Question about Briggs & Stratton Garden
I have a 14 hp Briggs and Stratton engine that is backfiring. How can I fix this?
How to set timing acording to marks
Posted on Nov 16, 2012
  • 279 Answers
Sounds like the timing is off. The easiest thing to check is the flywheel key. It is also the most likely culprit. Just remove the flywheel and check the key to see if it is damaged, replace it and you are in business. Good luck...Lee
Posted on Sep 29, 2009
Briggs 5 hp backfires through muffler
Exhaust valve is not closing completely or the valve seat is cracked.
Sep 24, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and Stratton 190CC 6.75 HP mower engine wont start. It backfires through the carburetor. Prior to this problem the engine would not shut down immediately when the kill switch control handle was...
Sounds like the flywheel key may have sheared and has knocked the ignition timing out. Check that first as its a cheap fix if that is the problem
Nov 04, 2013 | Briggs & Stratton Garden
My briggs and stratton 18 hp vanguard model 356447 will not start just back fires through the carb. I have good comprssion and spark at both plugs. I replaced the flywheel key as thought the backfireing...
check intake valves for proper seating. If the valves do not close completely it will allow the engine to backfire thru the carb. Another possibility is internal timing caused by the misalignment of the timing gears between the crankshaft and cam gears.
Oct 29, 2013 | Briggs & Stratton Briggs Stratton Intek V...
Engine won't start getting fuel and fire crank but won't start it wants to backfire
Try posting this question under mowers. This is the measurement tools category.
Aug 27, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Backfiring
Backfiring is either burned valves or often due to timing slipped because of broken flywheel key/keyway.
Jun 17, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
Engine won't start and backfires
Did you loosen the coil when you changed the key? Check the setting between the flywheel and the coil. !0,000ths, I think.
May 17, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have a briggs and stratton 14 hp ohv engine on my murray lawn mower it starts and runs good until i go to full throttle or engage the blades then it seems to flood out and start backfiring i can lower...
It sounds like you are putting it into choke mode. The choke is usually all the way up on tractors. And it will make it backfire and flood out. Just rev it high enough to work and don't go into the choke mode. hope this helps.
Apr 21, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Garden Logo
369 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
