Question about HP Compaq Presario V6700TX Notebook
Error 7 (net::ERR_TIMED_OUT): The operation timed out. Up until recently - I was able to connect to 1 particular site. www.trademe.co.nz Now, I can connect to almost everything except this one site. It keeps coming up with the error above & also: This web page is not available. The web page at null might be temporarily down or it may have moved permanently to a new web address. Here are some suggestions: Reload this web page later. When I try to Re-load it... it doesn't work. Any suggestions as to how I can fix this?
  • 2,418 Answers
Try >HTTP:/www.trademe.co.nz<
Posted on Sep 29, 2009
My computer is showing that it is timing out when I do a ping command. This then freezes my Citrix apps that I have to use for work and I can't work. Is there a firewall blocking the connection?
First question, why are you running a ping? do you have a problem connecting to your Citrix apps?
It is very probable that your work is blocking ping for your Citix server.
If you want to find out *where* the blockage is try a trace route
tracert (destination address\ hostname).
Some blanks are to be expected as most Network suppliers don't reply to pings either,
so for :
tracert www.bbc.co.uk
but you should get something like :-
1 3 ms 3 ms 3 ms routerlogin.net [192.168.0.1]
2 * * * Request timed out.
3 18 ms 17 ms 18 ms nrth-core-2a-xe-825-0.network.virginmedia.net [62.253.128.105]
4 * * * Request timed out.
5 26 ms 124 ms 37 ms brhm-bb-1c-ae1-0.network.virginmedia.net [62.254.42.210]
6 23 ms 24 ms 27 ms tcl5-ic-2-ae0-0.network.virginmedia.net [212.250.15.210]
7 24 ms 80 ms 22 ms 212.58.239.249
8 * * * Request timed out.
9 31 ms 38 ms 33 ms ae0.er02.cwwtf.bbc.co.uk [132.185.254.90]
10 21 ms 28 ms 38 ms 132.185.255.165
11 27 ms 31 ms 25 ms bbc-vip046.cwwtf.bbc.co.uk [212.58.246.55]
Nov 20, 2016 | Computers & Internet
I have a mazda familia bj5w 4wd disc brakes front and rear.1.5 manual, does the sport 20 carry the same rear caliper seal kit?
Search Results
    Mazda Familia Parts - PartsWorld NZ
    www.partsworld.co.nz/parts/mazda/familia
    Mazda Familia Parts. Browse the categories below to find the parts you are looking for. If the part you want is not in stock, fill in the request a part form and we will ...Missing: 4wd ‎caliper
    Mazda - Familia - BJ5W - Nengun Performance
    www.nengun.com/mazda/familia-bj5w
    Matches 1 - 17 - Mazda - Familia - BJ5W. We supply aftermarket performance parts direct from hundreds of manufacturers in Japan, if you have a request send us ...
    Mazda ' Car parts & accessories ' Trade Me
    www.trademe.co.nz > ... > Car parts & accessories > Mazda
    Trade MeMazda BT50 2009-2012 New Spot light Kit Complete. Closes in 14 ... 1990 FamiliaBG5P Chassis Ignition Barrell. Closes in 7 ... Ford/Mazda Front lower Rear Inner Bushes. Closes in 7 ... Mazda SP20 BC Gold Adjustable Suspension ~SPR ... Rx7 flywheel standard Have A S4 And S6 ... Mazda Parts ' Japanese Spares Ltd.
Feb 08, 2016 | Mazda Cars & Trucks
I need battery for uniden 050XR the battery is BP-052 7.2V,900mah
Check this site for a battery replacment:
http://www.trademe.co.nz/electronics-photography/radio-equipment/amateur-radio/auction-424872341.htm
Oct 31, 2011 | Radio Communications
"Error 7 (net::ERR_TIMED_OUT): The operation
hi,
re-install your google chrome browser.
Feb 05, 2011 | Google Chrome
WHERE CAN I BUY A JVC RV-B550 IN NEW ZEALAND
You may be able to find one at http://www.trademe.co.nz
there are at least 1 or more there, just looked
Oct 08, 2009 | JVC RV-B550 Cassette/CD Boombox
How do I unlock my LG RC388 to play other region disks
YES, it can be changed to view all regions. I've just done my new RC388 (bought it 4 hours ago) and it works.
To start the hack:
Click the home button on the remote, go to the Setup page, highlight the 16X9 TV aspect ratio and enter in this coded sequence: 1 3 9 7 1 3 9
A new factory menu now comes up on the screen.
To change the values of these options hit the enter button and scroll with arrow keys until you get to the option you want to change. For the region code hack replace the value of "option 5" with the value of: ff
Press enter.
(Changing this value will set unit to region code 0 which should allow any region to be played on the player.)
Now, hit the "return" button to save and exit.
Switch off the machine - switch on - all is well now.
Good Luck,
Will
Mar 31, 2009 | Televison & Video
Network Timeout error.... Going crazy! Up until about a week ago, I was able to access www.packratwiki.com without a problem. Now, I am getting a network timeout error. None of the computers in my...
Hi
I am assuming that you are using a router/firewall for your home network which is hooked up to your modem or probably a combo of both. First of all if the problem persists you have to make sure that your firewall / router is not blocking this IP. In order to check this out ...
1. If it is just this site that you are not getting: download a program called ultrasurf. Install and see if when you provide the IP above and get the website to come in. I checked the website for you and it is online and working. So it is a local problem.
2. If it is all the sites you're not getting and you know how to configure your router, I would give it a go and reset it.
3. FInally: you have to add this site to the exceptions of your firewall so that he lets it throughOnce you have determined which one of the 2 problems is yours. Add the site to the exceptions of your firewall so that you don't stay using ultrasurf for browsing that site. By the way use google to look up the program i mentioned :)
I hope that I was of help to you :)
Jan 07, 2009 | Computers & Internet
HP Compaq Presario V6700TX Notebook Logo
792 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
