Push the coffe brew button again. It should take right off and grind again.
Jul 15, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
415 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
