Question about Garden
John Deere LT155 Lawn Tractor has trouble going uphill
Our John Deere LT155 Lawn Tractor/Riding Mower balks and moves very slowly going uphill-either forward or reverse. I was told this has to do with the transmission belt, but it was replaced two years ago. Is this something I can fix myself, or do I need to take it to the repair shop that installed the transmission belt? Or could it be something else?
    Top Expert:
  • Garden Master
  • 12,173 Answers
U can change belt yourself need belt size and have to remove cutting deck but check belt tension first if loose with brake off belt stretched out and slipping needs replacement
Posted on Sep 29, 2009
My John Deere rinding lawn mower won't go forword or backwards
John Deere mowers, for the most part, use hydrostatic transmissions. These use an oil of some type (they vary by model) in the transaxle to provide hydraulic pressure to move the tractor. Older tractors will eventually experience some oil leakage over time due to seal wear. If the level gets too low, then you fail to move. Check the oil level in the transaxle. The location of the reservoir varies from model to model. If it is low, after determining the correct oil to use, fill to proper level. Then, start the tractor and work the hydrostatic drive lever forward and backward slowly and continuously until you get full speed operations in both forward and reverse. This can take a few minutes until all the air has been purged from the system.
Oct 03, 2016 | John Deere Garden
How do you change the drive belt on a john deere d110 riding lawn mower?
You can look at the manuel that came with the mower or if you did not get one, go to the JD mower web site and look up you model and download the needed documentation. If that is not possible contact the local JD mower dealer and get a copy of the mower deck docs and look at the instructions for belt replacement.
Jul 31, 2014 | John Deere Riding Lawn Mower. D110 42 in....
John Deere D105 Lawn Tractor will not go forward
does it go in reverse ??? if no, suspect the belt, or did you have the wheels off of it recently ??? if yes then still suspect the belt or a bad transmission
Nov 23, 2013 | John Deere Garden
John deere sabre 2354 hv moves slow forward, even slower in reverse
this hydrostat drive tractor is designed to max at 5.5 mph forward, 2.5 in reverse, check linkage at pedal if you dont think your achieving those speeds
Mar 23, 2013 | John Deere 420,1020,2010,2020,2510,2520...
I have a John Deere L120 tractor with a hydrostatic transmission which after a half an hour of mowing struggles to go in reverse and seems to loose power when moving forward without stressing the motot. I...
Hi, your problem is caused by the transmission over heating. Remove the battery and battery carrier and clean all grass and debris from the hydro cooling fins and fan. Hope this is helpful, regards Phil.
Sep 08, 2011 | John Deere 22HP VTwin 48" Riding Mower
I have a John Deere LT155. When you let off of either the forward or reverse pedal the tractor comes to an abrupt stop. It will actually lock the wheels.
Hi, most likely the brakes are hanging up. Follow the brake pedal path to the rear of the mower, it is attached to a small arm on the side of the diff that is probably locked forward. This lever and the pins behind it need to be freed up so the lever operates forward and backward freely when the brakes are applied and released. Hope this helps, regards Phil.
Jun 01, 2011 | John Deere 22HP VTwin Hydrostatic 42"...
Need instructions for changing a drive belt on a john deere LT155 lawn tractor. When mowing up hill the forward motion is slipping even though i am not loosing traction. if i come off the pedal and start...
I have googled LT155 and came upon john deere LT155 lawn tractor(noncurrent). It took me to John Deere's site. I put in your model number and it had several catagories. I would try the alphabetical list, go to B and look for traction belt.
Good day.
Oct 14, 2009 | John Deere Garden
Garden Logo
1,906 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
