Question about Samsung PCJ522R 52" Rear Projection Television
Samsung PCJ522R: When powered on, timer light flashes about 10 seconds but there's no audio or video. The set then powers off by itself. Any ideas?
  • Samsung Master
  • 8,457 Answers
Ur power supply board is dead,need it to be replaced.
Posted on Sep 29, 2009
Power cycling
Push the "menu" button on your remote
Tab over to the "time" menu
check all the settings in there, turn of the sleep timer etc...
Try a factory reset
Push the "menu" button on your remote and go to settings, scroll down and push reset.
I hope this helps
Feb 10, 2014 | Samsung LN40D550K1FXZA - LN40D550 40 1080p...
The power light is not coming on,only some timer light
IM NOT GETTING ANYTHINK WHEN I DO THAT NOTHING AT ALL ITS JUST THE RED LIGHT FLASHING :(
May 08, 2011 | Sharp CD-SW330 Shelf System
52' samsung pcj522r won't turn on.
have you replaced the lamp yet? other things that cause ttat are the ballast,cooling fan or power supply board. call1-800-samsung for nearest service center.
Nov 25, 2009 | Samsung PCJ522R 52" Rear Projection...
Toshiba 52HM95 lights blinking
Mine was having the same problem. Just heard back from the shop and they said it's the light engine. They want $750 to fix!!!
Sep 10, 2008 | Toshiba 52HM95 52" HDTV Projection...
Samsung HLN467W Flashing "LAMP" LED
remove the lamp and visually check if inside looks broken.if visually do not see any thing wrong,check if you have 300 volts dc supply on the ballast which starts the lamp.if you do then the ballast may be defective.if you do not then the power supply should be checked.
the lamp should always be tried first especially if is older than two years.
note - be aware about the switch at the door lamp.the door should be closed,otherwise tv will not work.if you remove the back cover,make sure to bypass the switch temporarely so you could work on the set.
Sep 03, 2008 | Samsung HLN467W 46" Rear Projection HDTV
Samsung rear Projetion Tv Model No. PCJ522R
I Have A
Samsung rear Projetion Tv Model No. PCJ522R i was cleaninthe inside when i spilled oil on half of the board power supply,when the tv is connected power button is light up but wont turn on,what can i do?
Mar 18, 2008 | Samsung PCJ522R 52" Rear Projection...
SAMSUNG PCJ522R 52IN Rear Projection TELEVISION WILL NOT P OWER ON
1)Check PC boards for CRT coolant leak.Look closely at the
signal board and the main/power PCB.
2)Check any/all fuse devices in power supply
3)Let me know your findings....T.
Oct 23, 2007 | Samsung HCN4727W 47" Rear Projection...
Samsung PC J5225 shuts down after 3 - 5 seconds
It sounds like the tv power supply has problems. you probably should call a service center about a repair.
there are "safety" features built in to any tv with a "crt" type of screen that will not allow the tv to run when there is a problem.
Oct 20, 2007 | Samsung PCJ522R 52" Rear Projection...
Samsung PCJ522R 52" Rear Projection Television Logo
182 people viewed this question
Jerry Greenberg
Jerry Greenberg
